Bike theiving, why so easy to hotwire?
Ribenapigeon
PostPosted: 07:04 - 01 Oct 2015    Post subject: Bike theiving, why so easy to hotwire? Reply with quote
Been a lot of bike thefts in Aberdeen recently. A lot of the bikes are new models less than five years old and from major manufacturers but the thieves seem to have no problem getting the bikes running so they can go joyriding. Why is it so easy to hotwire bikes?
grr666
PostPosted: 07:13 - 01 Oct 2015    Post subject: Reply with quote
Exposed engine/electrics/ignition
Duuuh!
/Thread
mentalboy
PostPosted: 07:14 - 01 Oct 2015    Post subject: Reply with quote
Really?
Ask yourself which of these three you prefer to gain unauthorised access to alter the wiring and think about your reasoning!
1) The Bank of England
2) A Volvo
3) A motorcycle
Rolling Eyes
MCN
PostPosted: 07:31 - 01 Oct 2015    Post subject: Reply with quote
Incompetent security.
Incompetent parking.
Incompetent incompetence.
c_dug
PostPosted: 07:39 - 01 Oct 2015    Post subject: Reply with quote
I agree with what the others have said, I'm unsure why immobilisers aren't a requirement on bikes though, my understanding is that the requirement for cars to be fitted with immobilisers has pretty much stopped that sort of thieving of cars.
hellkat
PostPosted: 07:52 - 01 Oct 2015    Post subject: Reply with quote
I have trouble remembering to take off a damn disk lock, I'd be fucked trying to remember to disengage an immobiliser.
hk: My bike doesn't work, call the RAC *waambulance* ...
RAC Man called out at 2.30am: It's your immobiliser, luv.
hk: Oh ... *blush, squirm*
MCN
PostPosted: 09:03 - 01 Oct 2015    Post subject: Reply with quote
Rock the Kill Switch to the 'Off' position when you park up.
If the daubuhrs who post on here about 'their bike can't start' are flummoxed by simple tech then the scroti should be too. (They're from the same Species init.)
PostPosted: 09:17 - 01 Oct 2015    Post subject: Reply with quote
The traditional wisdom was that every bike stolen and parted out / wrecked / burned out / shipped to Elbonia results in a new bike being sold.
So, are you or have you even been in the market for a new bike? Do/did you rule bikes out because of ropey security?
If the answer is "no" to either of those, then why would bike manufacturers give a wet fart about improving security?
zark
PostPosted: 09:31 - 01 Oct 2015    Post subject: Reply with quote
Makes perfect sense to me. Or... push button start with the key/card/whatever in range in your pocket - now that would make life easier. Does anyone do this?
Knowing that most aftermarket/retrofit immobilisers will leave you stranded at some point - i'm reluctant to fit immobiliser on current bike - but would kinda expect something decent on a new one?
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
Slacker24seve...
PostPosted: 09:39 - 01 Oct 2015    Post subject: Reply with quote
I was able to remove my datatool alarm when I was pissed. It took me a while, but I reckon it's a 5 minute job tops when sober.
Banger rallies are ace
PostPosted: 10:00 - 01 Oct 2015    Post subject: Reply with quote
Last bike I had stolen was fitted with a 12 lead immobaliser. Didn't stop them bypassing it and going joyriding.
I think the only way you'd really stop them joyriding is if the key was an integral part of the ignition system. Then you have the fun of having to replace the entire ECU if you loose the key.
goto10
Both of my Hondas have HISS on them - there's a passive chip inside the key itself so the ECU won't function unless it has seen it. All I have to do is put the key in the ignition and start the bike, nothing else to remember.
https://world.honda.com/tech-views/motor/hiss/qa/
PostPosted: 10:06 - 01 Oct 2015    Post subject: Reply with quote
HISS appears to be taking it seriously, although God help you if it malfunctions or you loose lose the key.
Again though, is it a deciding factor in new bike purchasing? Triumph, for example, sold loads of bikes even with notoriously poor security.
goto10
PostPosted: 10:33 - 01 Oct 2015    Post subject: Reply with quote
Yeah, that'd be a bit sh't, but the same risks apply to my car keys *shrugs*
When I was looking at the NC700 I had no idea what HISS meant, nor did the salesperson even mention it as a selling point - so, no.
But now I am aware of it, I'll probably be more conscious of it - especially for something that gets dumped in a London street all day long. If it was for a weekend toy that sits in an alarmed/double locked garage then it would be less of a consideration.
Undinist
PostPosted: 11:31 - 01 Oct 2015    Post subject: Reply with quote
Would it be hard to fit an extra switch to the ignition circuit? Wouldn't that be more reliable than an aftermarket immobiliser?
Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S
weasley
PostPosted: 12:21 - 01 Oct 2015    Post subject: Reply with quote
c_dug wrote:
...my understanding is that the requirement for cars to be fitted with immobilisers has pretty much stopped that sort of thieving of cars.
...and led to the aggravated theft of the keys, which is much quicker/easier with no need to repair any damage afterwards.
Someone I know apocryphally apparently wired a switch into the ashtray of his car - pull the ashtray out a little bit and the switch opened, no starty. Push the ashtray home fully, switch closes, vroom vroom.
J.M.
PostPosted: 12:32 - 01 Oct 2015    Post subject: Reply with quote
On my old diversion I once hot wired it by running a small wire from the battery to the starter fuse. Fired up perfectly well then. Didn't have to touch any of the wires around the ignition barrel.
2004 R1 & 2018 XSR900
PostPosted: 12:58 - 01 Oct 2015    Post subject: Reply with quote
My Trophy has a 'need the key' immobiliser fitted as standard by Triumph. While I'm sure it does the job, just thinking about the cost of a spare key has me sweating!
bladeblaster
PostPosted: 13:24 - 01 Oct 2015    Post subject: Reply with quote
probably the main reasons immobilisers are much less common on bikes is that on the whole they are pretty useless in themselves. OK it may deter the odd scrote joyrider, but if someone is actually nicking your bike chances are they will just lift it into the back if a van.
Ground anchoring, etc is much more effective for bikes than immobilisers.
Not quite so easy to chuck a car in the back of a van, lets be honest if you can;t start it, you probably ain't nicking it. With a bike all you need to be able to do is physically lift it, once you have done that you have all the time in the world to re-program keys, ECU's whatever, from the comfort of your scrote lair.
Mudshark
PostPosted: 13:56 - 01 Oct 2015    Post subject: Reply with quote
likewise my BMW, but as stated elsewhere it doesn't stop it getting manhandled into a van
R1250RS
XT660X
PostPosted: 14:09 - 01 Oct 2015    Post subject: Reply with quote
Or part it out. Everything except the ECU.
ScaredyCat
PostPosted: 14:22 - 01 Oct 2015    Post subject: Reply with quote
It's just a shame they make the keys out of butter...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
bladeblaster
PostPosted: 14:26 - 01 Oct 2015    Post subject: Reply with quote
exactly, which most of the time is what happens, much more difficult to trace parts, the chances of being caught are much less especially if its crossed the channel for breaking.
Baffler186
PostPosted: 14:31 - 01 Oct 2015    Post subject: Reply with quote
So does mine, but I've got a master red key locked in a safe, and two spare balck ones, so if I lost all of those I'd deserve to not have a bike
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
goto10
PostPosted: 14:57 - 01 Oct 2015    Post subject: Reply with quote
Have you had one break? I've used the same one for the last three years [almost daily] and it looks fine*
(I've not actually compared it to the spare, so it could be worn to f'ck and I haven't noticed...)
The last post was made 11 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 131.26 Kb
