Cleaning products for engine & metal
primalcarl
PostPosted: 22:46 - 23 Sep 2015    Post subject: Cleaning products for engine & metal Reply with quote
The engine on my bike is looking a bit grime and the metal is looking a little weathered as if some winters have taken their toll. Are there any good products for for cleaning oil and grime from engines, other than degreaser? I would like to make all metal areas look a bit fresher too.
UrbanRacer
PostPosted: 22:55 - 23 Sep 2015    Post subject: Re: Cleaning products for engine & metal Reply with quote
Remove engine, strip it bare and shot blast it. then repaint it in your favourite colours.
MCN
PostPosted: 23:49 - 23 Sep 2015    Post subject: Re: Cleaning products for engine & metal Reply with quote
Liam_ wrote:
This ^^^
Oil and Grime will come off using 'degreasers' because they are grease and oil. Brake clear is good too but more expensive and hazardous to skin some plastics, paints and very flammable.
stevo as b4
PostPosted: 17:59 - 24 Sep 2015    Post subject: Reply with quote
If the problem is not oil/gunge/greasy stuff, but more a case of discoloured and corroded engine casings, then a harsh but very effective way of cleaning the aluminium parts is with strong acidic alloy wheel cleaner.
Not cheap Simoniz stuff, but stuff for proper cleaning (often has warnings on the bottle of being harmful to paint and lacquered surfaces). Something a touch closer to driveway block paving acid cleaner, but not as strong as that obviously.
It's worked for me before, and when your fully PPE'd id brush it on with a stiff brush and leave it fizzing for 1-2min tops, before hosing it down well with cold water.
Sure it's a risk, but I've seen crank cases cleaned up this way to near new condition, without the need for vapour bead blasting which is how you'd normally get them that clean.
MCN
PostPosted: 18:13 - 24 Sep 2015    Post subject: Reply with quote
This ^^^
Cement Cleaner. (Muriatic Acid, about a fiver a gallon) will clean the shit off anything. It is also good for cleaning cement off stuff too apparently. Smile
Not good to get on stuff you don't want to clean like skin, eyes.
If you get it clean as you can you can then get heat resistant clear lacquer or even heat resistant paint to protect the cleaned alloy.
Alloy stops corroding due to the layer of oxide on the surface. If you remove this layer it will oxidise again in contact with air.
Painting it protects the surface from contact with air.
Most 'modern' alloy parts are painted. Some decorative parts are polished and then lacquered. Cheaper stuff is painted but not very well/thick.
primalcarl
PostPosted: 19:54 - 28 Sep 2015    Post subject: Reply with quote
God damn it!
I used the Autoglym Engine cleaner today and a lot of the paint has flaked off the engine. It might've be close to coming off anyway, but think the Autoglym stuff certainly helped it.
It's not massively noticeable, but a little shabby. Might be time for a new thread....'painting engine'!
The last post was made 10 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 60.41 Kb
