Tubed to tubeless tire, new valve required
JackDanger
PostPosted: 18:34 - 28 Sep 2015    Post subject: Tubed to tubeless tire, new valve required Reply with quote
Hi Guys,
I'm changing the tires over as they are really old and apparently I need a different valve on my back wheel as it is currently tubed.
Here are pictures of the front and rear valves as they are.
Rear
https://imgur.com/GmmVU31
Front
https://imgur.com/N9kwvZF
Could somebody please point me in the direction of a tubeless valve. My bike is a yamaha ybr125 2009. Would something like this be sufficient?
https://www.ebay.co.uk/itm/Car-Vehicle-Black-Plastic-Cap-Rubber-Tire-Tyre-Valve-Stem-Set-10PCS-wn-/291565650272?hash=item43e2aac160
Oh if it matters the tires are Michelin Pilot Sportys
Thanks in advance guys =)
RhynoCZ
PostPosted: 18:36 - 28 Sep 2015    Post subject: Reply with quote
Are those wheels spoked? Did it come with tube tyres? If so, keep on using the tubes, the rims won't hold the air in. Thumbs Up
Well, there is a possibility, they did put tubeless rims on the motorcycle, yet kept using tubes. But why would they do that? Thinking
If in need of valves, check with your local tyre shop/garage. They usually sell those.
JackDanger
PostPosted: 19:21 - 28 Sep 2015    Post subject: Reply with quote
Well the front wheel is defiantely not tubed, the guy that owned the bike before me did a load of BS work to it and didnt really look after it so it wouldnt surprise me if he just ripped the valve off and put a tube in the old tire. I dunno.
I havent changed the wheels or anything, I know it's not a great picture but I'm full of cold and can't be bothered going outside to take another. This is the picture from when I bought it if it helps.
https://imgur.com/k50Z9co
If the wheel isn't capable of holding a tubeless tire could I just have a new inner tube put in under the new tire?
PostPosted: 19:27 - 28 Sep 2015    Post subject: Reply with quote
That should be fine and those valves should be fine.
If you're paying someone to put the tyre in, they'll probably have them anyway, so worth checking.
I put some in recently and found an appropriate 'drift' poked through the back of the valve so it was pressing against the inner section with some washing up liquid 'lube' around the body got it nicely.
JackDanger
PostPosted: 19:30 - 28 Sep 2015    Post subject: Reply with quote
You know what I'm not that lazy. Heres some more pictures of the back wheel if they help.
https://imgur.com/9aHrRjj
https://imgur.com/eU66TiM
https://imgur.com/mGj0n41
Sorry for my potato camera.
RhynoCZ
PostPosted: 20:56 - 28 Sep 2015    Post subject: Reply with quote
Looking at the pictures I can see no reason, why those wheels wouldn't work with tubeless tyres. Go ahead. Thumbs Up Smile
From my experience, every motorcycle wheel I have ever seen, that was designed to use tubeless tyres, had the word ''Tubeless'' written/engraved somewhere on the wheel.
kramdra
PostPosted: 22:53 - 28 Sep 2015    Post subject: Reply with quote
TR412's are the size commonly used in motorcycles
https://www.ebay.co.uk/itm/141443354491
davebike
PostPosted: 10:47 - 29 Sep 2015    Post subject: Reply with quote
YBR125 is tubeless
Yes that valve will work
Yes the person how fitted a tube is a Twat
Smile)
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 10 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 58.14 Kb
