| BrownTownXR |
 BrownTownXR L Plate Warrior
 Posted: 15:21 - 30 Sep 2015 Post subject: honda XR125 '03 basic carb questions. come help a pure noob! |
so i saw a video on youtube watching someone clean out their carb, and since the XR125 i just brought has been sitting in a garage most of its life i figured i'd give it a clean.
ive just put the carb back on and when i try to start it, fuel comes pouring out of the bottom hose, like a tap, until i turn off the fuel switch.
i think what ive gone and done is unscrew the fuel mix screw and when i put it back on i tightened it pretty much all the way.
Am i right in thinking this is whats wrong? If so do i just unscrew it a small amount until it runs?
Or is it something else?
The bike was running before i put my hands on it
EDIT: in this thread ( https://www.bikechatforums.com/viewtopic.php?t=211774 ), the 2nd post says to turn the screw 1.5 - 2 turns out. Does this mean 1.5 - 2 turns from loose, or 1.5 - 2 turns from being thight?
Thank You. |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 16:42 - 30 Sep 2015 Post subject: Re: honda XR125 '03 basic carb questions. come help a pure n |
| BrownTownXR wrote: | ive just put the carb back on and when i try to start it, fuel comes pouring out of the bottom hose, like a tap, until i turn off the fuel switch.
Thank You. |
The most likely things to have happened are:-
1. You haven't put the float valve back in place properly or you've disturbed it and it's not seating correctly.
2. The screw your turning is not the mixture screw. There's normally a drain screw that allows you to let fuel out of the float bowl, this needs to be tightened.
3. The air screw, or mixture screw, is set by turning it out from fully tight and counting the number of turns. That applies to all screw adjustment on your carb, you count the turns out from fully tight.
Did you remove the float valve, did you check the float heights?
If you didn't remove the floats or valve there may be dirt blocking it which, as the valve will not close properly, means petrol will flood the float bowl and overflow via the overflow pipe. ____________________ "Everybody needs money, that's why they call it money!"  |
| BrownTownXR |
 Posted: 17:26 - 30 Sep 2015 Post subject: |
thanks for replying sid,
im sure its the float valve, i removed the valve (by mistake thinking i needed to) and took of the bowl, sprayed some carb cleaner around, then put it back together. And when i say that, i mean i put the bowl back on, screwed in the valve.
so how should i go about this?
thanks a lot for your help, i start work at 5am tomorrow and really dont want to cycle!
EDIT: this is the screw I took out and put back in, that's it. https://i.imgur.com/UVJZvt0.jpg |
| Suntan Sid |
 Posted: 18:40 - 30 Sep 2015 Post subject: |
I don't know that particular carb, I think it's similar to a CG carb, but I would guess that is the pilot jet, so you need to find out how many turns out it needs to be! ____________________ "Everybody needs money, that's why they call it money!"  |
| BrownTownXR |
| Iain. |
 Iain. Could Be A Chat Bot
| BrownTownXR |
| Iain. |
| Islander |
 Islander World Chat Champion
 Posted: 11:37 - 01 Oct 2015 Post subject: |
It may also be that the seal on the float valve is damaged or perished.  |
| BrownTownXR |
| BrownTownXR |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:26 - 01 Oct 2015 Post subject: |
The Kehin PD crbs have a drain screw o the bottom of the float-bowl, that when undone, 'drains' the fuel in the float bowl out of the over-flow pipe.....
Other-wise, if fuel is coming out that over-flow.. then the float-bowl is over-flowing! Only way that can happen is if the float isn't closing the inlet off when the correct level is reached.
Ergo.. IF fuel is coming out of that pip and pipe on the bottom, it isn't going to be aything to do with the jets, needles, pilot-air-screw or anything else. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Islander |
| BrownTownXR |
The last post was made 10 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
