Stripping a "proper" rusty engine
mudcow007
PostPosted: 08:57 - 24 Sep 2015    Post subject: Stripping a "proper" rusty engine Reply with quote
Was having a look at the bike I was given last night, it's a DT175MX that has been left on its side for about 8 years Shocked
removed the engine which is currently sat complete* in a plastic storage box.
Now every single fastener & bolt is rusted to shit, the engine will need a complete strip down. To make things easier on my self coudl i leave the engine soaking in something to hopefully make it easier to strip?
was thinking of something like diesel or kerosene, something that wont evaporate away quickly etc
*not really complete, the cover off the clutch side was left off so fly wheel etc is seized solid
c_dug
PostPosted: 09:37 - 24 Sep 2015    Post subject: Reply with quote
I tend to use plus-gas for any small local uses, and diesel for lager or longer term soaking.
bikenut
PostPosted: 10:36 - 24 Sep 2015    Post subject: rusty engine Reply with quote
https://i1098.photobucket.com/albums/g379/billb0baggins/Mobile%20Uploads/temporary_47.jpg
is it this, one??
nuts about bikes
bikenut
PostPosted: 10:42 - 24 Sep 2015    Post subject: rusty engine Reply with quote
clean as best as possible, remove flywheel and stator as best as possible, get metal container large enough to place engine in and immerse in old engine oil, allow to soak, then apply some heat, fizzing will indicate action ( oxygen coming out of the corrosion ?? ), allow to cool, clean off old oil, an start to strip repeatedly saying" please god" etc etc etc ....take your time and enjoy.
remember hair ( pulling your hair out is counter productive lol ) and tortouise, if a stuck item moves even one minute, it will come free if you are patient.
nuts about bikes
mudcow007
PostPosted: 11:12 - 24 Sep 2015    Post subject: Reply with quote
is it this, one??
mine makes that look showroom condition Shocked
cool thanks will have a go.
It might just come down to me playing with a 2 stroke engine an then scrap the lot Sad
PostPosted: 11:28 - 24 Sep 2015    Post subject: Reply with quote
If the intent is to strip the whole thing down to the cranks, put the whole thing in a bucket of diesel and forget about it for a week.
Robby
Dirty Old Man
PostPosted: 13:05 - 24 Sep 2015    Post subject: Reply with quote
You may find that the bolts will still come out with just a bit of penetrating oil. If a bolt is done up tight, water isn't going to get down into the thread. WD40 isn't going to either. Penetrating oil will.
I would give each bolt a squirt of penetrating oil and then try to remove it. Don't try too hard - if it's stuck, leave it and come back to it.
The diesel trick would probably work, but you'd need a fair bit of diesel.
If the bolts are in ok condition apart from the rust, clean them up in an electrolysis bath. Instead of rigging a single wire to each bolt, put them all in a metal sieve or colander and run your negative wire to that. Run your sacrificial anode above the colander on the positive lead, and submerge the whole lot in water with some washing powder.
PostPosted: 15:35 - 24 Sep 2015    Post subject: Reply with quote
50:50 ATF and paraffin makes a good homemade penetrating oil.
mudcow007
PostPosted: 16:03 - 24 Sep 2015    Post subject: Reply with quote
would kerosene work? i have oodles of that (fuel for boilers at work)
PostPosted: 16:19 - 24 Sep 2015    Post subject: Reply with quote
I reckon it would. Not a world of difference, they are both light oils. Usually more expensive which is why I suggested diesel.
mudcow007
PostPosted: 16:26 - 24 Sep 2015    Post subject: Reply with quote
cheers all, pics to follow of truly crustified (if thats not a word it should be) engine to follow
will get a few litres of kerosene an see how we go, im not in a rush to get it done so could just leave it soaking for a few weeks
Ed Case
PostPosted: 20:21 - 24 Sep 2015    Post subject: Reply with quote
You're doing a great job but b'Jasus that motors in a right state.
mudcow007
PostPosted: 20:26 - 24 Sep 2015    Post subject: Reply with quote
link to show an tell pics
its not pretty
mentalboy
PostPosted: 21:28 - 24 Sep 2015    Post subject: Reply with quote
Do the above before you go any further or you may well end up busting something unnecessarily.
Ariel Badger
PostPosted: 00:04 - 25 Sep 2015    Post subject: Reply with quote
Get a punch and hammer and give every screw a hard whack before trying to remove them. oil and diesel as well.
bikenut
PostPosted: 11:37 - 25 Sep 2015    Post subject: engine Reply with quote
yeah right, weigh it in and get another one off e bay......and when there's none left on the planet, wtf do you do then eh !??
the skills and knowledge you will learn stripping this engine will help you in later life. :karma:
nuts about bikes
mentalboy
PostPosted: 14:22 - 25 Sep 2015    Post subject: Re: engine Reply with quote
the skills and knowledge you will learn stripping this engine will help you in later life. Karma
I'm sorry if I'm offtopic (not the only one Rolling Eyes ) but why can't you save inane banter for the Random Banter section of the forum?
Random offtopic posts in the Workshop section are one of the reasons I tend to limit posting in this part of the forum.
Which is a shame for noobs because I split my first engine back in 1981 and have over 30 years experience playing with motorcycles (and cars, small engines, heavy plant, etc, etc.) and could contribute far more.
I hasten to add that I'm not alone in having many years practical experience on this forum but I have noticed n my short time here that the number of knowledgeable hands is shouted down by increasingly greater numbers with what can be best described as people spouting bullshit for no other reason than they can.
Rtwo
PostPosted: 16:38 - 25 Sep 2015    Post subject: Reply with quote
Get yourself an old-style (whack it with a hammer) impact driver
mudcow007
PostPosted: 20:05 - 25 Sep 2015    Post subject: Reply with quote
update
its currently "taking a bath" in kerosene mixed with ATF (because i had some)
an now i absolutely stink
MCN
PostPosted: 00:15 - 26 Sep 2015    Post subject: Reply with quote
I don't know soaking it in oil will help much. It is soaked with oil from the inside and that doesn't loosen bolts.
A small blow torch to apply very localised heat the the fasteners will be much more productive. You will only need to work that magic on any that seem too tight to budge.
The last post was made 10 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 106.04 Kb
