So..........fuck Microsoft
The Artist
PostPosted: 15:53 - 10 Sep 2015    Post subject: So..........fuck Microsoft Reply with quote
What are my options if I want to not use Windows?
Is there some version of Linux that I can run a VM with windows in so I can still use certain programs?
PostPosted: 15:59 - 10 Sep 2015    Post subject: Reply with quote
Sure you can run it in a VM, but then you're still running it. Which 'certain programs'?
If you don't know which Lunix distro that you want, then you probably want Mint.
https://www.linuxmint.com/download.php
Cinnamon, 64-bit most likely, with codecs.
Andy_Pagin
PostPosted: 16:26 - 10 Sep 2015    Post subject: Reply with quote
Any major Linux distro can run a virtual windows instance via virtualbox, or run most Windows applications directly via WINE.
Apart from games and some very specialised commercial Windows applications there's a free Linux equivalent to practically everything.
Why not install VirtualBox on your Windows machine, virtualise a few Linux Dsistros and have a play with them before deciding which way to go?
The Artist
PostPosted: 17:12 - 10 Sep 2015    Post subject: Reply with quote
I don't like the way it is going with non-opt out tracking for everyday use but some applications will still require Windows.
Good idea. I shall have a play. Thumbs Up Karma
c_dug
PostPosted: 17:21 - 10 Sep 2015    Post subject: Reply with quote
I'm not a massive tech head or anything, I've tried Linux twice in the past (two different iterations of Mint), plus Ubuntu at some stage too.
My experience would suggest that:
- At some point even the most GUI'd up versions of linux will require inputting a dozen lines of code to get something to work properly.
- The equivalent programs to Office aren't quite as slick as you'll have come to expect from microsoft.
- Despite the long list of supported hardware you'll still find things that just will not work!
If you can accept those foibles it's great. I went to Windows 7 in the end as I got too frustrated with the little niggles, I've toyed with the idea of Mint again a few times since then but haven't had another serious play for maybe 2 years.
PostPosted: 17:42 - 10 Sep 2015    Post subject: Reply with quote
Even Microsofts own Office within a Mac environment is utter tosh, would probably say Thunderbird is a better mail client than their Mac Outlook and fuck their Word, want a zoomable image, go fuck Laughing
Andy_Pagin
PostPosted: 17:54 - 10 Sep 2015    Post subject: Reply with quote
Speaking as someone who uses and develops with Linux for a living...
I can't think of any off the top of my head. Linux experts often prefer to edit config files manually, so you'll often be advised to do things that way, but it's extremely rare that you have to.
True and not suprising considering Microsofts massive budget. However OpenOffice/LibreOffice will do what 99% of people want to do 99% of the time - all for free.
Again this was more true a few years ago.
That's the IT equivalent of saying you don't want a car because your last car (1970 Austin Maxi) wasn't up to much.
PostPosted: 21:43 - 10 Sep 2015    Post subject: Reply with quote
If you list them, we may be able to suggest equivalents.
J.M.
PostPosted: 23:03 - 10 Sep 2015    Post subject: Reply with quote
Wine sometimes works for running Windows applications under Linux.
2004 R1 & 2018 XSR900
Pigeon
PostPosted: 23:51 - 10 Sep 2015    Post subject: Reply with quote
I've used Linux as my main desktop since 2000, so am a fan. But I agree with C_Dug on all points.
That said, I've done plenty of Windows XP installs with 58,000 reboots just to get updates and drivers. And had hardware that's no n longer supported etc 9/10 with Linux it just works. No need to go hunting for drivers or software, it's generally these days all automagically detected and installed......generally.
I like Windows 7. I haven't tried 8 or 10. I love/hate MS Office. Use it every day all day. Ribbon is a pile of dicks.
Going
PostPosted: 01:42 - 11 Sep 2015    Post subject: Reply with quote
A lot of Ubuntu based OS are more friendly than windows and mac now. As for using the cmd line, only if you want to.
"Why won't (Office program) open this Office file from (Work, friend)?"
Is a phone call I'm always getting.
Everything on my computer now didn't require me to do any extra work, Windows on the other hand.
VM's and/or wine can help with some Windows programs. Some may even work better. Others, that's the only reason I still have Windows still running.
If you do switch, remember things will work differently. You could be trading one problem for another problem. Once you get used to what's what, what you can and can't do. Why flash hasn't be buried yet, then you could be OK.
Still, bad things can happen and everything c_dug wrote may just affect you Smile
PostPosted: 08:40 - 11 Sep 2015    Post subject: Reply with quote
It's free (in every sense) to try Lunix though, and you can even just put the tip in. Modern Lunix "installers" will ask you whether you want to install the OS, or just have a play with it.
dan_flash
PostPosted: 12:47 - 11 Sep 2015    Post subject: Reply with quote
Another Linux bummer here.
Just download a couple of the distros people have suggested - Mint, Ubuntu or Fedora or something - and boot them up and just try it for a bit without installing it. As Roger just mentioned, in the installer it will give you the necessary options in an easy-to-understand way.
For general use, Linux can and should do just fine without any issues. You might need to use different software to those which you are used to (LibreOffice instead of MS Office, VLC instead of WMP, etc etc) but that's all small fish isn't it.
https://distrowatch.com/
Yamaha XJ600S, Volvo v40.
The Artist
PostPosted: 13:14 - 11 Sep 2015    Post subject: Reply with quote
Most programs I use do have alternatives.
One that doesn't is Winamp. I think Winamp is all a desktop music player needs to be and does the job great. The best feature is you can minimise to a thin control panel so you always have the basic controls visible, even if you are using another application.
https://media.mahalo.com/upload/9/9c/f247b04d5e4842188b64e6ed8d653281_20110708.JPEG?1310151293766
Does anyone know a Linux media player that has a decent library/playlist functions but also minimises in the same sort of way.
nowhere.elysium
The Pork Lord
PostPosted: 13:21 - 11 Sep 2015    Post subject: Reply with quote
Beep media player, last I checked.
The last post was made 11 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 93.16 Kb
