Uh Oh!.... :'( Coolant doesn't look right.
MissBex
PostPosted: 18:43 - 12 Sep 2015    Post subject: Uh Oh!.... :'( Coolant doesn't look right. Reply with quote
Hello once again all,
So since replacing the rad and figuring out the overflowing coolant was due to a non connected hose to the reservoir, bike has been fine.
Today I was going to take her for a ride and thought I nest check the coolant in the rad, make sure it was all ok as hadn't checked it for a while - took the cap off to find the coolant looking milky and a thin yellowy-brown coating around the neck and on the rad cap.
Sad Sad Crying or Very sad
I can only assume this is probably head gasket? Someone did mention it could be something to do with oil cooler o-rings.
I spoke to the Honda garage on the phone and the guy says he wouldn't think it would be head gasket as I'd notice other problems too and could just be oily residue from the new rad mixing with the coolant. He said I should firstly just do a coolant change again and see if it does it again.
I'm worried about running the bike though in case I make it worse.
I did run it just now though to check the oil. Let it sit running for several mins on the abbastand and oil and level seem fine.
https://i172.photobucket.com/albums/w11/BBBikergirl/001sm_zpsamushn7p.jpg
https://i172.photobucket.com/albums/w11/BBBikergirl/004sm_zpsnoqpmcmw.jpg
https://i172.photobucket.com/albums/w11/BBBikergirl/007sm_zpspigst6xt.jpg
Thinking about it.. it's only done this since connecting the hose back up to the reservoir that I found unconnected, which was why coolant was coming out from the bike somewhere.... I wonder if the coolant in the reservoir was just manky maybe? But then again, how would it have got like that in the first place :/
Direct Access Passed - 30/05/14
00' Honda Hornet 600
CaNsA
PostPosted: 18:48 - 12 Sep 2015    Post subject: Reply with quote
Looks fine, might be worth draining the coolant from the system and check for any oil... if only to put your mind at rest.
RhynoCZ
PostPosted: 18:51 - 12 Sep 2015    Post subject: Reply with quote
Was the radiator clean before you fitted it?
MissBex
PostPosted: 18:56 - 12 Sep 2015    Post subject: Reply with quote
I flushed it with distilled water before fitting it. It's a Delkevic one.
The coolant I used was the Honda stuff - it's blue. But the stuff it had in it before was green. When I found the unconnected hose to the reservoir, the stuff in the reservoir - that was green - has obviously mixed with the blue and it now looks greener.
Yeah I'm gonna order a bit more coolant as I don't think I have quite enough, and do a complete change and See what it looks like.
That yellowy-brown coating around the cap and rad neck is worrying to me (They are usually silver) and I can see swirls/streaks in the coolant.
CaNsA
PostPosted: 19:00 - 12 Sep 2015    Post subject: Reply with quote
Bex.
It's fine.
It's not broken.
Leave it alone.
MCN
PostPosted: 19:16 - 12 Sep 2015    Post subject: Reply with quote
Whenever I flush coolant I use a flushing solution to lift any residue. Tap water is fine to flush out.
Fill with flushing solution/Cleaner and top up with tap water. (Bleed air out.)
Run the engine until the thermostat opens (until the fan comes on.
Stick Kettle on.
Check level again.
Best if you can take it for a blast.
Allow the engine to cool a bit as opening the cap will blow steam and water out and can burn your wee handy-pops. Some say, Draining the water out will let cold air into the hot engine which may not be good either.
Fill with clean water run the engine (to open thermostat) and drain.
Repeat this until drained water is clear.
Usually two or three will have it sparkling.
Fill with pre-mix or 50% AF (with 2% inhibitor) and 50% clean water Tap is good.
Bleed.
Run to temp.
Kettle.
Check level.
Monitor for a day or two.
No sign of problems then leave it a week or so and re-check.
As the Honda man suggested, the residue may be a mix of two compounds, factory and after-market. Or some sort of spunk from the Rad. maker's manufacturing or a preservation process.
A burst head gasket 'normally' results in compression gas escape into the coolant which causes 'pressurisation'. That will quickly blow the coolant out the engine. Sad
MissBex
PostPosted: 19:35 - 12 Sep 2015    Post subject: Reply with quote
It smells bad too, not like the normal sweet antifreeze smell, more like a gone off horrid smell.
I'll order some more antifreeze in and drain it out as I say and then see, but I'm just worried about running it, it doesn't look right at all to me.
When you say 'blow coolant out the engine', would I see something happen?
The bike runs fine as I'm riding - Honda man says should be under a quarter - which it is.
In traffic/idling etc.. it can get quite hot, but never goes into the red and the fan kicks in to bring it down to around 2/3's to 3/4's until I start moving again.
MCN
PostPosted: 20:31 - 12 Sep 2015    Post subject: Reply with quote
Blowing out the coolant means it overcomes the pressure caps on the rad/expansion tanks and escapes. You would notice it as the steam will come out in big lumps. (inb4-Not steam as it is an invisible gas).
