2 stroke mix ratio help plz
john3287
PostPosted: 18:39 - 04 Sep 2015    Post subject: 2 stroke mix ratio help plz Reply with quote
Hi all, I have ordered a new oil pump but It wont be here until Monday is there anyone that can recommend a 2 stroke oil to petrol mix ratio please for my malaguti f15 Firefox so I can use It to get to work just until my pump turns up.
Thanks
Papa Lazarou
PostPosted: 20:47 - 04 Sep 2015    Post subject: Reply with quote
Read your manual. Two stroke oil is much better than it used to be.
To be more helpful:
https://www.rctek.com/pdf/fuel_to_oil_ratio_chart.pdf
PostPosted: 22:20 - 04 Sep 2015    Post subject: Reply with quote
Short term safe bodge is probably to got for 33>1 or 25>1
Remember to jet up to suit.
K
john3287
PostPosted: 23:19 - 04 Sep 2015    Post subject: Reply with quote
To be more helpful:
Manual doesn't have any info as to what oil mix ratio to use as the oil had a totally seperate tank for the petrol so i just poured into a separate oil tank then the oil pump done the rest.
john3287
PostPosted: 23:27 - 04 Sep 2015    Post subject: Reply with quote
K
Thanks.
I will go for a ratio of 29>1 so in the middle of what you said, also the bike has a size #68 gurtner main jet already in it as stock was #60.
Do you think a ratio of 29>1 will make my bike smoke its back out or will it just be abit of trial and error until my pump turns up.
Also kickstart you mentioned at the beginning of your reply a "short term safe bodge". is it not good to mix your oil and petrol for a scooter yourself, will I damage my scooter if I don't ride it with oil pump in.
john3287
PostPosted: 23:30 - 04 Sep 2015    Post subject: Reply with quote
Sorry kickstar I meant to say ride scooter without oil pump in.
Waynerck
PostPosted: 00:09 - 05 Sep 2015    Post subject: Reply with quote
I would aire on the side of caution and go for the ratio with a bit more oil to fuel , a bit of extra smoke to keep your piston happy
https://www.youtube.com/channel/UCCPfr4A66m1Ky4spt6kcpsg
john3287
PostPosted: 01:13 - 05 Sep 2015    Post subject: Reply with quote
Wot ratio would you recommend waynerck
misscrabstick
PostPosted: 08:40 - 05 Sep 2015    Post subject: Reply with quote
On my trials bike I use a silkolene premix at 50 to 1, like others say though I'd go 30 to 1 I think, overdoing it will be smoke and plug fouling at the worst.
Remember though oil in the fuel mix means less petrol = leaner mixture= overheating damage possible, upjet it or risk it, choice is yours, if you decide to not upjet then I suggest avoiding thrashing it.
MCN
PostPosted: 09:47 - 05 Sep 2015    Post subject: Reply with quote
Does the op understand 'Up Jetting'? (Tamperfering with the carburettor jets to change the air fuel ratio/s.) It may be alien language for some.
john3287
PostPosted: 12:18 - 05 Sep 2015    Post subject: Reply with quote
The scooter has already been up jetted by me, I emailed malaguti themselves to ask what stock size main jet was and reply of them stated #58-60 and I have up jetted to a #68 main jet, the only problem now is the right oil to petrol mix ratio.
stirlinggaz
PostPosted: 13:25 - 05 Sep 2015    Post subject: Reply with quote
Hi,
just go for 33/1 thats always my default pre-mix setting.
its also easier to measure out.
its translates to around 100ml of fuel to 3ml of 2t oil or a litre of fuel to 30ml of 2t oil.
cheers,
GAZ
john3287
PostPosted: 13:44 - 05 Sep 2015    Post subject: Reply with quote
So 33>1 is ok for a 2 stroke liquid cooled scooter Gaz
PostPosted: 20:06 - 05 Sep 2015    Post subject: Reply with quote
25>1 is 4%, 33>1 is 3%. Both relatively easy to measure out. 50>1 is fairly common, so both are relatively safe.
Running premix has other issue. Using oil in the fuel means you are getting less fuel for the same throttle, etc. Hence leaner.
Also with an oil pump you are still getting oil into the engine when the throttle is closed, with premix you are getting virtually none. Longer you do it the more likely it will cause a problem (ie, long down hill run with the throttle closed the whole way).
K
john3287
PostPosted: 22:09 - 05 Sep 2015    Post subject: Reply with quote
Aww no way can I balls the scooter up by using premix, though it would of been ok, I will use the ratio mentioned in earlier post.
1 quick question, once i receive my new oil pump do I have to do any sort of timing when putting the stator and fly wheel back on or can I just be fitted back to the bike without and pissing about,
Thanks for all your help everyone Very Happy
Blue_SV650S
PostPosted: 22:17 - 05 Sep 2015    Post subject: Reply with quote
Stuff can run at 100:1 these days, but if you mix in at 30:1 you can't go far wrong!
PostPosted: 00:15 - 06 Sep 2015    Post subject: Reply with quote
I have no idea with scooters but if anyone had suggested I ran any of my RD's, GT's or YDS7 on premix I would have had a heart attack.
Get the bus till your pump arrives.
john3287
PostPosted: 00:30 - 06 Sep 2015    Post subject: Reply with quote
Carnt use the bus pal as no buses running at the time i start and buses don't go anywhere close to were I work.
john3287
PostPosted: 20:08 - 08 Sep 2015    Post subject: Reply with quote
My petrol pump came today, was wondering do I have to do any sort of timing once i have fitted it and put the stator and fly wheel back on, or can I just put it all back together without any problems.
john3287
PostPosted: 22:13 - 08 Sep 2015    Post subject: Reply with quote
Haha sorry my oil pump I meant to say my stupidity got the better of me
PostPosted: 22:36 - 08 Sep 2015    Post subject: Reply with quote
Not come across a 2 stroke with a pump that needs to be timed up. But if you have moved the stator then you might need to retime the ignition timing.
You will likely have to bleed the pump through to make sure there is no air in the pipes / pump.
K
john3287
PostPosted: 01:14 - 09 Sep 2015    Post subject: Reply with quote
I have put a permanent pen mark on the stator and fly wheel and also had the piston at the top of the cylinder before I removed pump so would I be able to just put it all back together and match up the pen mark
The last post was made 11 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 128.35 Kb
