CB-1RR
Iain.
PostPosted: 10:13 - 25 Sep 2015    Post subject: CB-1RR Reply with quote
New little project.
My CB-1 broke down...
https://i.imgur.com/txFrG3Ql.jpg
Upon stripdown, seemed I'd done quite a good job on the engine. Extensive damage to the head, barrels, crank, pistons, and a lot of metal circulated.
https://i.imgur.com/LtxuTzVl.jpg
https://i.imgur.com/yX2HK5ll.jpg
https://i.imgur.com/Azz1HhGl.jpg
https://i.imgur.com/0opinDgl.jpg
Talking to a few freinds, one happened to have a CBR400RR trackbike that'd been up the road. We figured as the cams are sometimes used to power up a CB-1 the engines just might be interchangeable. So, we dug it out of the hedge it'd been in for the last six years...
https://i.imgur.com/SQe8CYQl.jpg
Dragged it back to the garage;
https://i.imgur.com/fRd8A0al.jpg
And gutted it;
https://i.imgur.com/47przYLl.jpg
https://i.imgur.com/bSGJQK2l.jpg
Old engine was pulled out of the CB-1
https://i.imgur.com/vzMyo1cl.jpg
CBR by this point wasn't looking so great. It really was ruined.
https://i.imgur.com/D0fenXTll.jpg
We then offered the engine up to the CB-1 and found two of four mounts fitted perfectly!
https://i.imgur.com/evLulqOl.jpg
Then I realised the CDI plugs were different, as were the carb spacings and half the loom plugs. Stripped the CBR of its loom.
CB-1 loom does the lights and charging & idiot lights. CBR loom does the spark & rev counter. Had to bypass the neutral switch to make it fire.
https://i.imgur.com/yemyylul.jpg
https://i.imgur.com/SDm4Tz4l.jpg
https://i.imgur.com/CeaQGaSl.jpg
Fabrication of the front mount started whilst I got on with removing the various things living in the carburettors from the CBR.
https://i.imgur.com/mwM748vl.jpg
Popped the carbs on, added a little fuel and it fired right up!
https://i.imgur.com/Asvm9OLl.jpg
Hoping to have this rideable by the weekend. Mr. Green
RhynoCZ
PostPosted: 11:15 - 25 Sep 2015    Post subject: Reply with quote
It's cool to see you've decided to do it. Thumbs Up Smile
Are you gonna use the CBR front end? I know I'd try to. Smile
PostPosted: 12:25 - 25 Sep 2015    Post subject: Reply with quote
no airbox, just trumpets plz.
instigator.
PostPosted: 15:14 - 25 Sep 2015    Post subject: Reply with quote
I love these wee CB-1's. At what mileage did your engine go? They're known for being quite reliable, no? I want another one now. Crying or Very sad
Iain.
PostPosted: 15:26 - 25 Sep 2015    Post subject: Reply with quote
At a later date i'll refurb the front end and I intend to try and fit the swingarm as it's a rather nice braced item. Forks look to be the same diameter so I think I can make them work, means double discs. Make for a decent chassis upgrade package anyway, but need to make it work first.
In answer to mileage? It had 10k in 2006,7,8,9,10 where it jumped to 64k and hasnt changed till present but has been MOT'd each year. Could be anything Laughing
We've tracked down some aftermarket headers...Hansei? They've been tweaked to fit.
https://i.imgur.com/IqgzVEV.jpg
The carbs barely clear the tank even after attacking it with a hammer so I have the trumpets & an open sponge filter on top of those. See how it fuels on road test and go from there.
https://i.imgur.com/ljH1sj9.jpg
Tank fits though
https://i.imgur.com/0xuuGZW.jpg
Feeling fairly positive at the moment, need to finish the frame and get the radiator brackets made before I can actually run it up and try to get the thing adjusted & idling nicely.
PostPosted: 16:29 - 25 Sep 2015    Post subject: Reply with quote
Dat air filter Laughing
SQL
PostPosted: 16:43 - 25 Sep 2015    Post subject: Reply with quote
best air filter ever
RhynoCZ
PostPosted: 16:44 - 25 Sep 2015    Post subject: Reply with quote
Yes, very reliable, never had a problem, always pushed it to the limit. I'd have one, right away. Thumbs Up
The only flaws/features I did not like, was the engine temp (fan ran a lot - everything was working alright), the MPG and having about 15hp less, than I'd want from it. Always the need to push it really hard to keep up with others, which means oil being sprayed into the airbox, BUT it did not eat a dcl of oil. I only lost about 0.05L per season and all that was the spray into the airbox, due to reving it like a mental person all the time. Well, and the stator burned, but that was an easy and cheap fix.
