ultrasonic cleaning solution
bladeblaster
PostPosted: 08:41 - 30 Sep 2015    Post subject: ultrasonic cleaning solution Reply with quote
What are people using in the ultrasonic baths for cleaning carbs? Is there something which is specifically good, or anythings that should be specifically avoided.
We have some generic cleaning solution at work that I can use, its probably essentially washing up liquid.
Cheers.
uberkron
PostPosted: 11:50 - 30 Sep 2015    Post subject: Reply with quote
I use white gas/coleman fuel. I also put the lid on. And do this outside just in case.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 11:51 - 30 Sep 2015    Post subject: Reply with quote
PostPosted: 12:17 - 30 Sep 2015    Post subject: Reply with quote
I use hot, soapy water.
PostPosted: 12:21 - 30 Sep 2015    Post subject: Reply with quote
Soapy water with some vinegar normally. Thumbs Up
Baffler186
PostPosted: 13:14 - 30 Sep 2015    Post subject: Reply with quote
Might be dumb question - has anyone tried bicarbonate of soda? It works wonders in my dishwasher and in the drains.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Ariel Badger
PostPosted: 19:24 - 30 Sep 2015    Post subject: Reply with quote
I do not think Bicarb is good to aluminium.
bladeblaster
PostPosted: 08:40 - 01 Oct 2015    Post subject: Reply with quote
cheers guys, I will use the stuff we have at work then I guess. Just make sure I give it a damn good rinse through after and a few good squirts of carb cleaner Thumbs Up
Nexus Icon
PostPosted: 14:21 - 01 Oct 2015    Post subject: Reply with quote
A 50/50 blend of soapy water and isopropyl/isopropanol works well.
You should be able to buy isopropyl as rubbing alcohol somewhere like Boots.
Greetings from Shitsville!
Major Doss
PostPosted: 23:43 - 01 Oct 2015    Post subject: Reply with quote
Be careful of soaps/washing up liquids as these can contain salt. Short cycles and rinse, then another cycle with warm (not hot) water, rinse again. Oh, and another rinse. Dry. Blow with airline/brake cleaner.
sickpup
Old Timer
PostPosted: 02:19 - 02 Oct 2015    Post subject: Reply with quote
Generally considered best to avoid things like washing up liquid as they contain salt.
bladeblaster
PostPosted: 11:38 - 02 Oct 2015    Post subject: Reply with quote
I will check the ingredients on the one we have at work.
ZRX61
Victor Meldrew
PostPosted: 21:31 - 02 Oct 2015    Post subject: Reply with quote
laundry detergent.
They're not one night stands, they're auditions.
bladeblaster
PostPosted: 07:38 - 03 Oct 2015    Post subject: Reply with quote
I looked at the cleaner we have at work and its a high alkaline cleaner so no good for Aluminium.
I figured a drop of Muck-Off should be ok, that's specifically for bikes, and bikes are primarily aluminium these days, so should be ok?
bladeblaster
PostPosted: 07:42 - 03 Oct 2015    Post subject: Reply with quote
ZRX61 wrote:
laundry detergent.
hmmm, I have heard this somewhere before, had forgotten about that.
cheers
Robby
Dirty Old Man
PostPosted: 13:51 - 03 Oct 2015    Post subject: Reply with quote
You only need a small amount of detergent. You're using detergent to break the surface tension of the water so that it will get into small spaces, not for its cleaning power. I presume this is why some people use vinegar - low surface tension, so it penetrates well.
Remember the ultrasonic cleaner is just removing grime from metal, not flushing it out. You will need to blow it all through with compressed air to get the crap out, then probably put it back in the bath. Repeat this process several times.
I don't like ultrasonic cleaning. I've only ever had bad results from it, starting with a carb that was "a bit off" and making it "totally shit". An aerosol can of carb cleaner does a far better job at cleaning up small holes and flushing out the crap. It's also the one job where I wear safety glasses, because aerosol carb cleaner seems magnetically attracted to my eyes.
BTTD
PostPosted: 21:40 - 03 Oct 2015    Post subject: Reply with quote
As per Robby, although ultrasonic cleaners have worked well for me in the past on BMW carbs, a generator carb, an SU, and a lawnmower!
bladeblaster
PostPosted: 23:31 - 03 Oct 2015    Post subject: Reply with quote
I put them through the ultrasonic cleaner with a small dash of muck-off. Then again with just hot water.
They are now sitting in a bowl of hot water just to thoroughly rinse.
Tomorrow once drained will get a good going through with carb cleaner, then compressed air Thumbs Up
PostPosted: 11:03 - 04 Oct 2015    Post subject: Reply with quote
Putting carb bodies, engine casings and crankcases through the dishwasher brings them up lovely. Like new.
BTTD
PostPosted: 18:11 - 04 Oct 2015    Post subject: Reply with quote
Vincent wrote:
....................I notice a lot of sites etc say not to use compressed air inside carbs..............is this just with more modern carbs that may have some non-metalic parts inside Question I like to blow jets through after cleaning them but most petrol station pumps won't do it now and I'm compressor-less. It'd be handy to have some pipe that you could stick onto a car tyre and use........ Thinking
I think it's to do with blasting out tiny rubber seals which then leaves you wondering why it won't work.
BTTD
PostPosted: 18:25 - 04 Oct 2015    Post subject: Reply with quote
I tried this with a bicycle sprocket set and was underwhelmed with the cleaning. Not sure why it didn't work well to be honest. Different type of dirt maybe?
The last post was made 10 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 127.41 Kb
