Bike stalling when downshifting
jetblast787
PostPosted: 23:22 - 24 Sep 2015    Post subject: Bike stalling when downshifting Reply with quote
Hello all!
I'm a new biker (just passed the 100 mile mark today!) on a 2009 CBF 125. While slowing down to a stop when downshifting, my engine occasionally stalls before stopping. It doesn't seem like time of day or cold or hot engine makes a difference to the stall, except for when downshifting.
I am a new rider, but I always hold the clutch in when downshifting, but it seems like when pulling off the throttle and holding the clutch, I feel the engines rev getting dangerously low all the time when riding, occasionally leading to a stall.
I've adjusted the throttle idle, but after initial tinkering, it doesn't seem that the idle stays high, but goes to its pre-tinkering state.
Anyone know how I can stop my bike from stalling when coming to a stop? It feels a little dangerous because I'm forced to focus on keeping the throttle slightly open while negotiating the road and working the gears.
Thanks!
Ariel Badger
PostPosted: 23:45 - 24 Sep 2015    Post subject: Reply with quote
I think you are being over cautious in your riding and knocking down the gears too early.
jetblast787
PostPosted: 23:52 - 24 Sep 2015    Post subject: Reply with quote
You are correct in that assumption. Is it better to come to a stop then downshift or should I be downshifting at lower speeds?
Ariel Badger
PostPosted: 23:58 - 24 Sep 2015    Post subject: Reply with quote
Keep on down shifting and keep the revs up.
Teflon-Mike
tl;dr
PostPosted: 09:06 - 25 Sep 2015    Post subject: Reply with quote
Hobby-Horse time; but very common Newbie habit, especially with riders coming from cars, is to short-shift, and not use the engine revs. Result is, you deny yourself engine response to change speed easily, and make more work, and trouble for yourself, making too many unnecessary up-shifts, that then beg too many unnecessary down-shifts, making your whole ride, harder, less 'smooth' and less finesses... while chucking up little anomalies like this, or jerky changes or un-charged batteries, that pop up as symptoms here in work-shop, when they come looking for something to do to the bike, to fix the problem, rather than the rider...
Your bike, has a rev range that extends from about 1,200rpm tick-over, to about 11,000 rpm, just beyond the red-line. Peak torque, the point n the rev range that the engine is working at it's most 'optimal' is probably about 9,000 rpm, with peak power, probably around 10,000rpm.....
BUT, it's a small, air-cooled single, in an 'unfaired' commuter style bike; so, there's water-jacket, or body-work to shield you from the noises it makes, and being a single, it only makes one bang' every other crank rev, it's not very 'smooth' so sounds more strained than it really is, and in consequence, (and compared t car engines) 'thrashed' if you use more than about half the rev's t has... so many newbies don't... and short shift before 3Krevs, and rarely exceed 6K....
But, first gear, will take you from rest, to perhaps 30mph, 2nd. from 20, to about 40, third from abut 25 to 50.... forth, will take you from about 30mph, to around 60, and you only ever really need 5th, when you are on a 50+mph road, with little likelihood of needing to change speed, so a more open A-Road or duel-carriageway, when you use t to knock the revs back for more relaxed cruising and maybe eek a couple of extra points of speed out of the top end, if you are really determined to max it out....
What are my odds, f I bet a quid you are using 5th, quite a lot more often, and at speeds as low as 30?
This would put you at least three gears higher than you need be, when you start slowing for junctions.. most likely on 20/30mph limit roads.. where, there's no real need for you to be in a gear higher than third, and IF you were in 3rd, slowing down, you would only have to make ONE down-shift, after rolling off the throttle, and loosing 10mph of that as the revs drop.. WITHOUT them dropping so low it 'feels' like it's going to stall.. like it would if you were in 4th or 5th, at bugger all above tick-over before you roll off the throttle, where yeah! Apply the brakes, to try slowing down, with the engine driving the back wheel, clutch engaged, it WILL try and make the motor go lower than its 'stall-speed', wont it! Which is why you are haling in the clutch... and more than likely, trying to crash down three gears in one go, without letting the clutch out between...
Don't shift up, you don't need to shift down! Use the revs, you can slow down On the throttle, NOT the gears, and you can do it without risking the motor stalling, AND you can do it all 'under drive' rather than "coasting", where you DON'T have the same degree of control over the bike.. and with the clutch 'out', and making only one distnict shift at a time, clutch loading and turning the shafts n the box between shifts, givig the cogs a change to line themselves up, you'll make smoother, slicker, more possitive chages on those fewer occassions you DO need to make a shift.
