Cylinder 2 and 3 not firing after shim adjustment
B0ndy
PostPosted: 03:18 - 12 Sep 2015    Post subject: Cylinder 2 and 3 not firing after shim adjustment Reply with quote
I've recently reshimed one of the cylinders on my CB400 which sorted out the compression problem I had, I've since put it back together and have found cylinder 2 and 3 are not firing (cylinder 2 isn't firing at all and cylinder 3 is firing but I can feel on the downpipe of cylinder 3 that it doesn't get very warm).
I've tested all the ignition system as per owner manual and all tests ok , I'm now wondering whether I put the camshafts in the correct position when reassembling the bike.
I now think that because the camshafts aren't in the correct position, that the engine isn't sparking at the correct points of stroke.
Is there anyway to identify when the coils spark for each cylinder? Suspect that might help me find out what's going wrong but can't think of anyway of doing this.
Lined up the timing marks as per below, but now a bit stumped, any ideas please?
https://i.imgur.com/BI4EAxc.png
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
PostPosted: 06:32 - 12 Sep 2015    Post subject: Reply with quote
If the cams were wrong then all of the cylinders would be affected. Check your valve clearances and if they are ok clean the carbs.
PostPosted: 09:30 - 12 Sep 2015    Post subject: Reply with quote
Have you got the plug caps on the wrong cylinder?
B0ndy
PostPosted: 15:21 - 12 Sep 2015    Post subject: Reply with quote
Thanks for the reply Pete. Just checked the valve clearances and they are out of spec on Cylinder 2 and 3, Doh! I'm sure I rechecked all the clearances before reassembling. Sorry, I should of double checked this before posting.
Thanks for the reply stinkwheel. I made sure I recorded which plug caps sat on which cylinder prior to taking the coils off, looks like it was the valve clearances, cheers for the suggestion though.
The last post was made 10 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 41.78 Kb
