help me diagnose an issue
pompousporcup...
PostPosted: 15:45 - 03 Oct 2015    Post subject: help me diagnose an issue Reply with quote
Gpz5 starts and runs alright however once the engine has been run for a little while it doesn't rev as well and the exhaust note sounds crap..not crisp and responsive. When engine is cold sounds a lot better
Spark is good, valve clearances checked, carbs cleaned and balanced. Idle set correctly
I'd like to get it running cleaner.
CaNsA
PostPosted: 15:52 - 03 Oct 2015    Post subject: Reply with quote
Leaky carb rubbers?
air:fuel mix out of whack?
Fuel tank breather pipe blocked?
Fuel filter replaced?
pompousporcup...
PostPosted: 16:04 - 03 Oct 2015    Post subject: Reply with quote
Don't think its the tank breather, at least not this time as it runs ok...seems a bit hesitant when hot at lower revs in say 3rd at 30mph so I tend to stay in second. Tiny throttle and its fine until around 3/4k rpm then picks up
I've adjusted the mixture screw to 2.5 or there and got a blue spark at idle with the colour tune device
There is a slight fluctuation at idle on the rev counter.. so possibly a leak somewhere but has only started doing it recently after 100s of miles. The rubbers looked in good condition
Fuel filter is perhaps 500 miles old
bladeblaster
PostPosted: 22:36 - 03 Oct 2015    Post subject: Reply with quote
sounds like a fueling issue.
Is the fuel filter an in-line filter, and is it supposed to have one? They can play havoc with gravity fed systems.
PostPosted: 08:27 - 04 Oct 2015    Post subject: Reply with quote
Get it warmed up then get your face round by the exhaust outlet. If you're choking on fumes it's running rich.
PostPosted: 08:47 - 04 Oct 2015    Post subject: Reply with quote
Did you inherit this issue with the bike, or was it running fine but has started misbehaving recently?
Did you make any changes before it started happening? I'm looking at "valve clearances checked" with a little suspicion.
Any chance the choke cable has got pinched and the choke isn't coming off fully? Probably not since you're been at the carbs.
Diggs
PostPosted: 08:53 - 04 Oct 2015    Post subject: Reply with quote
Degraded coil. Swap for a decent one and see how it goes...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
orac
PostPosted: 09:46 - 04 Oct 2015    Post subject: Reply with quote
the fact that it happens with hot is sort of helpful.
how does it start when hot, easily needs a little cranking or is complete bastard?
compression test, take readings when cold and hot. if you get less when hot either the valves are incorrectly shimmed (which is my current guess) or you are getting blow by on the rings. I would think that you would be getting some oil from the exhaust if you had blow by - you can also do a leak down test to check for blow by.
I don't know what the plugs are like to get to on that but hot plugging to check mixture could be helpful.
incorrectly shimmed valves wont always show up on compression test, I have not done enough to be able to advice on that.
when you say carbs are clean, did you check float height, are the mixture set correctly, are the slider needles set correctly are the diaphragms in good condition. I had issues with a single diaphragm which stopped the bike running correctly when hot, the hole barely made it all the way through the membrane and took nearly 15 minutes of inspecting (by stretching in front of a light source) to find.
PostPosted: 09:59 - 04 Oct 2015    Post subject: Reply with quote
I'm pretty sure you've already checked the air filter?
The issue you describe (pulling well at high revs when cold, not so good when hot) is classic of an over-large main jet if you were setting a bike up.
So too much fuel, not enough air at wide-open throttle.
pompousporcup...
PostPosted: 16:27 - 04 Oct 2015    Post subject: Reply with quote
Not checked the filter in a few hundred miles so will have a look see.
Carbs were completely stripped and cleaned so it's unlikely an issue with them although I'm not ruling it out. Jetting it stock.
Coil..could be, the leads and plugs are pretty new with less than 1k on them.
Valve clearances are, as far they can be, correct. They were checked, checked again and then rechecked again with a size up and size lower.
I'l go and inspect the air filter and reset the idle mixture and do a general bolt/plug/rubber check
pompousporcup...
PostPosted: 20:09 - 04 Oct 2015    Post subject: Reply with quote
Filter was a bit dirty, I've taken a newer one out of the spares bike and have given it a clean
Set the idle mixture again using the colour tune and also changed the plugs in case it was a duff plug causing issues
Fuel filter is a zzr600 one that's in the fuel rail. A known mod as the gpz never came with an inline filter. I've checked it this evening and it wasn't clogged up or anything.
Nothing like reassembling a bike before leaving for work -_-
pompousporcup...
PostPosted: 20:37 - 05 Oct 2015    Post subject: Reply with quote
Ignoring the spammers. I put it back together this morning and rode to work. Still happens a bit but really If I use the rev range its not such an issue...it's like it's bogging down a bit under certain throttle/load situations but maybe I'm expecting too much from the bike and its heluvalot 47hp
Il keep adjusting the mixture until it's right and update when I've found the issue Thumbs Up
orac
PostPosted: 01:46 - 06 Oct 2015    Post subject: Reply with quote
All carbed engines have a flat spot somewhere in the rev range. The gs5 was resolved with a10% up jet on the mains,up jet on the primaries extra half turn on the mixture screws and a washer under the slider needles to raise them a half notch
pompousporcup...
PostPosted: 08:50 - 06 Oct 2015    Post subject: Reply with quote
no standard pipes.. stainless aftermarket set with a viper end can. Swapping this one over from a motad system the top end felt better(as much as it could from the engine)
Pretty sure they're not blocked but worth a check next time they're off. It rides fine and screams up to the red line.. its just a bit hesitant between 3/4k rpm at some throttle position
orac
PostPosted: 09:18 - 06 Oct 2015    Post subject: Reply with quote
seems the pipes had an affect but full standard google indicates a flat spot @ the 4-k5mark.
retune and service should sort it providing its not been fubard by a previous owner
heres something google threw up
https://www.bikechatforums.com/viewtopic.php?t=80961
pompousporcup...
PostPosted: 10:03 - 06 Oct 2015    Post subject: Reply with quote
thats awesome, hadn't seen that page Thumbs Up
I am the second owner from new. Laughing Hadn't been ridden properly in ~20 years hence the carb strip down, full service and exhaust change (the other developer a hole where the two pipes meet)
got to a point now where it works nicely when cold/normal running temp but if i'm sat in traffic too long and the engine gets "Hot" then it starts the issues described. I have no "flat" spot around 6/7/8k rpm and it shoots to the red line and feels responsive. It is possible im expecting too much from the old girl
bikenut
PostPosted: 10:15 - 06 Oct 2015    Post subject: hot Reply with quote
sitting in traffic it gets hot, fuel vapour lock or similar ?? but check ign advance when hot, to rule that out !!
exhaust headers by head glow red hot when bike misbehaves ?? show signs of too much heat ??
nuts about bikes
pompousporcup...
PostPosted: 13:58 - 28 Oct 2015    Post subject: Reply with quote
little update, thanks all for the ideas and advice.
i fixed this by trying to do an oil change.. because of the manifold design i couldn't get the sump plug out properly so ended up taking the exhaust off and when i'd finished the oil change i put the exhaust back on and used copper ring gaskets instead of reusing the organic gaskets i'd fitted a few hundred miles earlier
hey presto. the jumpy revs went away and its running better where it used to stutter (the correct gear means i never have this issue)
only now the flat spot is a bit further up the rev range -_-
The last post was made 11 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 101.41 Kb
