Problem with reaching the Starter Motor
vlf
PostPosted: 21:31 - 07 Feb 2005    Post subject: Problem with reaching the Starter Motor Reply with quote
So, I've been going over my starter problem and me and a mate tried to get the starter motor out to try and solve the problem.
The problem is that the damn generator coil case doesn't even budge!
We've, obviously, removed all the screws but still, the damn plate won't budge. There's no screw left that could be restraining the plate but it won't budge, we even tried running her up a bit but the case just sits there and laughs at us.
So, my question is - Is there any special trick to remove it? or is there anyway to reach the damned starter motor besides removing the WHOLE engine?
The bike is a '98 NSR.
Thanks in advance!
mr jamez
PostPosted: 21:52 - 07 Feb 2005    Post subject: Reply with quote
Strange, are you sure you have removed all the bolts? there are two that hold the sprocket cover on that also go through the gen cover but these are fairly easy to spot.
Perhaps tap sharply all the way round with a rubber hammer or the wooden handle of a hammer to break the seal that the gasket provides, because I cannot think of any other reason why it would not come off.
Once you have removed this, there are two bolts and that is pretty much it regarding the removal of the starter motor.
vlf
PostPosted: 22:21 - 07 Feb 2005    Post subject: Reply with quote
we've tried bashing the whole thing with a hammer, but still it wouldn't budge. Also, we removed a total of 9 bolts.
Seven from the generator coil, and the other two from the chain case.
I just can't think of a way for it to open. Have you ever removed the case? It went out good? is there any other way to the starter motor?
mr jamez
PostPosted: 22:34 - 07 Feb 2005    Post subject: Reply with quote
Have removed it about 5 times or so, never had any problems! The bolts that hold the starter motor in can only be accessed when you get the gen cover off.
If you take off the little cap (hex key head) on the gen cover, you may be able to get a better hold on it to pull it off. Hit it, rock it and pull it at the same time!
vlf
PostPosted: 22:44 - 07 Feb 2005    Post subject: Reply with quote
We even tried to do it that way, but we were unsure if it would be doing any good... We did it with some random weak tool, didn't seem to work. Any advice?
mr jamez
PostPosted: 22:56 - 07 Feb 2005    Post subject: Reply with quote
I would just keep at it, the seal will break eventualy, hit the top of it a bit harder with the old rubber mallet Wink
vlf
PostPosted: 23:07 - 07 Feb 2005    Post subject: Reply with quote
I guess that's the only way out of it... Even though we were bashing the damn thing for 5 hours straight!
alains
PostPosted: 23:08 - 07 Feb 2005    Post subject: Reply with quote
some pictures
alains
PostPosted: 23:11 - 07 Feb 2005    Post subject: Reply with quote
an other , knock the nose with a piece of wood , the seal has stocked it
vlf
PostPosted: 23:35 - 07 Feb 2005    Post subject: Reply with quote
Damn that left crankcase cover, if only I could remove it!
Thanks all of you for the advice and schemes! I'll probably give it another try tomorrow... With a hammer...
vlf
PostPosted: 17:03 - 08 Feb 2005    Post subject: Reply with quote
Updating - Well more bashing and some pushing, nope, ain't going to budge. I guess the last option is the garage, right? *sigh*
alains
PostPosted: 18:12 - 08 Feb 2005    Post subject: Reply with quote
try to insert a fine screwdriver with a small hammer (hope you have a new gasket) . how many nuts did you take off (apart of the 2 from the front sprocket cover)
vlf
PostPosted: 18:59 - 08 Feb 2005    Post subject: Reply with quote
I took 7 bolts, I even tried brutalizing the damn thing, pushing it from inside but it still wouldn't even budge.
alains
PostPosted: 19:40 - 08 Feb 2005    Post subject: Reply with quote
i gess the last time it was open , it has been fit with pasta avoiding to put a new gasket . i think you must hit it firmly with a piece of wood and a hammer from behind .
vlf
PostPosted: 19:55 - 08 Feb 2005    Post subject: Reply with quote
Pasta huh? I can see a green substance, looks like plastic, in between the cover and the gen.
alains
PostPosted: 20:39 - 08 Feb 2005    Post subject: Reply with quote
i think you must insist otherwise i cannot see how to take it out .
what you can too is to take off the 2 bolts fixing the starter , unplug the little loom up on the bike , they with a piece of wood and a hammer knock it out .
vlf
PostPosted: 21:07 - 08 Feb 2005    Post subject: Reply with quote
But the problem is, I can't reach the starter motor. And besides, no matter how much I bash it, it justs sits there, idling. It NEVER EVER moved an inch. I think if I were to crash, it still wouldn't budge.
alains
PostPosted: 22:18 - 08 Feb 2005    Post subject: Reply with quote
so , the only solution you have is to buy a second hand spare cover and destroy yours , but be carefull to do not destroy the alternator stator . just knock on the border (where it's easier) even if you make an hole in it , afterwards with a lever you will be able to lift it . i have not many alternative ideas
vlf
PostPosted: 22:28 - 08 Feb 2005    Post subject: Reply with quote
Perhaps you're right. Still - I'd rather try and resfrain from destroying it. I guess the garage will have to use some tools and do their work. Thanks for the help!
The last post was made 21 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 97.56 Kb