Try it - I'll lay the winnings of that quid I bet earlier, your 'tickover' problem goes away without a single screwdriver being twiddled"!
pompousporcup...
PostPosted: 09:33 - 25 Sep 2015    Post subject: Reply with quote
what ^^ he said. I used 4th and 5th whilst doing 30/40 mph for a month or so thinking it would be more ecomonic but in fact it just labours the engine and means more shifting with left foot which becomes tiresome on a commute.. also means you have less to think about if you're not shifting so many gears coming up to junctions/negotiating idiots etc etc. only one click and you're back in decent revs to get you up to speed Thumbs Up
pompousporcup...
PostPosted: 09:34 - 25 Sep 2015    Post subject: Reply with quote
one thought.. if you turn the idle screw.. does the idle speed actually change? and stay changed? ie, turn the idle speed up, do the revs stay up or do they settle back down to what they were before?
PostPosted: 10:40 - 25 Sep 2015    Post subject: Reply with quote
Reading what OP has actually written, I'd also check the clutch cable tension.
There should be just the merest sliver of slack at the lever before the tension comes on.
Too tight and you'll be slipping the clutch inadvertently while riding.
Too slack (which is what I'd suspect) and it might not be disengaging fully.
jetblast787
PostPosted: 14:36 - 05 Oct 2015    Post subject: Reply with quote
Thanks for the replies guys; I've ridden it for another 2 weeks and during this time I've noticed that this only happens when the engine is cold, so after about 3 stop starts at lights it doesn't stall anymore. Anyone know what this may be?
PostPosted: 15:01 - 05 Oct 2015    Post subject: Reply with quote
What RPM does it idle at? I'd consider raising it 100/200
jetblast787
PostPosted: 15:32 - 05 Oct 2015    Post subject: Reply with quote
I don't know the rpm value as the bike doesn't have a meter, however idle sounds good. Its only when downshifting to first I hear the rpm drop dangerously low which occasionally stalls the bike when cold.
PostPosted: 16:41 - 05 Oct 2015    Post subject: Reply with quote
Try raising it slightly see if it still cuts out.
jetblast787
PostPosted: 17:57 - 05 Oct 2015    Post subject: Reply with quote
I have tried that as well using the idle throttle screw, but it hasn't helped unfortunately. Also slightly above the throttle adjuster there is another screw that adjusts the cable (I think?) attached to the handlebar. I don't see a way of securing it properly but it must be an adjuster of some sort as the screw doesn't screw onto something and is loose (i.e. not hanging out but easily moves only if touched).
Either way I've adjusted both to a slightly higher idle, but it does go back to the same as before. I did this about a week and a half ago and have since ridden about 150 miles total.
Robby
Dirty Old Man
PostPosted: 18:55 - 05 Oct 2015    Post subject: Reply with quote
How many miles on the bike?
From memory, CBF125s from around that time had an issue with fuel pumps. The best explanation that I heard was fuel dissolving some kind of protective coating on the inside of the tank (or maybe just paint) and fucking the pump. A replacement pump fixed it - the stuff that killed the pump was long gone by the time the pump failed - but Honda never issued a recall.
If your bike is low mileage, it is possible that the fuel pump is the original and knackered. It could also just be the way you're riding it. It's a 125, more revs, less mechanical sympathy.
jetblast787
PostPosted: 19:52 - 05 Oct 2015    Post subject: Reply with quote
I've heard that only applies to post '10 models, my bike is a early '09 model.
Although saying that, I did notice on Saturday that when the fuel level was low, engine performance seemed degraded, but after I refueled it significantly increased engine power. However your suggestion still doesn't explain why the engine stalls when cold in the first 5 mins of riding as the engine works fine in those 5 mins when riding at a constant speed or when pulling away.
Ariel Badger
PostPosted: 22:06 - 05 Oct 2015    Post subject: Reply with quote
Do not fiddle with the mixture screw.
It only affects running at tick over and your revs do not drop to tick over when down shifting.
PostPosted: 15:23 - 06 Oct 2015    Post subject: Reply with quote
Depends how you do it. A lot of new riders clutch in and go down the box which can lead to the bike stalling.
jetblast787
PostPosted: 15:33 - 07 Oct 2015    Post subject: Reply with quote
[quote="chris-red"]
Wait, aren't you supposed to hold the clutch while going down the gears? Surely you'll need to disengage the clutch before lowering the revs?
PostPosted: 17:05 - 07 Oct 2015    Post subject: Reply with quote
Say you are coming to a stop, you shouldn't just hold the clutch in and go down all the gears in one go, firstly it's good practice to use engine breaking. Second it can stall the bike.
The last post was made 10 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 107.46 Kb
