Not starting, checking out a charging fault
Paul2129
PostPosted: 22:08 - 04 Oct 2015    Post subject: Not starting, checking out a charging fault Reply with quote
I have a 2005 CG125 (somebody has to Wink it's done 23,000 miles. When I bought it, it was slow at turning the starter motor, I changed the battery, I'll admit, a cheap eBay one. All was well for maybe 2 years of fairly heavy daily use. The starter seemed to start jamming, it was replaced with one from a breakers.
I've started to notice that if it doesn't start on the first press, that the next press appears to have completely drained the battery. Ive just been on a long ride, and found that it was further drained during the ride, later on short errands it seemed better.
So, could it be :
1, the reg/rec, if so, how do I test it ?
Or
2, if it shows up 12 to 13v across the battery with the engine off, and 14.4v (ish) with the engine on and revving a bit, does that suggest that all is well with the charging ? (I have a digital display that shows voltage, I might be able to rig it up such that I can keep my eye on what the battery sees during a ride, any point ?)
They say "common things are common", fair point, but reg/recs are pretty common problems on Hondas. I think the next battery will be a decent one, I'd rather not fry it Sad
Many thanks
MattEMulsion
PostPosted: 22:11 - 04 Oct 2015    Post subject: Reply with quote
From what you have stated the charging system sounds fine. I would say that your cheap ebay battery is on its last legs.
Yamaha YZF-R6
Paul2129
PostPosted: 22:40 - 04 Oct 2015    Post subject: Reply with quote
Thanks, I'm hoping so. I'll try to make sure I've checked it out first. I guess if I'm seeing 14.4v while the bike is running at all engine speeds then the rest of the charging gear is guess Wink
FlightRisk
PostPosted: 23:51 - 04 Oct 2015    Post subject: Reply with quote
From what I remember;
- check battery voltage with the ignition off
- turn the key so your lights come on
If the battery voltage instantly plummets, it's f***ed > buy a Yuasa > fit & forget.
Honda CB500S
MCN
PostPosted: 00:13 - 05 Oct 2015    Post subject: Reply with quote
14.5ish engine running is good. (More can boil the battery acid)
As said, probably bad battery. YOu should expect to pay about £30 ish
https://www.yuasa.co.uk/
Yuasa is what lots of Proper OEM fit as standard.
If the bike is left for several months then you need to connect a trickle charger to protect your investment.
I use only these now. The others I have used seemed to not last or werent as good at what they are supposed to do.
https://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=2654&utm_source=Google&utm_medium=base&utm_campaign=google-base&gclid=CILm18D4qcgCFQkUwwod-2cNbw
Paul2129
PostPosted: 07:01 - 05 Oct 2015    Post subject: Reply with quote
Brilliant, thanks guys for the replies. I'll test the voltage today, stupid of me to buy a cheap battery, cost more in the long run Sad
SpencerJ This post is not being displayed because the poster is banned. Unhide this post / all posts.
mentalboy
PostPosted: 23:51 - 06 Oct 2015    Post subject: Reply with quote
Don't beat yourself up about it. Bike batteries last best if you are using the machine on a regular basis.
I've had issues with an all-singing and dancing Motobatt AGM that cost a bloody fortune three years ago, it's just been replaced with a cheapie - far better to blow £20 on a battery that'll last two years than £70 on one that lasts three.
The last post was made 10 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 57.47 Kb
