Air rifle scopes
PostPosted: 13:47 - 19 Sep 2015    Post subject: Air rifle scopes Reply with quote
i bought a Gamo .22 air rifle with scope a while back. It's ok, but I find the scope hard to use as in small field of view and difficulty seeing clearly.
Ok, it's probably me but what scope would you shooting people recommend for my gun. 11mm mount.
Laser dot so I can feel like an American sniper and actually hit anything? Embarassed
Nothing too expensive as its only a bit of fun reducing the local rat population.
The sights I have are 4x32 and came with the gun. Gamo's own.
https://www.google.co.uk/search?q=gamo%20varmint%20stalker%20barricade&newwindow=1&gws_rd=ssl
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
Andy_Pagin
PostPosted: 14:03 - 19 Sep 2015    Post subject: Reply with quote
Back in my field-target air rifle shooting days I used a Tasco 4-9 * 50 parallax adjustable scope. I won a fair number of trophies so they can't be too bad. Not expensive either.
Ichy
PostPosted: 14:39 - 19 Sep 2015    Post subject: Reply with quote
Tasco are not what they used to be.
Nikko Stirling Mountmaster are a good budget scope for £20-£30.
Hawke are, in my opinion, better but about a tenner more.
pepperami
PostPosted: 17:28 - 19 Sep 2015    Post subject: Reply with quote
Jewlio Iglesias wrote:
Nikko Sterling do decent quality scopes, and not wholly expensive prices.
This^
Joncrete Cungle
PostPosted: 17:37 - 19 Sep 2015    Post subject: Reply with quote
Nikko Sterling or Simmons. Try Airgunbbs / Airgun forum etc for second hand ones.
defblade
PostPosted: 10:18 - 20 Sep 2015    Post subject: Reply with quote
If you're ratting, it's probably at fairly short range, in poor light. So you'll likely need a scope that will focus down to 10 yards or less and has the biggest front lens you can find, given the focus requirement.
Or make yourself a nightsight for about £35 - it does feel like cheating, though Wink
MCN
PostPosted: 13:26 - 20 Sep 2015    Post subject: Reply with quote
It is the same as telescopes and binoculars.
It depends on your age. Shocked
Pupil Dilation affects how the amount of light your eyes can see.
The older you are the less you pupil can dilate.
https://www.cruxis.com/scope/limitingmagnitude.htm
Blackwolf
Burgerfist
PostPosted: 16:30 - 20 Sep 2015    Post subject: Reply with quote
Agree. Quite good scopes.
MCN
PostPosted: 20:02 - 20 Sep 2015    Post subject: Re: Air rifle scopes Reply with quote
Hoolyoh and Black spaniel don't know noffing.
https://en.wikipedia.org/wiki/Exit_pupil
If you have bother seeing stuff through a telescope it may be the telescope magnification is no good for your eye's physical abilities.
If you read how lens systems work you may understand what it means.
But if you have potato eyes you will be blind to the facts.
pepperami
PostPosted: 20:10 - 20 Sep 2015    Post subject: Reply with quote
The older you are the less your pupils can dilate.
This is correct^.......... all my scopes are now 3-9 x 50 to get the extra light.
Also the higher the magnification, the harder it is to eliminate crosshair wobble.
just my Penny Coin Penny Coin Thumbs Up
MCN : fixed for you
MCN
PostPosted: 21:11 - 20 Sep 2015    Post subject: Reply with quote
MCN : fixed for you
But Hoolio and BlackSpaniel cannot 'see' the light. Smile
PostPosted: 23:47 - 20 Sep 2015    Post subject: Reply with quote
People have also mentioned the paralax.
If it's set too far away (and many scopes are set up for use with rifles, not air rifles), you will have difficulty focusing on the target and reticule. Almost certainly an issue with any over the counter sight at ratting ranges.
I believe it can be reset.
However, I'd be rocking either traditional open sights or a reflex sight for ratting.
Reflex sights are used with both eyes open for maximum light. They are also very quick to align on target. Intuative. Feels like you're using a laser sight but the red dot is actually being shone back into your eye with a focus correction so it appears to be on the target. Like a head-up-display. It's all very top-gun but great for ratting. Also cheap.
temeluchus
PostPosted: 05:23 - 21 Sep 2015    Post subject: Reply with quote
I always liked the Tasco/simmons 1.5-5x20 scope for air rifles as it covers all likely airgun magnification needs and is more all round useful than a red dot or irons.
This thing seems similar.
https://www.uttings.co.uk/p117282-bsa-advanced-1-4x24-ir-g430-rifle-scope-30mm-532-ad1424irg430/#.Vf-GLPlVhBc
Hetzer
PostPosted: 11:53 - 21 Sep 2015    Post subject: Reply with quote
Use a reflex for ratting. A scope on a legal-power rifle is pretty much a waste of money when you consider the relatively small zone over which it's accurate.
recman
PostPosted: 20:57 - 21 Sep 2015    Post subject: Reply with quote
You set your own approximate parallax by loosely fitting the scope on the rifle's dovetail rails, placing your cheek on the cheek piece of the stock then sliding the scope until you're happy.
I always shoot with both eyes open when using scopes.
You just prioritise your vision to the eye looking through the scope.
pepperami
PostPosted: 14:12 - 22 Sep 2015    Post subject: Reply with quote
that is not correct, moving the scope on the rail until it suits your own particular vision is called eye-relief .
That is the distance between the rear lens/bell and your eye.
If that bell is to far or to near, your wont get a focused picture .
Parallax is the range/distance that objects stay in focus.
For example on a good scope, you will be able to look through it and see objects that are at different distances away, but both are still in focus.
ie the target 35 yards away and the post 20 yards away.
What you get is a bigger/rounder picture and not a flat image that will have blurry bits in it.
This is more of an issue the higher the magnification or the longer the distance you are looking.
recman
PostPosted: 15:06 - 22 Sep 2015    Post subject: Reply with quote
Sorry, my mistake. Embarassed
Eye relief adjustment is what I described, you are quite correct.
MCN
PostPosted: 16:22 - 22 Sep 2015    Post subject: Reply with quote
That is Depth of Field. Which is the range of a lens system where the object remains 'in focus'. Anything in front of or behind that range is blurred.
Parallax is where the object in focus can appear to be in different positions depending on the point it is viewed from.
I think I became Parallaxed on Friday night from too many sherbets.
pepperami
PostPosted: 18:33 - 22 Sep 2015    Post subject: Reply with quote
Hmmm? ok?
However with telescopic sights, your point of focus will always be the centre of the crosshairs, and parallax will/can/does affect your depth of field/quality of image/crispness of focus.
quote[\I think I became Parallaxed on Friday night from too many sherbets./]
Sad Fat chance of that happening here Evil or Very Mad
PostPosted: 19:14 - 22 Sep 2015    Post subject: Reply with quote
Isn't parallax what you get when you dip a stick in water and it seems to bend?
recman
PostPosted: 20:49 - 22 Sep 2015    Post subject: Reply with quote
Light refraction, endless fun.
Matt B
PostPosted: 10:14 - 23 Sep 2015    Post subject: Reply with quote
Have you been into Willards in New Bradwell? Found them to be pretty switched on.
Last time I was in there he had a decent range of scopes. Would at least give you the chance to look at a few even if you don't buy.
PostPosted: 18:04 - 10 Oct 2015    Post subject: Reply with quote
Just finished a days ratting and bunny potting with the scope I got off recman. Excellent scope, a Hawke Sport HD 3-9x4, and easier for my eyes than the one I had before. Thumbs Up
The last post was made 10 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 135.48 Kb
