| stevenc370 |
 stevenc370 Two Stroke Sniffer
 Posted: 19:35 - 01 Oct 2015 Post subject: |
As far as I'm aware, the brake light and tail light on a GP100 ought to run off entirely seperate and independant circuits.
The head and tail light run on an AC direct lighting circuit (so they only run when the engine is on and brighten as you rev it).
The brake light runs off a DC powered circuit from the battery.
So, if they both work properly in isolation (bright tail light with engine running. Bright stop light with and without the engine running), the only place the two circuits SHOULD meet is at the earth connection.
I'd therefore suspect a bad earth. Japanese bikes of that era have notoriously badly earthed taillight clusters. FInd the earth connection (often a mucky ring terminal trapped under the rusty bolt holding the corroded rear mudguard to the rotting subframe spar) and give it a damned good clean so you have shiny metal of the terminal contacting shiny metal of the frame.
Also check out the earths on the bulb holder. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| davebike |
 davebike World Chat Champion
 Posted: 09:41 - 02 Oct 2015 Post subject: |
Probable poor earth connection or poorly fitting bulb ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| stevenc370 |
| stevenc370 |
The last post was made 10 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
