| sickpup |
 sickpup Old Timer
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 08:32 - 02 Aug 2015 Post subject: |
The quickest thing to check would probably be the valve clearances, or the 'teaspoon of oil down the sparkplug hole' trick. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| garth |
 garth World Chat Champion
| Robby |
 Robby Dirty Old Man
| sickpup |
 sickpup Old Timer
 Posted: 04:07 - 11 Aug 2015 Post subject: |
Had the engoine apart this weekend and its a valve problem. The Right hand cylinder is running consoderably hotter than the left which with the low compression suggests an air leak possibly from a piece of carbon caught under a valve head.
https://i945.photobucket.com/albums/ad297/750RK/Odds%20and%20ends/20150809_210346.jpg
In fact the right hand cylinder is so hot it has burnt away most of the carbon deposits.
Next step will be to pull all the valves and take a look at whats going on under them. |
| Pete. |
 Pete. Super Spammer
 Posted: 05:47 - 11 Aug 2015 Post subject: |
You going to clean up all that carbon before pulling the valves? ____________________ a.k.a 'Geri'
| sickpup |
 sickpup Old Timer
| Pete. |
 Pete. Super Spammer
 Posted: 17:14 - 11 Aug 2015 Post subject: |
Cool. For cleaning valves I usually turn up a split bush from ally that fits over the stem, then clamp that in the chuck of my lathe. I spin it up and clean them by hand using a scraping tool and a tool rest. It strips the crap off the face and the back of the valve without scratching the metal. ____________________ a.k.a 'Geri'
| stevo as b4 |
 Posted: 18:34 - 11 Aug 2015 Post subject: |
That seems like a lot of carbon deposits for a 60'000m modern engine with EFI and run on todays fuel etc?
I do wonder over 60k would there be a significantly lower amount of deposits if a motor was run on an expensive fuel with all the extra detergents, like BP Ultimate etc?
Oh and as for stuck/sticking rings from long term storage, could this really reduce compression from say 120psi to 60psi??
My old ZX6R may have suffered from sticking rings after I left it 4years in a garage. But with fresh oil and fuel it started without too much bother, but only started smoking a bit after 100miles or so. |
| sickpup |
 sickpup Old Timer
 Posted: 17:57 - 15 Aug 2015 Post subject: |
| stevo as b4 wrote: | That seems like a lot of carbon deposits for a 60'000m modern engine with EFI and run on todays fuel etc? |
Not really, combustion is a messy business.
| stevo as b4 wrote: | I do wonder over 60k would there be a significantly lower amount of deposits if a motor was run on an expensive fuel with all the extra detergents, like BP Ultimate etc? |
In my experince it makes vitually no difference.
| stevo as b4 wrote: | Oh and as for stuck/sticking rings from long term storage, could this really reduce compression from say 120psi to 60psi?? |
Yes its perfectly possible.
| stevo as b4 wrote: | My old ZX6R may have suffered from sticking rings after I left it 4years in a garage.  But with fresh oil and fuel it started without too much bother, but only started smoking a bit after 100miles or so. |
Likely a mixture of rings and valve stem seals.
Okay so I have petrol tested the head and it is weeping slightly from the inlets and pissing from the exhaust valves so its due a good head job. Will drop round to see Matt Walsh at London Cylinder heads and see what he says although I suspect that we will be replacing the exhaust valves on the right hand cylinder as a precaution. |
| 316lad |
 316lad Borekit Bruiser
| 316lad |
| Robby |
 Robby Dirty Old Man
| sickpup |
 sickpup Old Timer
| Pete. |
 Pete. Super Spammer
 Posted: 12:50 - 16 Aug 2015 Post subject: |
I wouldn't worry about the running condition going by the colour of the vales, because that's going to change when it's been worked over anyway. I'd be worrying about how deep you're going to have to cut the seats in the head to get rid of all the pitting.
Can the head shop press in new seats? ____________________ a.k.a 'Geri'
| sickpup |
 sickpup Old Timer
| Robby |
 Robby Dirty Old Man
| stevo as b4 |
| sickpup |
 sickpup Old Timer
 Posted: 18:16 - 17 Aug 2015 Post subject: |
| stevo as b4 wrote: | I still can't believe that that's a 60k engine, especially as it's an EFI lump that technically should not overfuel like a badly set up bank of carbs etc. |
In this respect carbs are better as once set they are set. Fi on the other hand continually tries to optimise even if values are wrong.
| stevo as b4 wrote: | Do you think the exhaust valves have been held off their seat by all the deposits that has then caused both the low compression and also the burning and pitting of the seats? |
Mentioned this earlier, possible bit of carbon. But I have the full reason below...
| stevo as b4 wrote: | Oh and if you really think that the average modern injected four stroke bike engine will look that coked up inside after 60k, if ever I own another, I'll be chucking in bottles of fuel system cleaner, and spraying water down the throttle bodies with the engine running every 10k or so to try and steam clean the chambers. |
It won't work and if you are really unlucky it will and all those loose bits of carbon will kill your engine.
| stevo as b4 wrote: | I don't like to think my old ZX6 could have had fucked valve stem seals after 4years unused in a dry garage? It had 2000mile oil and filter changes, and I was always told that 4stroke engines with lots of clean oil in them, leave the internals coated in a nice film of lube for a very long time even when sat unused. |
Thats pretty much rubbish I'm afraid. There are specific oils manufactured for engines that aren't being used such as new or re-cons called iirc preservation oils. Commonly used in aircraft but less common in automotive applications.
If the valve stem seals failed it would be because the rubber went hard and took a set.
So I've been to the cylinder head chap and we've had a chat. His opinion is the exhaust valve guides are shot and that has promoted bad seating of the valves getting worse as more deposits are left. He is surprised at the amount of wear and wouldn't expect it at such a low mileage but engines are becoming a throw away part. He also said that it could simply be down to modern petrol and the additives such as ethanol taking their toll as engines aren't really designed for it.
He believes the valves should be fine but we need to compare them against new guides before a final decision is made.
Matt has said he should theoretically be able to get away with removing 0.005mm of metal from each surface to cut the seats and redress the valves so taking a total of 0.010 and after checking with Kawasaki we have just over 0.5mm-0.75mm to work with so hopefully we can get away with this. Lets hope it works. |
| sickpup |
 sickpup Old Timer
 Posted: 14:12 - 18 Sep 2015 Post subject: |
| kramdra |
 kramdra World Chat Champion
| sickpup |
 sickpup Old Timer
| kramdra |
| sickpup |
 sickpup Old Timer
| kramdra |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
The last post was made 10 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
