Short biker
bignige
PostPosted: 08:38 - 28 Sep 2015    Post subject: Short biker Reply with quote
Hi,
I am 54 years of age, male and (honestly) 5 foot tall, 7.5 stone and very slim build.
I have not had a bike for 12 years and have never attempted the full bike test because I have always felt I am too short and not strong enough (7 stone weakling and all that!) to hold up and manage a 500cc bike.
Last bike I had was an Aprilia RS 125 having passed the CBT - which has now expired. Struggled like hell with the bike as it is the same seat height as a CBR600 - so I had a cobbler build up the heels on my boots - even then I could only get one foot down so it was dodgy riding in wind etc!
Would I be able to take the full bike test? If so on what bike? Anyone else my height done it?
I am not a fan of cruisers etc - only want a sports bike.
The real shame is that I can just about get both feet down on a 400 baby blade - but they are not suitable for taking a test on.
I get people all the time saying 'So and so has passed his test and he is only your height' - reality is that often these people are, say, 5 ft 2+ - those extra couple of inches make a difference - but I am only 5 ft exactly.
Got the bug now to get back on a bike so any help would be much appreciated.
Nige
petalbriefs
PostPosted: 09:09 - 28 Sep 2015    Post subject: Reply with quote
Hi Nige,
I say I am 5"0 but in actual inches I am 4"11 3/4
I weigh a little more than you to be honest ( Embarassed ) but still, that shouldn't stop you altogether.
I passed my test on an ER6F that had been lowered and now have a Yamaha R6 (also lowered)
If you want to ride a bike, you will learn to deal with your shortcomings ( Laughing ) as I have.
Just persevere, in all honesty, once you've done it and you start building some confidence, You'll be fine.
I started off on a CBR125 and I am now as confident handling the R6 as I was that.
Confidence really is the key. Smile Thumbs Up
*My inside leg is only 28" and I can only get one foot down on the R6, you have to learn to shift about a bit when you stop.
Proud owner of an R6 Smile + ZXR400
Honda CBR 125 R - Stolen
UncleFester
PostPosted: 09:21 - 28 Sep 2015    Post subject: Reply with quote
It's inside leg length, not height that you need to quote.
My YBR125 fitted fine as does my CB500 - as do Monster 696/796
Have a look on www.cycle-ergo.com
Don't forget some bikes have the right seat height but the seat may be the wrong profile so you still end up wobbling from one side to the other.
5'8 / inside leg is around 28"
2017 Z1000SX
doggone
PostPosted: 09:45 - 28 Sep 2015    Post subject: Reply with quote
You don't absolutely need to be able to touch both feet down, a lot of trail bikes unless your 6ft plus you just have to get used to it and slide one way or the other in advance!
Good point about seats, a narrower profile e.g. SV650 might make it easier even though it isn't particularly low.
PostPosted: 10:21 - 28 Sep 2015    Post subject: Reply with quote
QFT.
Ostriches and otters might be the same height[*] but it's all about what's below-the-groin.
I'm about a 28" inside leg and find even "low" bikes like a CBR600 a bit tippy-toe. But you can lower them. My lowered-example-of-a-lowered-model GS is ridiculously low, I can flat foot both sides.
If you're serious, buy your own 600cc+ bike and modify it. You can insure it on your provisionaL entitlement with BikeSure and possibly others. You're absolutely fine to use your own bike for the tests, as long as it's insured and sporting L plates front and rear.
Training on it and getting it to the test centre legally is an exercise for the reader.
[*] I'm saying that they might be, not that they are. Have you ever seen them together?
bignige
PostPosted: 13:35 - 28 Sep 2015    Post subject: Instructor's advice Reply with quote
Thanks for all the helpful replies. I have met an instructor today and he has advised me to buy or borrow a bike that I can ride comfortably- over 35KW and use that for the test.
Ultimately I only want a sports bike - but could use some other bike for the test. He suggested a Triumph Bonneville?
ER 500 was far too big and heavy for me.
What is a small bike over 35KW that would be good for the test?
I could easily ride a baby blade 400 but instructor thinks they do not have the 7.5 metre turning circle needed?
Nige
petalbriefs
PostPosted: 14:23 - 28 Sep 2015    Post subject: Reply with quote
I really think you're going to struggle if an ER5 was heavy for you.
I believe its 193kg wet weight, my R6 is 200kg wet weight and I chose it because its one of the lightest 600 sports bikes.
I honestly dont know what you're going to find thats lighter than that but has the criteria for you to do the test.
Maybe someone here who is an instructor might be able to give an idea.............. Neutral
wr6133
PostPosted: 14:31 - 28 Sep 2015    Post subject: Re: Instructor's advice Reply with quote
If it's A2 bikes (20-35KW for test) then you have plenty of options. CB1 or CB400 superfour spring to mind. They can be had cheap and if you don't like the style you could punt them on after testing for what you paid.
