Wiring help
tatt0owarrior
PostPosted: 11:42 - 01 Oct 2015    Post subject: Wiring help Reply with quote
Anyone got any ideas on how to wire this lot?
https://img.photobucket.com/albums/v162/bigblokey0/20151001_111529_zpshm87ogtz.jpg
its for this
https://img.photobucket.com/albums/v162/bigblokey0/Screenshot_2015-09-27-16-44-592_zpslvnnni11.jpg
Michelle L
PostPosted: 12:11 - 01 Oct 2015    Post subject: Reply with quote
How have you done that may I ask ?. Or are you putting something new on your bike.
Ride safe , if you can not ride safe , ride free....
Islander
PostPosted: 12:15 - 01 Oct 2015    Post subject: Reply with quote
Permanent or non-permanent?
For permanent I'd probably use either soldered connections and heatshrink if there wasn't going to be too much movement in the wiring, or decent quality crimped butt connections and heatshrink over the lot if there's likely to be movement. If you go down the butt route, then stagger the connections otherwise you'll end up with a huge bunch in the middle.
For non-permanent then I'd use a suitable rated multiway connector weatherproofed if required.
This bunch supply all that you'll need:
https://www.vehicle-wiring-products.eu/
Michelle L
PostPosted: 12:22 - 01 Oct 2015    Post subject: Reply with quote
Sorry have I miss read it , I thought he was asking which wire went where Confused .
I just use wire connectors , always have , never had any problems,
tatt0owarrior
PostPosted: 12:25 - 01 Oct 2015    Post subject: Reply with quote
I'm adding a new speedo to replace the stock one but i cant find a wiring diagram for a gs 125 so yes i'm asking which wire goes to which wire
Islander
PostPosted: 13:33 - 01 Oct 2015    Post subject: Reply with quote
As I understand it, the GN125 is similar barring the gear position indicator. The diagram below is on an Argentinian site so you might need to use google translate but it'll give you something to compare.
https://cmelectronica.com.ar/wiring-diagram/imagenes/suzuki-gn125-h.jpg
tatt0owarrior
PostPosted: 14:05 - 01 Oct 2015    Post subject: Reply with quote
Ahh that's great thanks very much Thumbs Up
The last post was made 10 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 50.74 Kb
