gpz second gear
pompousporcup...
PostPosted: 16:27 - 14 Sep 2015    Post subject: gpz second gear Reply with quote
my little gpz has a little issue with second gear (almost sure its just second) which has happened a couple of times now but not often enough to make me want to rip it apart to investimagate.
today i took it to the top of second and then let off the throttle at which point the revs suddenly disappeared. looked as though it had gone into neutral Confused Confused
whats happening when it does this?
*it also, sometimes, doesnt go up into 3rd under load, clutchless or not. i rev, go to change, click it up and it stays in second, prompting many concerns as the revs bounce the limiter
MCN
PostPosted: 16:39 - 14 Sep 2015    Post subject: Reply with quote
slipper clutch? Very Happy
https://en.wikipedia.org/wiki/Slipper_clutch
RhynoCZ
PostPosted: 16:54 - 14 Sep 2015    Post subject: Reply with quote
What GPz? 250, 305, 400, 500, 550, 600, 750, 900, 1000, 1100?
Do you shift the gears firmly enough? Is the gear lever straight on the selector shaft or is there some sort of linkage? Is the linkage setup properly?
pompousporcup...
PostPosted: 16:55 - 14 Sep 2015    Post subject: Reply with quote
500 gen 1. Thumbs Up
PostPosted: 18:04 - 14 Sep 2015    Post subject: Reply with quote
The primary gear selector mechanism can wear over time and as a result doesn't shift the gear fully into place. Two hooks attached to the gear lever pull a toothed selector drum round when you change gear. It engages into the correct place for each gear when a sprung wheel drops into little notches around the circumference of the drum. The neutral notch is deeper than the others to facilitate neutral finding. As such, if it's not pulled fully round into the "second gear" position, it tends to want to drop back round into neutral.
You can also get wear on the dogs which engage the gear clusters together. They are slightly undercut so they stay in position when slid across. Excessive wear can see them sliding back out again
The first is (reasonably) easy to fix because the primary selector mechanism is under a seperate cover below the front sprocket. Can just be a case of filing points back on the hooks if they've rounded off. I say reasonably because it's fiddly, tight and spring loaded BUT you don't have to take the engine out nor do you have to drain the oil if you lean the bike way over..
The second would mean taking the engine out and stripping the gearbox.
Before any of that, check and adjust your chain tension, check your clutch adjustment, check your gear lever travel and make sure you are allowing the lever to fully return to the central position before selecting the next gear (take your foot off it completely before changing and see if the problem still happens).
Probably the most common cause of bikes jumping out of gear is new boots.
pompousporcup...
PostPosted: 14:51 - 15 Sep 2015    Post subject: Reply with quote
thanks stinkwheel. it happens every now and then, not constant thing.
i've put it down to lack of mechanical sympathy for now/until it gets more frequent. i do tend to ride it like you would a newer machine Laughing
RhynoCZ
PostPosted: 15:03 - 15 Sep 2015    Post subject: Reply with quote
I was about to tell you about boots, but the Wheel got to you first.
Learn how to shift gears firmly, move the gear lever all the way (100%), new or old, most of the motorcycles (not Honda) would jump out of gear if you only gently stroke the lever. If you got too thick boots, set the lever so you can comfortably put your foot under the lever (to shift gear up). I also had some issues when I bought new boots. I just turned the gear lever, so I've got 1 up and 5 down, it's easier to step on the lever when at speed rather than lifting it up + it feels cool. Thumbs Up
You do know that you have got to shut the throttle before you kick one gear up, when shifting with the clutch fully engaged, right?
pompousporcup...
PostPosted: 15:15 - 15 Sep 2015    Post subject: Reply with quote
i do, although use of the clutch lever is optional. thottle off is not Laughing
fwiw i've had these boots for a while now without issue although it could well be down to my hamfootedness.
PostPosted: 17:46 - 15 Sep 2015    Post subject: Reply with quote
If it feels like it's clicked up normally but actually hasn't changed, I'd be more supicious of that primary selector mechanism.
pompousporcup...
PostPosted: 18:39 - 15 Sep 2015    Post subject: Reply with quote
That's exactly it. It feels like it has changed but when I throttle back on it hasn't. Haven't noticed it with other gears but then I'm not usually at the end of third going into fourth.
I need to do clearances this weekend so may have a ganders at the mech/selector if all goes well
The last post was made 10 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 66.41 Kb