If you do A2 though be aware none of the 600 supersports can be ridden on that licence. You'd be limited to the older 400's if you want that kind of thing.
PostPosted: 14:56 - 28 Sep 2015    Post subject: Reply with quote
Clearly intends to do full A.
Tests, sure, you want something with a good turning circle rather than a sports bike. Bonny might be an option, but they're not the lightest of bikes.
What's your budget, and are you OK with buying a bike specifically for your tests, or do you want to have a go on a sports bike?
UncleFester
PostPosted: 15:10 - 28 Sep 2015    Post subject: Reply with quote
See if you can borrow a F700GS with the low seat option, the bike is heavy .... but the weight is very low down.
As above, CB400 is very low ... as is the CB500 and the slightly later
CBF500 too.
2017 Z1000SX
wr6133
PostPosted: 15:18 - 28 Sep 2015    Post subject: Reply with quote
I thought A test bikes were 40KW+? OP mentions 35KW
PostPosted: 15:32 - 28 Sep 2015    Post subject: Reply with quote
I think mine (earlier branding of that model) has the lowered spring as well/instead. Either way, it's the lowest seated bike I've owned bar a 250 cruiser (even lower than my 125 and Enfield), and with the under-seat tank is far easier to handle than you'd expect.
I got on it and pulled away into a confident feet-up U turn, no problems at all. It was one of the big selling points to me.
It's not the lightest of beasts to push around on foot, but that's only one aspect of the test.
UncleBFester wrote:
As above, CB400 is very low ... as is the CB500 and the slightly later CBF500 too.
Not suitable for A tests Sad
Matt B
PostPosted: 16:09 - 28 Sep 2015    Post subject: Re: Instructor's advice Reply with quote
If you have a Triumph dealer nearby go and sit on one. They may be ok but the seats look relatively wide on them, and that is going to give you as much of a problem as a high seat.
Fester mentioned seat profiles, you want something narrow so your legs aren't as spread out which adds to the problem. Not sure the Bonny is really narrow enough in general.
PostPosted: 16:19 - 28 Sep 2015    Post subject: Reply with quote
A few of the girls recomend Daytona Ladystar boots. They add 2 inches to your height, without looking like it. I don't think they are too 'girlie' but they may be worth a look. Thumbs Up
bignige
PostPosted: 19:24 - 28 Sep 2015    Post subject: Boots Reply with quote
I like the idea of the boots. That is what I did when I had the Aprilia RS which enabled me to get one foot fully down and I managed that OK.
If I can't get sorted to do the full test I am just going to do the CBT and go back to a 125.
As I said to the instructor today if I can't physically do the test then at least I will be on a bike.
Probs the only 54 year old on a 125 sports bike - but hey ho!!
N
bignige
PostPosted: 20:56 - 28 Sep 2015    Post subject: Honda CBR250R Reply with quote
Just found the spec for the above and seat height is only 30.5 inches and very light bike.
Is there a test I can take on one of the above so I can get on the road?
Would it be OK as a bike to take a test on - thinking about turning circle etc!
N
PostPosted: 21:04 - 28 Sep 2015    Post subject: Reply with quote
Might be as well to get your confidence back up.
And there's nothing stopping you from doing A1 tests on your own bike. It's the cheapest way to practice particularly just £15.50 for mod 1.
Sure, it doesn't lead to a worthwhile license, but it does prove to yourself, examiners and any potential instructor that you're perfectly capable of passing them. You just need to do it on a bigger bike, which (once you're moving) is actually easier.
mailee
PostPosted: 21:43 - 28 Sep 2015    Post subject: Reply with quote
I had similar problems when taking my lessons and tests. I am a little taller than you at 5' 2" but am only 7.5 stone and was 58 at the time of my tests. I found the 500 Suzuki heavy and a little tall for me and could only get the ball of my foot down on one side. Half way through my lessons they moved the goal posts and I then had to change to a 650cc bike for the A test and the school went for kawasaki ER6's. This bike although slightly heavier was easier to control with a lower centre of gravity and a thinner seat. I could manage to get the ball of one foot down still but the bike just seemed easier to control. After a few lessons on this machine it became much easier and I got used to sliding slightly on the seat to get a full foot down each time I stopped. I now ride a Honda hornet and am surprised how easy it now is to ride a big bike now. I know i will never be the owner of a 1000cc machine but my Hornet is more than enough power for me and always gives me a big grin after each ride. Good luck. Wink
Val
PostPosted: 21:46 - 28 Sep 2015    Post subject: Re: Instructor's advice Reply with quote
First you need: Category A https://www.dft.gov.uk/motorcycle-test-vehicle-list/rules.php
This is a motorcycle without a side car that must:
be at least 595cc
have a power output of at least 40kw (53.6bhp)
There are many bikes that will fit you after you lower them. Somebody mention ER-6 and SV650.
