| System of a Clown |
 System of a Clown Two Stroke Sniffer
 Posted: 23:17 - 16 Sep 2015 Post subject: Turbo 2 stroke singles. |
Daft thought I know - well that's what I thought at first.
It has apparently been done according to a few YouTube vids.
Has anyone got any knowledge/experience of this sort of thing?
I've got a lot of forced induction experience but that's car stuff.
And no 'it can't be done' stuff!!
It has been done, I'd just like to know more and I love a challenge  |
| stevo as b4 |
| smegballs |
 smegballs World Chat Champion
 Posted: 06:33 - 17 Sep 2015 Post subject: |
Draw-through would be the easy way. No fancy plumbing or pitot tube tuning just bolt the carb to the turbo inlet and go. You don't need exhaust scavenging because that's for using the exhaust design to fill the chamber. Now you're pressurising the cases with a big pump so the chamber will be getting filled quite well enough.
Also:
1. Buy a big pile of spare engines and parts before you start.
2. Keep buying spare engines and parts. ____________________ a.k.a 'Geri'
 - Super Spammer
| bikenut |
 bikenut World Chat Champion
| stevo as b4 |
| Iain. |
 Iain. Could Be A Chat Bot
| jimspeed |
 jimspeed World Chat Champion
 Posted: 19:05 - 17 Sep 2015 Post subject: |
how do they lube the turbo?
I would think as others have said injection would be the way forward as jetting would be a nite mare, interesting project to play with tho.  ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| temeluchus |
| MarJay |
 MarJay But it's British!
 Posted: 20:01 - 17 Sep 2015 Post subject: |
I have a fair amount of experience with performance two strokes, having owned two strokes basically non stop since about 2005, and my first bike back in '99 was an NS125R.
First off, exhaust design is critical. This means that the turbo, instead of taking wasted energy and using it for more power, actually will more than likely rob power from the bike, because I doubt putting a turbine in the way of the pressure waves (which need to move freely through the expansion chamber) will allow for the perfect exhaust design. Changing the exhaust design by a small percentage can make a bike unrideable, so adding a turbine in the way is probably not going to do any good.
Secondly turbos work best with a constant flow of gas. So the moving pressure waves within the expansion chamber could even cause compressor stall, or a kind of 'burp' which will stall the turbo. This is pretty much as good as blocking the inlet altogether. You might be able to manage it on a multi with no expansion chambers, but then you'll more than likely lose more power than you'll gain from adding the turbo.
Thirdly, turbos require a constant supply of quality oil, warm from the engine. This is impractical on a two stroke.
Lastly, most if not all two strokes use the crank cases to pre compress the charge before it enters the cylinder. The mixture is already pre compressed, it doesn't need more compression. If you add too much compression to this mixture before it enters the crank case, the crank will have trouble compressing it further robbing some power again.
So I'm not going to say it's impossible but you can draw your own conclusions from that.
[edit] To add a caveat, you could probably do it if you designed the engine for forced induction from the outset, but bolting on a turbo to an existing bike will encounter the problems listed above. [edit] ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Major Doss |
 Major Doss Traffic Copper
 Posted: 02:00 - 18 Sep 2015 Post subject: |
Does a decent 2 stroke not rev up quick enough?
Bimota went bust trying 2TDI, so we'll suss it with turbo.. LOL.
How can you Force induction a cylinder that is designed to be open to 'breathe'?  |
| Major Doss |
| stevo as b4 |
 Posted: 18:38 - 18 Sep 2015 Post subject: |
It can and has worked, but it's understanding how is the bit that's really hard to grasp.
For a long time my biggest question/are of concern was sealing the inlet into the engine under boost. I therefore assumed that only a piston ported or rotary valved two stroke would be able to be turbocharged, as with a reed valve motor the charge air would never let the reeds close?
I don't think this is as much of a problem as I first thought now, especially when you think how quickly reeds open and close at high speed, and the fact that there's little time in the two stroke cycle for air to escape anyway.
The snowmobile and quad bike turbo builds I've seen do generally tend to keep an individual expansion chamber per cylinder, and then join the stingers together before making a turbo flange to fit the turbo post expansion chamber.
I imagine turbocharging a two stroke is a bit like turbocharging a tuned Honda VTEC car engine, in that in the case of the cars, theres a lot of valve overlap on the high lift cams, and some of the boosted air will just blow straight out of the exhaust. But in these set up's it still works very well and gives a big power gain.
I'm thinking on a stroker you will be blowing away a lot of the charge air, but you'd still have some left to fill the cylinder with that is probably more than you would have otherwise, hence getting power gains. It's this effect which is why I think that keeping the expansion chamber is used? I would bet that there's not a lot of boost generated but it's enough to give greater cylinder filling than you could achieve otherwise? |
 Posted: 19:18 - 18 Sep 2015 Post subject: |
The engine parts don't know or care what pressure the incoming air is at, what matters is pressure differential. If the airbox is at 1 bar absolute (normal atmospheric pressure) then the mixture will enter the cases at 1 bar and when the piston starts to come down the case pressure will increase to more than 1 bar, meaning you have a delta-p across the reeds (1 bar one side, more than 1 bar the other) and the reeds will close. If you are running half a bar of boost exactly the same thing happens except now you have 1.5bar one side and more than 1.5 bar the other. ____________________ a.k.a 'Geri'
| System of a Clown |
 Posted: 19:56 - 22 Sep 2015 Post subject: |
Loads of info/hints here
Cheers all!
I'm still looking into this, it's going to be a slow burning project, but I'm still up for it  |
| stevo as b4 |
 Posted: 20:12 - 22 Sep 2015 Post subject: |
Pete, so your saying if I understand correctly that if say pick a number 4psi? of charge air pressure is blowing in through the reeds from the boost generated by the turbo, that on the piston down stroke the pressure in the crank case will rise to a higher number say 4.5psi and then shut the reeds, and this how you'd still get your crankcase compression to occur and help to scavenge the cylinder when the piston falls to the point where the transfer ports start to open?
I'm still not sure on the ideal two stroke turbo exhaust and if it would be best to try and make the exhaust volume tiny before the turbine for fast response, or if a turbo after an expansion chamber can still produce a good effect, as the expansion chamber does increase exhaust pressure and bleed off gas through the small stinger pipe that must be several times smaller than the header pipe to work.
I'm thinking would the expansion chamber be a possible advantage on a single cylinder engine at least, as all that exhaust volume before the turbo would act as a reservoir, maybe a bit like a large plenum chamber before a set of carbs can, so that a balanced amount of air is available to draw on instead of pulses?
Or the ^ all horseshit?  |
 Posted: 20:37 - 22 Sep 2015 Post subject: |
Yes you have it - the reed system works the same at any (sensible) pressure. Not sure how much boost the main seals will cope with but I bet you couldn't raise it far enough to pop them. Seal wear might become an issue.
Turbo after the expansion chamber does work. That's how the Buddfab setup was done.
https://i24.photobucket.com/albums/c5/pixelr0x/turbomotor.jpg ____________________ a.k.a 'Geri'
| mentalboy |
 mentalboy World Chat Champion
| mysterious_rider |
 mysterious_rider World Chat Champion
| System of a Clown |
| Vincent |
 Vincent Banned
The last post was made 10 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
