Piaggio Nrg Wont Start
djjohnjones
PostPosted: 18:02 - 24 Sep 2015    Post subject: Piaggio Nrg Wont Start Reply with quote
I am trying to get my scooter to work when Then engine has just been rebuilt and has never actually been running with the rebuild. I try and start it it wont start the starter motor goes and tries to start the bike. The bike will sometimes start to light up and the rev kicking in then instantly go out as if its trying to start. I know fuel is getting to the card i am however not sure about oil getting to the carb even know it is going to the pump. (I know the pump works) What could be the problem please help
Pol Anorl Fam This post is not being displayed because the poster is banned. Unhide this post / all posts.
djjohnjones
PostPosted: 19:13 - 24 Sep 2015    Post subject: Reply with quote
Can i tell that by taking the spark plug out and seeing if the dark bit has petrol on it
Just_James
PostPosted: 19:34 - 24 Sep 2015    Post subject: Reply with quote
After trying to start it, just remove the plug and see if it is wet at the tip. If it is wet then it would suggest you're getting fuel through but possibly not getting a good enough spark.
While the plug is out, clip it back onto the HT lead (the bit that plugs on the top of it) and then rest the metal base of the spark plug on top of the cylinder head, then press the starter button while watching the tip of the spark plug and see how the spark looks. It should be a good consistent blue spark.
Do those little tests first then report back.
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
djjohnjones
PostPosted: 19:52 - 24 Sep 2015    Post subject: Reply with quote
I shall have a look tomorrow i know the spark plug is new and the cdi works as i have used them just recently on another piaggio
djjohnjones
PostPosted: 20:13 - 24 Sep 2015    Post subject: Reply with quote
Hello i just popped in to my garage and removed the plug. The spark Plug wet when i removed it i didnt get chance to see if it has a good spark but it is only a month old and has been used on a running bike so it should have a good spark
Just_James
PostPosted: 20:46 - 24 Sep 2015    Post subject: Reply with quote
The plug and/or cdi being fine on another bike doesn't necessarily mean you'll have a good spark on this one, there are other factors that come into play.
Check your spark first and if you're confident it looks good then you can move on to checking for fueling issues.
djjohnjones
PostPosted: 14:44 - 25 Sep 2015    Post subject: Reply with quote
Hi just checked the spark it was sort of blue then i gave it a quick clean and it gave a nice blue spark
djjohnjones
PostPosted: 17:42 - 26 Sep 2015    Post subject: Reply with quote
Is it possible that if my stator was damaged it would stop the bike from starting
Nobby the Bastard
Harley Gaydar
PostPosted: 17:46 - 26 Sep 2015    Post subject: Reply with quote
Not if you have sparks.
Triumph Sprint ST 1050
Val
PostPosted: 17:49 - 26 Sep 2015    Post subject: Re: Piaggio Nrg Wont Start Reply with quote
When you say goes how long? Have you charged the battery well?
If the starter spins long enough and you have spark, you probably have fuel supply issue.
Try some starting fluid to check that the bike can start. If it starts with starting fluid, but does not start without it that will mean fuel is either old and bad or no good supply.
djjohnjones
PostPosted: 21:39 - 28 Sep 2015    Post subject: Reply with quote
Sounds stupid but i dont have any starter fluid but im not sure if it is fuel starvation as i sprayed wd40 in to where the piston is and nothing happened (Read somewhere you could use WD40 instead of wd40)
Ariel Badger
PostPosted: 22:00 - 28 Sep 2015    Post subject: Reply with quote
Do not squirt WD40 into engines.
Just_James
PostPosted: 22:55 - 28 Sep 2015    Post subject: Reply with quote
Eh?
Don't spray anymore WD40 or wd40 into your engine!
That aside, if you're confident your spark is good and the plug is getting wet ooh matron then it seems (assuming the plug isn't wet from WD or similar) there is likely a fueling issue.
Has it been running previously while you've had it and when was the last time?
How old is the fuel in the tank? Could it be stale and / or contaminated?
Have any adjustments been made to the carb'?
djjohnjones
PostPosted: 01:10 - 29 Sep 2015    Post subject: Reply with quote
Hello thanks for all the help im a newbie just listening to peoples advice its a new built engine the fuel is not that old. I think the carb works i have an AC (Air Cooled) Carb that i know works can i try this on the bike there for the same bikes but the difference is how they warm up on is LC and the other uses a Heater.
djjohnjones
PostPosted: 19:20 - 29 Sep 2015    Post subject: Reply with quote
Hello i swapped the carbs over and still wont star but this time i now have no spark i am sure it is something to do with the alternator/stator
djjohnjones
PostPosted: 18:15 - 02 Oct 2015    Post subject: Reply with quote
Hello the tool for the flywheel removal was the wrong one so got to get them to send right one out. I used starter fluid today and it was still turning and the odd time it would try to start for half a second if that any advice
Nobby the Bastard
Harley Gaydar
PostPosted: 18:45 - 02 Oct 2015    Post subject: Reply with quote
1) Push it two miles from your house.
2) Pull out mobile phone
3) Pull out RAC card
4) use one to call the other
5) ......
6) win!
djjohnjones
PostPosted: 02:08 - 03 Oct 2015    Post subject: Reply with quote
Is it possible the timing is out
mentalboy
PostPosted: 09:25 - 03 Oct 2015    Post subject: Reply with quote
I'll bite Rolling Eyes
Who rebuilt this engine of yours, presumably you mean it was opened up all the way to the crank?
For what reason was it rebuilt?
(When you say it's a 50cc do you mean it's still a 50cc or has it now got a 70cc big bore kit in it?)
When was the bike last running?
How old is the battery?
How long can you hit the starter button before the battery slows up?
What reading does your multimeter say the battery is at before you start cranking away?
Read, digest and try to answer that lot before posing more questions or ripping bits out of the bike
djjohnjones
PostPosted: 10:36 - 03 Oct 2015    Post subject: Reply with quote
Hello a family member rebuilt the engine as the people we got it off said it was seized and the main bearing collapsed. Unfortunately i dont speak to him no longer. the battery lasts for around 5 mins. The battery is around a year old. and it was only rebuilt because it seized and just has a standard 50cc kit on it
The last post was made 10 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.71 - MySQL Queries: 13 - Page Size: 108.25 Kb