You can get Suzuki Gladius SFV650 it has low seat height 785mm anyway. You can lower that say 40mm to 745mm.
This way it will be 5mm lower than your beloved 400 blade which is 750mm
Boneville is 775mm. But the Boneville seat is very wide so in practice any SFV650, SV650 or ER-6 will feel better.
https://www.lustracing.co.uk/suspension/suzuki-gladius-lowering-kits-sfv650.html
These are kind of sport naked bikes and they are 5-10kg lighter than Boneville.
By the way the ER 500 been to heavy for you. Nobody here can lift its own bike. The weight of the bike does not matter when you move.
When you are stopped you need one foot on the ground. That comes with practice.
Marclev
PostPosted: 23:22 - 28 Sep 2015    Post subject: Re: Instructor's advice Reply with quote
be at least 595cc
By the way the ER 500 been to heavy for you. Nobody hear can lift its own bike. The weight of the bike does not matter when you move.
Where the weight of the bike will most definitely matter is manual handling on the Mod 1 (I still have no idea what the point of that exercise is, in the real world, I just sit on the thing and use my feet to push it backwards when I need to, and the engine to go forwards!). OP won't get far if he can't shift the thing because he hasn't got the physical strength (yes it can be compensated for with technique of course but it's not going to do much for his confidence). Other than that I agree it's completely irrelevant, gyroscopic forces are great Smile
OP, why don't you just go to your local motorcycle dealership and sit on a bunch of bikes to see which works for you? You won't be able to test ride any, but if you tell them you're looking to buy a bike from them for when you completed your test, they shouldn't have a problem letting you try the seats and position.
PostPosted: 08:13 - 29 Sep 2015    Post subject: Re: Instructor's advice Reply with quote
https://i926.photobucket.com/albums/ad110/lupo355/grom_zps76d67c60.jpg
Gladius / SV might be a good shout. Plenty of lowering kits around as well. Thumbs Up
petalbriefs
PostPosted: 09:15 - 29 Sep 2015    Post subject: Re: Instructor's advice Reply with quote
Which when you are the height that the OP and I are, is not in the realms of possibility with most bikes.
I, pretty much every time I want to park, have to get off and "manually handle" the bike into the spot or out of it, if I park nose in.
So the manual handling part was very useful for me Thumbs Up
UncleFester
PostPosted: 09:20 - 29 Sep 2015    Post subject: Reply with quote
I have the same issue - whilst i'm more than strong enough to push most stuff around off the bike, leg length does not allow this on the bike.
I tend to push the bike around in 1st gear with the clutch held in - just makes it easier to stop a roll without needing to change grip.
BMW F700GS was a piece of cake to shove about, nice wide bars, narrow tank and a very low centre of gravity.
CB500 - much the same but that's lighter.
VFR800 - is a fat pig, dropped bars and without the rear rack on - hard to shove about.
GSR750 - narrow bars and a fat tank make it hard to get your weight in nice and close to it.
2017 Z1000SX
bignige
PostPosted: 10:25 - 29 Sep 2015    Post subject: Thank you so much Reply with quote
Thanks to all who have replied. I am overwhelmed now and don't know where to go next but I will start and try some bikes for size and weight.
Also, going to combine that with some boots with a heel or raised inner sole in them.
At the end of the day I will probably end up doing CBT again and sticking with a 125.
It seems ridiculous that I have spent around 20 years on and off riding bikes up to 125 (started on an FS1E at 16), with no accidents, I can easily ride a 400 baby blade (which I would be happy to ride for the rest of my biking days!) - but because of the regulations and my height, strength etc. I am unlikely to be able to pass the full bike test that will get me to be able to ride a 400cc bike!
When you also bear in mind that my last bike, an Aprilia RS 125 would reach 100mph it is not as if I have not been introduced to speed (although I appreciate that it is not in the same league as a 500cc plus machine).
It's a shame there is not some sort of dispensation where someone has been riding smaller machines for a certain number of years!
Many thanks again for all that have contributed to this discussion.
Nige
PostPosted: 11:48 - 29 Sep 2015    Post subject: Reply with quote
You can use a CBR400RR to sit A2, although it'll 'have' to be restricted down to 35kW for for the test and post test use. By which I mean, get a piece of paper that DVSA Derek will accept.
It's not on the DVSA list of A2 bikes but I can't see any reason why not.
The last post was made 10 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 139.85 Kb
