How do I get stuck bulb out of headlight casing
notbike
PostPosted: 18:25 - 09 Sep 2015    Post subject: How do I get stuck bulb out of headlight casing Reply with quote
Without having to take the whole fucking set of fairings off just to remove the headlight cluster? Parker bulb needs replacing but it fell in. Wanted to put pic but can't seem to on phone.
Ta.
bugeye_bob
PostPosted: 18:27 - 09 Sep 2015    Post subject: Reply with quote
super glue on stick or finger if long enough, touch bulb, wait a few seconds and remove.
Ben90
Failing that
https://www.twistedthrottle.com/ezimagecatalogue/catalogue/variations/10452-425x350.jpg
Yamaha FZ6 S2
notbike
PostPosted: 18:28 - 09 Sep 2015    Post subject: Reply with quote
Bloody ell that was quick. Thanks lads I'll give it a try.
notbike
PostPosted: 01:48 - 10 Sep 2015    Post subject: Reply with quote
Haha gonna do it tomorrow when there's plenty of light. Couldnt find a stick or superglue at work.
Kind of wondering how I'm going to get the stick under the fairings in the first place.
Very likely I'll start unscrewing fairings after 5 minutes of getting pissed off.
MCN
PostPosted: 10:10 - 10 Sep 2015    Post subject: Reply with quote
A bit of copper wire will work.
MCN
PostPosted: 10:13 - 10 Sep 2015    Post subject: Reply with quote
notbike
PostPosted: 17:10 - 10 Sep 2015    Post subject: Reply with quote
https://i.imgur.com/nhMINhq.jpg
Blue fucker in the corner was stuck, took headlight bulb out and fed an ethernet cable through with some masking tape on the end. The stuck parking bulb was magnetic so I used a neodymium magnet to lift it up from the corner so i could snag it on the tape.
In the end, the biggest pain in the arse was actually getting my headlight back in. Now I might need a new headlight lamp cause this one's scratched up to fuck.
Seems like I'll need to spend a day taking my fairings off and doing the lights properly instead of half-arsing it and fucking up the bulbs.
Thanks for suggestions everyone.
MCN
PostPosted: 17:37 - 10 Sep 2015    Post subject: Reply with quote
You scratched the lens, the reflector or the bulb?
Confused
notbike
PostPosted: 23:51 - 10 Sep 2015    Post subject: Reply with quote
Confused
Woops I meant I scratched the headlight bulb.
MCN
PostPosted: 00:00 - 11 Sep 2015    Post subject: Reply with quote
Meef wrote:
Confused
Ahhh. Thumbs Up
Not to be a smarty arse. But you must try not to leave any fingerprints on the glass part of those bulbs.
Some better bulbs come with a cover to handle them. But a clean rag/tissue is OK.
If you do get a print on the bulb you can remove it with brake cleaner or alcohol/spirit.
The dirt on the glass can cause them to break/brake.
The last post was made 11 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 83.83 Kb