The fan will cycle on and off that is normal. If you lose enough coolant then the engine won't cool and the fan will come on but stay on as there is not enough coolant not to cool the hot engine. And the temp gauge will climb into the red.
Smell may be from machine oil. ??? Some cheaper cutting oils smell like cat's pish. Puke
MissBex
PostPosted: 20:43 - 12 Sep 2015    Post subject: Reply with quote
Yeah that was my worry if it's the oil mixing with the coolant.
Oil in it is Motul 10w30 - it's what the Honda garage put in it on the service a few months ago.
Suntan Sid
PostPosted: 20:58 - 12 Sep 2015    Post subject: Reply with quote
If it's the oil cooler seals, eventually your bike will spew out a load of, brownish, "mayonaise" via the coolant overflow.
It's quite an easy job, exhaust off, drain coolant, remove oilcooler, replace O rings then put it back together, should take a couple of hours max and a much better scenario than a leaky head gasket!
Also if it's the oil cooler it's unlikely you'll see anything in the oil, just oil in the water!
I started a thread, a few years ago, when the seals went on my oil cooler, you should find it if you use the search facility.
MCN
PostPosted: 20:59 - 12 Sep 2015    Post subject: Reply with quote
Sorry I menat the Machine Oil/Cutting Oil which is used in metal cutting machines as lubricant/coolant by the people who made your new radiator.
Cutting oil will emulsify in water so that could account for the 'milky' look. But the cheaper oils don't mixed completely and some 'oil' residue can remain.
PostPosted: 21:11 - 12 Sep 2015    Post subject: Reply with quote
Stop worrying. It looks perfectly fine.
When something does go wrong with the coolant or oil side of things, you'll see it externally. Not just under the cap
MissBex
PostPosted: 21:21 - 12 Sep 2015    Post subject: Reply with quote
Yeah I guess it could be that, but I just have that horrible feeling it's gonna end up being something worse. *Scared face*
Sounds better than the head gasket going, but even that kind of job to me is big, I don't think I'd be confident and nowhere near mechanically knowledgeable enough to attempt doing it myself if it was..
I did notice a little tiny damp patch under the bike in the shed the other day, just under where the water pump is, had a look around the bike but could notice or feel any leak - but could the water pump be any kind or culprit?
MissBex
PostPosted: 21:25 - 12 Sep 2015    Post subject: Reply with quote
It doesn't really show in the picture how it really looks, I can see light streaks/swirls in the coolant like how oil would be if you put it in water.
I don't want to worry but I will, I know what I'm like and have read that if it is something bad then it could cause more problems so I'm a bit worried to, don't wanna mess her up <3 <3
CaNsA
PostPosted: 21:40 - 12 Sep 2015    Post subject: Reply with quote
Yours and everyone else's.
LEAVE IT ALONE.
IT IS FINE.
PostPosted: 22:30 - 12 Sep 2015    Post subject: Reply with quote
I'll send you a photo of all 3 of my rad caps tomorrow. Daily runners that look 100 times worse that have no issues Thumbs Up
MissBex
PostPosted: 23:56 - 12 Sep 2015    Post subject: Reply with quote
hehe ok thanks Paddy, Maybe that'll make me feel a bit better then Smile
CaNsA
PostPosted: 00:00 - 13 Sep 2015    Post subject: Reply with quote
I don't know why I fucking bother....
MissBex
PostPosted: 00:16 - 13 Sep 2015    Post subject: Reply with quote
Sorry CaNsA Sad
I really do appreciate your advice, but saying it's fine, just leave it doesn't put my mind at ease right now when I feel something isn't right with it. You could be right, it might be fine, but I know it didn't look like that before and I know that these kind of symptoms could be early warning signs of something bad, so I want to make extra sure it really is ok rather than just leave it and risk it.
I've ordered some coolant which'll be here during next week (Which I have off work, yay) and I'll do a coolant change just for peice of mind if nothing else. Then see what it does from there.
CaNsA
PostPosted: 00:39 - 13 Sep 2015    Post subject: Reply with quote
its gunk getting released from the coolant system because of the fresh coolant you have put in there.
Paddy, is your coolant as clean as the day you put it in?
PostPosted: 09:13 - 13 Sep 2015    Post subject: Reply with quote
Most certainly not.
My pipes are likely dirty and the engine isn't as clean as one would expect. I'd not expect my coolant to be perfect.
MissBex
PostPosted: 11:21 - 13 Sep 2015    Post subject: Reply with quote
Vincent wrote:
Maybe it's some Rad Weld or similar that the PO stuck in the system after he punctured the rad and it's still lurking about?
I'm away for a week later this afternoon but if you want a second opinion, before I go...........?
Heya Vincent, can't be Rad weld cause it's a new rad we fitted. Ah thanks for the offer but I'm going to work in a few mins till 4.
The last post was made 11 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 130.89 Kb
