Peugeot vivacity won't start
Useless mechanic
PostPosted: 11:00 - 08 Sep 2015    Post subject: Peugeot vivacity won't start Reply with quote
Hey I got a Peugeot vivacity 50cc moped it's my lil bros he had problems with it before such as loss of power while ticking over but now it won't start at I have locked it over but I can't understand why it's not running it has a spark (fitted New spark plug) it has fuel going to carb also (recently new carb gleaming) full tank the only thing is that there are no electrics but I found out that a bunch of wires aound but not going to the starter have been melted so I cut and crimped them back together now when I kick it the fuel light glows but not sure if that happened before none of the lights work the batter has 5v in it i fitted a new batter and rectifier before it stopped staring but that did nothing please help!
doggone
PostPosted: 11:03 - 08 Sep 2015    Post subject: Reply with quote
If it has a fuel pump it probably needs electrics or it won't go Thinking
Or was it running OK before without?
Have you got to the bottom of the attempted spontaneous combustion?
It sounds a bit hazardous unless you keep it in a field away from other items.
Useless mechanic
PostPosted: 11:04 - 08 Sep 2015    Post subject: Reply with quote
Was running fine without electrics before but was losing power randomly
xeningti
PostPosted: 08:41 - 09 Sep 2015    Post subject: Reply with quote
does it start on the kick?
Useless mechanic
PostPosted: 08:46 - 09 Sep 2015    Post subject: Reply with quote
No
xeningti
PostPosted: 12:23 - 09 Sep 2015    Post subject: Reply with quote
Useless mechanic wrote:
No
Try opening the throttle half way while kicking. Its difficult if you can get someone to help
Useless mechanic
PostPosted: 12:25 - 09 Sep 2015    Post subject: Reply with quote
I have tried that I'm a mechanic myself that's why it is frustrating
xeningti
PostPosted: 12:30 - 09 Sep 2015    Post subject: Reply with quote
Your issue is initial spark
or a fuel delivery issue
check all hoses, vacs and your pump
Papa Lazarou
PostPosted: 18:43 - 09 Sep 2015    Post subject: Reply with quote
It's the circuit to the spark plug.
Some wires were melted and you replaced them (what caused that???-best find the source of that problem?). Check over your repair. Multimeter, continuity etc-you know the drill. Boring, but necessary.
Current bike: Honda Blackbird 1100 and a little 250.
The last post was made 11 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 57.61 Kb
