| Vincent |
 Vincent Banned
| recman |
 recman World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 09:31 - 06 Sep 2015 Post subject: |
Oh no....it's a cruiser jack I hope none of the neighbours saw it through the garage door
https://www.youtube.com/watch?v=BipVmHzBWE4
Classic Ad  ____________________ Space Is Deep |
| Vincent |
 Vincent Banned
| MCN |
 MCN Super Spammer
| Vincent |
 Vincent Banned
 Posted: 10:02 - 06 Sep 2015 Post subject: |
Cheers I presume the shaft and piston are a one-piece affair? I was wondering if I could get someone to knock up another shaft. What's the correct terminology for that "shaft" BTW? Is it a con-rod or just a piston? ____________________ Space Is Deep
| Vincent |
 Vincent Banned
| Pete. |
 Pete. Super Spammer
 Posted: 10:58 - 06 Sep 2015 Post subject: |
Just clean the shaft with a strip of rough emery, put it back in and give it a whack or two. Re-fit spring and pedal.
Ahh, I see it's too late for that. You could have rolled the emery into a rope and pulled it through the spring, been done in a few minutes. ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
| MCN |
 MCN Super Spammer
 Posted: 13:13 - 06 Sep 2015 Post subject: |
Excellent photos Sir.
They are too good for this forum as I can actually make out what I'm looking at.
Those sort of things are 'usually' made from 'nominal' size/diameter bar stock. (i.e. 5mm 10mm 1/4" 1/2" as opposed to a custom 'turned-down' in a lathe sort of a size.)
If you get stuck for spares, you 'may' be able to cut the shoulder of a long-enough bolt to length and drill the pin hole to suit. If you're stuck. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Vincent |
 Vincent Banned
| MCN |
 MCN Super Spammer
| bugeye_bob |
 bugeye_bob World Chat Champion
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
 Posted: 18:00 - 06 Sep 2015 Post subject: |
| MCN |
 MCN Super Spammer
 Posted: 20:10 - 06 Sep 2015 Post subject: |
I don't think that has a piston on the bottom of the rod I think it's a very basic pump.
And is just a rod with a pin hole in one end.
The rod looks as like it will pull out the the barrel in the direction of the bursted hole.
There will be a gland seal in the end where the rod sticks out.
It probably has no piston seal either and just relies on the displacement of the rod going in and out of the 'barrel'.
It's a very low pressure jack system. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
 Posted: 20:30 - 06 Sep 2015 Post subject: |
| Vincent |
 Vincent Banned
 Posted: 09:43 - 08 Sep 2015 Post subject: |
| recman |
 Posted: 09:51 - 08 Sep 2015 Post subject: |
Could always message the seller expressing your interest in the jack but you'd like to know if spares are readily available.  |
| Vincent |
 Vincent Banned
 Posted: 10:14 - 08 Sep 2015 Post subject: |
| recman wrote: |
I think I know the answer but 'no harm in trying I guess
It's a big seller too...big sellers aren't always the best to get info out of as they tend to employ someone to answer the messages that usually know very little about anything  ____________________ Space Is Deep |
| Pete. |
 Pete. Super Spammer
 Posted: 06:31 - 09 Sep 2015 Post subject: |
Cut the end off, clean with emery, punch out the ram, clan with emery some more, replace the ram, weld a big nut on it sideways. Re-fit to jack, pin goes through hole in nut. 15 minutes work. ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
 Posted: 09:44 - 09 Sep 2015 Post subject: |
That's what I like about you Pete..........you may have an engineering workshop at your disposal.......but you've still studied the dark art of "improvisation"
The pistons been soaking a couple of days, I'm home now, will get my "Coffee table" vice out and have a go at hammering it free. No welder though, which is OK as I can't weld for toffee anyway I'll see if I can get some local assistance and get a new one made up. ____________________ Space Is Deep |
The last post was made 11 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
