| J.M. |
 J.M. World Chat Champion
 Posted: 10:21 - 08 Sep 2015 Post subject: R1 not passing 10k under load |
I bought my 2004 R1 not too long ago. Before clocking up many miles I took the bike in for a 24,000 mile service to ensure that the entire bike was checked over. I have a Meta Alarm that has been fitted by the Yamaha dealership.
A few things came up, however I opted to get anything that wasn't quite right all fixed with OEM parts. This even included replacing the wiring loom due to it being stretched in places and having clips broken off to the ECU and such.
I've not had the bike back too long, but on Saturday took it out for its first decent ride. During the ride, I noticed two things:
- Indicators on RHS started flashing too fast (both bulbs work - this only started to happen part way through the ride)
- The bike wouldn't pass 10k RPM under load
If I gradually take the bike up in first gear, I can pass 10k RPM. If I decide to give it some stick from say 6-7k in 2nd or 3rd gear, the bike just won't pass 10k RPM. It feels as if the bike is spluttering. I haven't tried it in 4th/5th/6th gear as it gets difficult to find somewhere to get the bike up to those speeds with no traffic.
When the bike refuses to pass 10k RPM, it feels as if the bike is spluttering. I would liken it to fuel starvation. No engine management lights come on. The immobiliser light does not come on. However there do not feel to be any issues with fuelling at other RPMs. Performance pulling away from lights, and accelerating, in general, all feels good. It is only once it hits this 10k revs that anything feels wrong.
The Yamaha dealer has plugged the bike in to the computer and there are no registered error codes. The technician couldn't figure out what the problem is. He's trying to contact the main Yamaha Technical Support now to see if they have encountered any similar issues before.
Right now I'm waiting for the dealer to call me back. I took it to them yesterday.
My main thought is trying to figure out whether or not this issue has been caused by the service that they have performed. I haven't noticed this issue before having the service. 150 miles after the service, I have noticed the issue, and the indicator relay has also gone crazy. I want to ensure that if this is their fault, I'm not left footing the bill.
I'll update this when/if I know more. ____________________ 2004 R1 & 2018 XSR900 |
| Papa Lazarou |
 Papa Lazarou Nova Slayer
| J.M. |
| P.addy |
 P.addy Red Rocket
| J.M. |
| Copycat73 |
 Copycat73 World Chat Champion
 Posted: 17:28 - 08 Sep 2015 Post subject: |
the fuel filter on mine was covered in crap @ 24k .. not that it caused any problems ...  ____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
| G |
 G The Voice of Reason
| J.M. |
 Posted: 18:27 - 08 Sep 2015 Post subject: |
Well, the air filter would have been a part of the 24k service.
Prior to the service, the air filter was incorrectly fitted, leading to excess air being able to enter the system (even unfiltered... ). At the time of the service, one of the ram air intake rubbers was missing.
Alongside the service, the air filter has been changed (and now correctly fitted), a new OEM ram air intake rubber was fitted, and the injectors have been balanced using the computer.
When I took it to them the other day after I noticed the problem, they took it out to check the problem for themselves (which they are able to reproduce) and I believe plugged it in to the computer. I don't know everything that they did to check the bike. ____________________ 2004 R1 & 2018 XSR900 |
| MCN |
 MCN Super Spammer
 Posted: 18:44 - 08 Sep 2015 Post subject: |
Hypotheticals:
Does your computer read the ECM parameters?
It may be in a 'get-home' mode. (If there is such a thing on the bike.) It is a factory preset for when there is a problem in the engine.
The dealer diagnostic can probably read that and reset the ECM or find out if there is a fault. If the person reading is competent.
I know personally of times when dealer teknishons had fcuk all clue about what they were looking at on the diagnostic.
An old army trick that 'can' possibly 'fix' a confused ECM is to disconnect the battery and touch the + & - together. Probably no good now but it doesn't take any time and costs nothing.
The reason for the suggestion is that the ECM doesn't really calculate much it only references stored settings and matches them to the inputs it receives. If all inputs are correct but the ECM is jumbled/frazzeled then you may get the problems you write about.
You could also try a known good ECM as a try B4U Buy.
Some ECM will need initiating by OEM software to work in some engines. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| kramdra |
 kramdra World Chat Champion
 Posted: 19:32 - 08 Sep 2015 Post subject: |
What is the top speed, assuming it might be different in other gears? 10k on a 600 would probably be around 33bhp restriction area, probably much faster on a litre. As there is no ECU codes, I would first check for mechanical restriction that might have been left in by previous owner (or fitted to wrong bike by idiot dealership technicians, or something dropped into the throttle opening ).
I am reasonably surprised they were not able to pull fuelling and sensor information out of the ECU to quickly locate the issue, but dealerships are usually incompetent with electrics  |
| MCN |
 MCN Super Spammer
 Posted: 20:12 - 08 Sep 2015 Post subject: |
| J.M. |
| MCN |
 MCN Super Spammer
 Posted: 20:30 - 08 Sep 2015 Post subject: |
Is the Tachometer working properly?
The spluttering may be the rev-limiter preventing a low earth orbit.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
 Posted: 09:51 - 09 Sep 2015 Post subject: |
I would in no way assume a dealer has done what they say they have done.
Just because you've been billed for an air filter and the time it took to fit one, dfoesn't mean it's been done, or done competantly.
I paid for dealer servicing for three years the one and only bike I've bought from new. Each time I was charged for check and reset tappets, clean air filter and change fork oil. When I went to do my first home service, the paint on the tappet inspection covers was unmarked and they were corroded in place. The fork oil was like rancid, stinkin mayonaise and the air filter was black and full of spiders. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| J.M. |
| J.M. |
 Posted: 12:56 - 09 Sep 2015 Post subject: |
I was very cautious because the only other time I've used a garage to do any work was a Suzuki dealership on an engine I dropped off in their workshop. They claimed to be able to do the work by a certain date, then 2 days after the date they phoned me to claim that they couldn't do it and I'd need a new top end. They made a right mess of it. I didn't need a new top end... because I found someone competent in the end that sorted it no problems. ____________________ 2004 R1 & 2018 XSR900 |
| Minty |
 Minty World Chat Champion
| J.M. |
| MCN |
 MCN Super Spammer
| Fizzer Thou |
 Posted: 17:04 - 09 Sep 2015 Post subject: |
Which model of R1 have you got as I may well have the pukka Yamaha workshop manual?
R1s are easy to work on.
Do you know if the bike had some performance silencers fitted before you bought it?
Have you seen if the bike is fitted with a Power Commander?
If you look in the airbox is it a washable K&N cotton filter?
Or even another type of 'performance air filter?
A friend bought a Yam R1 and it had a Power Commander fitted but the previous owner had reinstalled the standard filter just before selling it.So the PC3 was overfuelling.We installed a new K&N and the bike then ran perfectly
Some places can perform a 'flash' update to a standard ECU.But the box is the same and unless it is marked up that a 'flash' has been performed,you would not know.
Changing the spark plugs is a pain in the rear on injected R1s  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| chris-red |
| G |
| Pol Anorl |
 Pol Anorl Banned
The last post was made 11 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