It's funny, I used to say, if the CB-1 had the RR engine, it'd have been perfect. Having just a bit more power, not much. Razz
What was cool about the bike, you could get out of a corner at 2nd speed, and rev it up to the top at all gears, yet doing only about 100 mph. The bike felt quick, yet it was slow, which is a good thing on the open road. You are having fun plus you're being safe at the same time. I also liked the OEM exhaust system, very nice and decent sound. The bike before the CB-1 I had had a fully open exhaust (just pipes) so it was nice to not wear earplugs on a bike again. Thumbs Up
Billing
PostPosted: 11:47 - 26 Sep 2015    Post subject: Reply with quote
If the forks are different lengths just swap the lowers, I have NC30 lowers on NC23 uppers and guts, meant I could bin the 2 pot sliding calipers and use the 4 pots from my old '30
Fladdem
PostPosted: 09:08 - 27 Sep 2015    Post subject: Reply with quote
Nice screen Iain! Thumbs Up
I like that idea a lot, I would have thought it would have fallen straight in as well, but doesn't look like it takes too much effort.
My super four has 82K on the clock and feels as sweet as a sweet thing, but has been well looked after, maybe yours hasn't...
I feel like mine could do with about 10 more horses and stiffer suspension up front, brakes are ace, and everything else is ace! Laughing
qarka
PostPosted: 19:56 - 28 Sep 2015    Post subject: Reply with quote
CB400 superfour and CB-1 are quite different beasts no?
qarka
PostPosted: 19:57 - 28 Sep 2015    Post subject: Reply with quote
Wicked project btw! Thumbs Up
Fladdem
PostPosted: 21:51 - 28 Sep 2015    Post subject: Reply with quote
Yeah, they are a bit different. The engine is loosely based on the NC23 though so engine characteristics I'd imagine are similar, mine has a bit less poke, I would guess.
CB-1 is probably the sportier of the two but the SF has, I've been told, VFR750 brakes up front, so a bit overkill for the tiny 400.
I love it though for exactly the reasons Rhino described, throwing it around, dropping it into a corner and then redlining her out of the corner and up the gears to still be doing less than the ton before the next. And having to keep it on the boil to keep her shifting, reminds me of a two stroke in that regard.
Iain.
PostPosted: 20:15 - 30 Sep 2015    Post subject: Reply with quote
Things happened
https://i.imgur.com/3dGJSG1l.jpg
Lots of nope living in this engine. Found this bastard hiding in it.
https://i.imgur.com/fncpiIBl.jpg
Big issues with the engine mount, simply no way of making it fit. Chopped it up;
https://i.imgur.com/DX1pag0l.jpg
Then attempted to weld a box section mount around the headers which just wasn't happening.
https://i.imgur.com/cCCqXo3l.jpg
Then gave up, and attached it to the cylinder head mount instead. Ought to hold it...soon find out if the engine falls out I guess, keep an eye on it and see if the welds start cracking.
Found an exhaust in a hedge that seemed to fit, so got that hooked up at the moment. Was near where we found the CBR so probbably came off it at some point.
https://i.imgur.com/Sv8sTFkl.jpg
Did ride it, rode like an absolute dog. 1/8th throttle and 6,000rpm is about the limit. Being hamfisted you can rev it out but it's very spluttery and pretty much pointless trying to do so...bike back in bits again.
https://i.imgur.com/RXVll3Kl.jpg
https://i.imgur.com/jM1T3A1l.jpg
Carbs off and in a bazillion bits.
https://i.imgur.com/aMgfvhzl.jpg
https://i.imgur.com/qBPCQO2l.jpg
Picked up a fiberglass matting kit, I'm going to attempt to make the bottom half of the airbox, I can then bolt the trumpet panel off the CBR carbs to the CB-1 air filter element and top half of the airbox at an angle that it'll fit under the tank. See where that goes...if its a non starter then I guess I'll just have to re-jet and shim needles till it's rideable but I suspect I'll loose a lot of power going that way. I can't make any more space under the tank as I've already had to batter the hell out of it just to clear the carbs and trumpets, it's a really tight squeeze under there.
The radiator needs a better mount too, but the motor makes oil pressure, selects all the gears, clutch is good, no coolant leaks, temprature reads all okay. I'm happy with that to be fair, fuelling issues were always going to be an issue from the second the CB-1 carbs diddn't fit the CBR head.
Iain.
PostPosted: 20:27 - 30 Sep 2015    Post subject: Reply with quote
N cee thirty wrote:
should have just reframed the nc23
On what basis?
