speedo cable malfuncting. anyone can help?
 Topic moved: from Forum Feedback & Help to The Workshop by G (7 Feb 2005 - 20:31)
speedometer malfuncting on Hongdu 125
Help will be greatly appriciate.
0%
 0%  [ 0 ]
thanks for the idea
0%
 0%  [ 0 ]
Total Votes : 0
ramesh kotecha
PostPosted: 19:37 - 07 Feb 2005    Post subject: speedo cable malfuncting. anyone can help? Reply with quote
Brick Wall Karma
I have Hongdou 125 bike. recently my speedometer stoped showing above 20MPH even when I know I am doing 40MPH. Any body has encounter similar problem. I do not want to dismantle anything unnecessary.
mchaggis
PostPosted: 20:30 - 07 Feb 2005    Post subject: Reply with quote
This is in the wrong section, but the problem is a far too familiar one with me at least. The speedo cable stopped showing above 45 on my Hongdou 125 after about 600 miles. 2000 miles later, and I've got a new cable, but it's at home and I'm not, so I've still not got around to replacing it.
The problem is that the cable is sticking. The speedo mechanically driven, by a spinning cable within an outer sheath. The problem is that at higher speeds, the spinning inner cable sticks to the outer sheath, slowing down and hence your indicated speed drops. Then, when it winds up enough to unstick it, it flies round and overcorrects itself as it is then going faster than the wheelspeed in order to catch up with itself. Hence the speedo will fluctuate and flap about, and not show any reading higher than a specific value where it sticks.
Eventually, given enough twisting, the cable will break and need replacing. Ideally, replace it before it breaks.
Which Hongdou have you got? If it's the same as the one in my profile, it is a direct clone (bar the engine and upgraded brakes+ electrics) of the Honda CM125. A speedo cable for that should fit, if the company you buy it from send the right one.
Rolling Eyes
Oh, and (assuming that is the same as mine) if you could let me know if you ever manage to source replacement 12V15W bulbs, I'd be eternally grateful. Mr. Green
I must not be a troll...
Mmmm, Guinness
bish777
PostPosted: 20:40 - 07 Feb 2005    Post subject: Reply with quote
before you fit the cable, fill it with oil-not wd40- use engine oil or gearbox oil.
I had the same problem on my old MZ. The oil is the only way to prevent this happening.
Scotsman37
PostPosted: 20:45 - 07 Feb 2005    Post subject: Reply with quote
Here's a link to bulbs with pics in regards to 12v 15w bulbs
https://www.beedspeed.com/bulbs.htm
Hein Gericke also sell a 12v 15w Moped headlight bulb
mchaggis
PostPosted: 21:25 - 07 Feb 2005    Post subject: Reply with quote
Aha! The one on that link looks remarkably similar to the one I already have, I wonder if it's the same fitting.. The scooter headlamp bulb CMC supplied my brother with when he went to look is 6V25W, which is the burnt out one in the picture, but it is exactly the same fitting. (attached, sorry for the dodgy picture quality but there's not much daylight around just now).
HEADLIGHT BULB
P26S
12 VOLT 15 Watts (BLB100)
https://www.beedspeed.com/bulb%20p26s.jpg
If it's the right one, you are a star! Very Happy
That reminds me, the bulb in my speedo appears to have gone awol too. Confused That should be straight forward to find a replacement for, once I can find the time to take the speedo to pieces to find it. Smile
Thanks for that link. Thumbs Up
Mmmm, Guinness
Scotsman37
PostPosted: 21:42 - 07 Feb 2005    Post subject: Reply with quote
Take your bulbs to a bike mechanic and speak to him rather than a sales person because no doubt he has spare ones tucked away in a box some where in the garage. He'll know what ones will fit and may speak to the sales person, if necessary, to advise him/her which ones you require.
The last post was made 20 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 18 - Page Size: 52.23 Kb
