Is my derbi senda running properly?
ItsTommmm
PostPosted: 20:42 - 01 Oct 2015    Post subject: Is my derbi senda running properly? Reply with quote
The spark plug looks a good colour. I'm wondering if what's happening is normal or if I need to adjust jetting a bit. I let bike warm up properly. It won't rev instantly like from idle to quarter turn but when I rev it a bit more I get better responce from from no throttle to a quarter. So its like if I get it going a bit it goes absolutely perfect but only when its been idling for a bit it doesn't pick up revs instantly.
Any advice appreciated.
Thanks.
RhynoCZ
PostPosted: 21:07 - 01 Oct 2015    Post subject: Reply with quote
Why would you change the jet? Is there a reason why you'd do that? If it's stock, then do not touch it. I'd start with checking the adjustment of the throttle cable/s. Then I'd check the idle adjustment. If everything is alright, then it's time to have a look at the airfilter. If that's alright, there could be a slight air leak in the intake manifold. You could also clean the carb, read the manual and put it back to its factory settings, if you've already fiddled with it.
Never fiddle with the jets, if it ran alright before. It's not going to fix a thing. Thumbs Up
ItsTommmm
PostPosted: 21:10 - 01 Oct 2015    Post subject: Reply with quote
I had to upjet because I put a Performance exhaust
Just_James
PostPosted: 21:18 - 01 Oct 2015    Post subject: Reply with quote
If you're having the problem since fitting the new exhaust then you may need to upjet but if you're mostly having the issue at low revs then you may be able to just adjust your air / mixture screw.
Fairly simple vid on how to here
https://youtu.be/YxpQjDQzX7g?t=3m1s
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
ItsTommmm
PostPosted: 21:20 - 01 Oct 2015    Post subject: Reply with quote
thanks, I'll have a fiddle when I get a new plug
RhynoCZ
PostPosted: 21:21 - 01 Oct 2015    Post subject: Reply with quote
What James says, by the way Tom, always start with what you or your mates, previous owners have done, before you ask a question. It helps us to get you the right answer quicker. Thumbs Up
ItsTommmm
PostPosted: 19:46 - 02 Oct 2015    Post subject: Reply with quote
ok. I'll do a plug chop tomorrow and see if my mixture is right.
.. This post is not being displayed because the poster is banned. Unhide this post / all posts.
ItsTommmm
PostPosted: 20:24 - 06 Oct 2015    Post subject: Re: Fit a Polini CP 19 or it'll never run properly' Reply with quote
MacGyver wrote:
thanks
The last post was made 10 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 69.55 Kb