Every bearing is shot. As are the forks, the calipers, all the bodywork, the chain and sprocket set, the dashboard...infact everything that isn't the frame. It's got a very good straight frame with all it's paperwork.
I can't see any reason at all I'd spend £2-3k on a six month restoration of what can only be described as a total wreck, totally replacing the single good component of the bike. Confused
Iain.
PostPosted: 20:52 - 30 Sep 2015    Post subject: Reply with quote
N cee thirty wrote:
i very much doubt, the running gear on this cb1 is any good going by your track record
Was in daily use, commuting Maidstone - Basildon every day prior to engine death. Has a long MOT. Everything works as expected.
You are by all means welcome to make me an offer on what remains of the CBR, apparently theres a few more boxes of spares to come with it. Perhaps some are of use to yourself?
Fladdem
PostPosted: 17:50 - 01 Oct 2015    Post subject: Reply with quote
Iain!
Here's one for you, would the NC23 header pipes fit a CB-1? And if so, would they fit a Super four? Or no chance at all?
I ask because I want more noise, but don't want to butcher my lovely stainless pipe. Laughing
Iain.
PostPosted: 18:03 - 01 Oct 2015    Post subject: Reply with quote
Nope. Port spacings totally different - hence cant fit the factory cradle into the bike.
CB-1 downpipes however might? Take some measurements - I've still got CB-1 downpipes with no can on them that'd be ideal for butchering!
Matt B
PostPosted: 08:55 - 02 Oct 2015    Post subject: Reply with quote
The most important question is - will this be ready for 1/4 mile shenanigans at Santa Pod tomorrow?
Fladdem
PostPosted: 20:17 - 05 Oct 2015    Post subject: Reply with quote
Thanks, here's some rough measurements with the pipes in place, I may need to get them off, but I'm going to Cornwall on her on the 7th and taking the pipes off now would only result in disaster. Laughing
From outside 1 to the outside of 4 is 320mm
From inside of 1 to the inside of 2 is 50mm
Inside of 2 to the inside of 3 is 75mm
The inside of 3 to the inside of 4 is 50mm
I'm not sure what the factory cradle looks like for the CB-1 but here's the best I could find of the NC31 Super Four
https://i.ebayimg.com/t/HONDA-CB400-NC31-PROJECT-BIG-1-CB-400-1994-MAIN-FRAME-PLATE-HPI-REPORT-V5-/00/s/OTAwWDEyMDA=/z/eiIAAOSwKrhVXzxt/$_35.JPG
Iain.
PostPosted: 00:10 - 08 Oct 2015    Post subject: Reply with quote
Will measure up when I clean the garage out.
Attempting to make carburettors work with no air filters isn't a lot of fun. I needed to do a lot of research into the donor bike to give me somewhere to start from before wasting money. Based on some ancient HRC setups, old manuals showing no airbox and some forum posts from 2007 I concluded the following;
Factory pilots are useable but read a smidge lean when dyno'd with no airbox. Increased from 40 to 42.
Mains are tiny. HRC kit included 140, 145 and 150 Keihin mains, dyno data from one with a modified airbox indicated 128 DJ mains were about on the money, if a little lean - they equate to about 138 Kehin. Opted to change the 110's to 145's.
The dyno pulls indicated the OEM needles shimmed offered the most stable fuel curve, and the HRC carb kits came with different needles. Speaking to Slipstream, my old boss and having been suggested the same by someone in workshop on here conclusion was needles need to go up to prevent the 6k drop off. Have put two more shims under each needle to richen up the midrange as a starting point.
Most of the parts are here, I'm taking the carbs to be ultrasonicly cleaned tomorrow. Might as well do the job propperly and it rules dirt out as a factor with setup issues. When it's back together and running roughly right I'll take it to the dyno and get it run up with a sniffer up the tailpipe to see what's actually going on & how much power it's making. Should be interesting!
Iain.
PostPosted: 23:17 - 08 Oct 2015    Post subject: Reply with quote
Managed to borrow this for a few hours;
https://i.imgur.com/wZnMH7Fl.jpg
Removed all parts of the carbs I could get off and dunked them in. 80 degree bath, four 20min cycles. Cleaning solution was clear when I started! Shows how much these things actually get out of the carbs.
https://i.imgur.com/EGwxbbul.jpg
Flipped them over each cycle;
https://i.imgur.com/oGOvEH2l.jpg
Washed out with water, then dried with an air line & finished off off by cleaning anything else with brake cleaner.
Then started re-assembly;
https://i.imgur.com/0mJ4wSEl.jpg
Just awaiting the arrival of new pilot jets.
The last post was made 11 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 144.28 Kb
