Yamaha YBR Engine light on
fran race
PostPosted: 19:56 - 06 Oct 2015    Post subject: Yamaha YBR Engine light on Reply with quote
hi guys
I have a Yamaha YBR 125 2010. The engine light has come on but it is not flashing, its just a constant light that comes on when I turn the key in the ignition.
The engine light comes on for about 3 seconds then it goes off (all the electrics go off). It has just had a new ignition switch but wondering if its not been put in properly or the connection might be loose?
I can't find a full list of the management codes or what they mean!
many thanks for your help!
fran
fran race
PostPosted: 22:10 - 06 Oct 2015    Post subject: Reply with quote
sorry if I wasn't clear in the original post.
I've left it for a couple of hours and just tried again - all that happens is I turn the engine on, the management light comes on for 3 seconds and then the engine cuts out and the light goes off.
When I got the bike out earlier I hit the ignition button and the engine came on for two seconds then cut out and the management light came on then. I can't remember how long it came on for though because it just started to rain so I decided to put it away anyway.
fran race
PostPosted: 22:25 - 06 Oct 2015    Post subject: Reply with quote
I was just wondering if what I've described above sounds like a flat battery?
fran race
PostPosted: 22:38 - 06 Oct 2015    Post subject: Reply with quote
No, the engine won't run with the lights turned on; I can't eeem to turn the lights off either....
mentalboy
PostPosted: 23:19 - 06 Oct 2015    Post subject: Reply with quote
Quite possibly
PostPosted: 23:30 - 06 Oct 2015    Post subject: Reply with quote
if the electric start can turn the engine over it can run the ECU.
2nd result under 'ybr fault codes'
https://ybr125owner.blogspot.co.uk/2014/06/yamaha-ybr-125-fault-codes.html
Major Doss
PostPosted: 01:05 - 07 Oct 2015    Post subject: Reply with quote
Your engine is not dead, nor leccy's. Pull the battery leads, clean and replace. TIGHTEN!!!!! Shouty tight. Had this a couple of weeks ago. Wink
The last post was made 10 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 49.46 Kb
