| x alex x |
 x alex x Renault 5 Driver
 Posted: 22:35 - 06 Sep 2015 Post subject: CBR running issue after many new parts |
Hey all,
My GF's CBR has been a bit of a headache since I picked it up, I bought it cheap and in bits but once together it passed an MOT and seemed to run fine.
After a while it misfires and dies then won't start again. Plug always looks oily.. Once cleaned it won't always go again and will take a few hours or over night, some times it will struggle to start too and do the misfire thing.
It will leak fuel out of the overflow sometimes too.
So far I have replaced various parts (not all because of this issue)
Carb from a running bike
New coil & lead
Plug
Air filter element
Only on 7k miles and engine compression is at about 145psi, standard too, valve clearences to spec and the breather pipes aren't bloked
I'm kind of stuck now and really can't work it out.. Unless it's burning oil through the HG or something but there's no grey/blue smoke at all.
Any help would be great I was sure a new carb would sort it out.. Trying to get her into bikes and this one is putting her off, bought it because I wanted something more reliable than the 125 2 strokes I used to have
Thanks! ____________________ Rides: Yamaha FZR 750 & KMX 200
Drives: 2007 Fiat grande Punto Sporting 1.9 Multijet, Remapped, 194BHP  |
| kramdra |
 kramdra World Chat Champion
| x alex x |
 Posted: 00:50 - 07 Sep 2015 Post subject: |
Thanks for the reply, the overflow only happened a couple of times after trying to start it, happened with the other carb too though but I suppose it's not impossible for this one to have an issue too.. I put it down to it being on a slant and on the side stand as that's the only time it happened
I've had it apart and measured then float height which was within spec and all looked well ____________________ Rides: Yamaha FZR 750 & KMX 200
| B0ndy |
 B0ndy Spanner Monkey
| misscrabstick |
 misscrabstick Crazy Courier
| x alex x |
 Posted: 16:59 - 07 Sep 2015 Post subject: |
Yeah it still sparks after it has cut out.
I've just had the carb off again checked it over carefully and put it back to standard.
Started and ran OK apart from the revs hanging a little but I let it warm up but cut out and won't start again, plug is a little sooty but otherwise OK. Cleaned it and still won't run but sparks OK.
Popped the fuel pipe off the carb to check its coming through OK (it is)
Forgot to say I replaced the rubber inlet boot too as it didn't look great.. That was another time I thought I'd found the problem lol
No flooding though now it's on level ground I think the overflow was down to it being un level for a while turning over ____________________ Rides: Yamaha FZR 750 & KMX 200
| x alex x |
 Posted: 17:37 - 07 Sep 2015 Post subject: |
Thanks for the replies though everyone
Forgot to say it cut out after I turned the air/fuel screw half a turn out, put it back to how it was and it won't run.. Plug is clean with a nice spark its getting fuel too as I can smell it on the plug. ____________________ Rides: Yamaha FZR 750 & KMX 200
| Vincent |
 Vincent Banned
| x alex x |
| Vincent |
 Vincent Banned
| x alex x |
 Posted: 19:19 - 07 Sep 2015 Post subject: |
Did that earlier, deffinitly fuel.
I'm starting to think I have a carb issue with with replacement too.. It all points towards that even though I was assured it was fine and it's very odd that it would have the exact same issue.
Dear me.. I choose a Honda 4 stroke over a 2 stroke for her because I just don't have the time these days ____________________ Rides: Yamaha FZR 750 & KMX 200
| kramdra |
 Posted: 19:29 - 07 Sep 2015 Post subject: |
Honda 4t 125's are some of the lowest quality bikes you can buy
It does sound like fuelling and float. Have you given carb a thorough clean, ensure all passages are clear and set to factory settings?
Carbs, generally, should not leak unless really leant over to the point of being dropped or crashed, so I would say you do have a float problem. |
| Vincent |
 Vincent Banned
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 20:18 - 07 Sep 2015 Post subject: |
What sort of carb is it, if it has a needle, what position is the clip at?
If the clip is not in the middle position, move it there try again and start from there! ____________________ "Everybody needs money, that's why they call it money!"  |
| x alex x |
 Posted: 21:49 - 07 Sep 2015 Post subject: |
Not sure about them being the lowest quality bikes.. It's put together brilliantly.
The carb is all standard with needle position etc.
Anyway... Got a mate with the same bike and we ended up switching CDIs and she started and ran perfect! Ordered one off eBay for £13 so I'll see how it goes ____________________ Rides: Yamaha FZR 750 & KMX 200
The last post was made 11 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
