Honda CBF 125 2013
sunny20n81
PostPosted: 13:34 - 29 Sep 2015    Post subject: Honda CBF 125 2013 Reply with quote
Hi all,
I have a Honda CBF 125 2013. I have to push start it everyday. During the first 10 minutes of the ride the engine keeps cutting out if I don't keep the revs high. After about 10 minutes it seems to go away.
Not sure what is causing that problem.
Any advice will really help.
Thanks.
Honda CBF 125 2013
davebike
PostPosted: 09:34 - 30 Sep 2015    Post subject: Reply with quote
Battery or charging system or both
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 09:54 - 30 Sep 2015    Post subject: Re: Honda CBF 125 2013 Reply with quote
Sounds likely.
Don't guess, diagnose. Get a cheap £5 multimeter and measure your battery voltage with the engine off and with it running.
If it's a wet cell battery, check the level of electrolyte in the cells and if necessary top them up with distilled water which you can get from most supermarkets, garages or Halfrauds. Google for how.
If you're doing short trips, slap a charger on it and get it fully charged up. If you do end up replacing the battery, get a charger and charge it up anyway - you want to get it fully charged and keep it that way.
sunny20n81
PostPosted: 11:49 - 30 Sep 2015    Post subject: Reply with quote
Thank you so much for your help guys. Your input really means a lot. I have been struggling to get help elsewhere. I was quoted 70£ + VAT just to diagnose the issue - Unbelievable!
Thanks again. Much appreciated.
Honda CBF 125 2013
The last post was made 10 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 38.86 Kb
