Heated vest worth buying?
BBR
PostPosted: 11:18 - 07 Oct 2015    Post subject: Heated vest worth buying? Reply with quote
The older I get the worse I find the cold and been thinking of buying a heated vest.
Not sure if they are any good though.
Anyone using one?
DrSnoosnoo
PostPosted: 11:24 - 07 Oct 2015    Post subject: Reply with quote
I was perusing fc-moto the other day and found one I will be buying.
It's a rechargeable battery kind of jumper for beneath your gear. Works out around 85 spondoolies with three areas of heating elements. I'd like the battery pack because I could guarantee that if I wire myself into the bike, I'll spaz it up and yank it when forgetting.
This is what I'm eyeing up
BBR
PostPosted: 11:31 - 07 Oct 2015    Post subject: Reply with quote
Looks good.
I've been considering a Keis heated vest probably wired into the bike.
DrSnoosnoo
PostPosted: 11:34 - 07 Oct 2015    Post subject: Reply with quote
BBR wrote:
Looks good.
I know someone who has one and he rates it, he says even on the lowest setting it gets him red hot. Your experience may vary.
I'm a bit tight though and when looking for those type of vest, you buy the vest for 120 quid or something and then they say, oh the controller is extra ... that's 25 ponds more please. Oh you want to wire it to your bike? that's an extra 15 ponds (second example may be made up)
PostPosted: 11:48 - 07 Oct 2015    Post subject: Reply with quote
Fnar.
6 x AA (i.e. 4.5V per panel) battery powered heated vest. For example, £25 at Maplin, cheaper ones are doubtless available. I got mine for £7 in a Maplin end-of-season sale.
Lighter socket plug, couple of £££ or from the spares bin.
L78xx 10V regulator, £1.
Bit of old heat sink from a defunct CPU, £0.
Solder, wire, tape, bodge is a good 'un.
yen_powell
PostPosted: 12:12 - 07 Oct 2015    Post subject: Reply with quote
I've had the same one for nearly 18 years and it's been brilliant.
It's one that plugs into the battery via a lead. The lead has been repaired many many times and been on about 6 bikes but the vest is still in good condition.
The vest needs to be quite snug, I wear it over a thin jumper in cold winter weather and between t-shirt and jumper in bloody freezing weather. Nowadays it tends to unzip slowly from the waist up, this is due to middle aged spread and not the vest's fault.
It is like riding to work in front of a lovely log fire!
The vest is also pretty good unplugged as despite being thin it seems to be well insulated. I got one without a collar after trying a mates with one. Too bulky round the neck I found.
Mine was made by Widder who packed up a few years ago, although I believe spares are still available through some long distance riding american nutter club, Iron Butt or similar.
XT1200Z and a DR350 in bits
goto10
PostPosted: 12:16 - 07 Oct 2015    Post subject: Reply with quote
I've had the Keis vest through two winters now (wired to bike) - this will be the third winter, it only warms up the kidneys so don't expect to be warmed up all over - but it _is_ quite effective. (The idea is that it warms your blood up as it passes through the kidneys and then gets pumped around)
I've just bought some Gerbing XR12 heated gloves too - I've yet to try these heated.
INB4 KeepCoreWarmYouDon'tNeedHeatedGear. F'ck that advice in the ear, heated gear FTW.
DrSnoosnoo
PostPosted: 12:24 - 07 Oct 2015    Post subject: Reply with quote
Rogerborg wrote:
Fnar.
Might be something to try! I do have a lighter socket on the bike but I also like the aspect of having a rechargeable battery that leaves me untethered to the bike. Therefore less likely to spack and break it?
I dunno. I'll consider the options!
Accuhaler
PostPosted: 17:18 - 07 Oct 2015    Post subject: Reply with quote
I wouldn't be fushed about my chest being a larger bloke, it;s my arms that get cold.~~
maybe we need heated arm liners too?
edit, after pressing submit it hit me, I only have half lengh arm inner lining.
so ignore this post!
MCN
PostPosted: 18:14 - 07 Oct 2015    Post subject: Reply with quote
Yes they work.
They are a bit of bulk under a jacket.
A couple of merino base layers probably cost the same and are more comfy i.e. take up less bulk.
Look for one that has an element around the neck as Klan do. It is awe-sum when it's switched on.
Pie-Roe
PostPosted: 18:15 - 07 Oct 2015    Post subject: Reply with quote
Something about them overheating your core so your extremities get more heated blood. I'm not entirely sure, but this topic comes up every year about this time.
.. This post is not being displayed because the poster is banned. Unhide this post / all posts.
MCN
PostPosted: 21:58 - 07 Oct 2015    Post subject: Reply with quote
MacGyver wrote:
i wear THIS goose down Gilete/vest worn on outside of leather jacket with THIS as the base layer, torso never gets cold even during a 11hr 722 mile ride Thumbs Up
That's some Melon you've got going on there big yin. Shocked
talkToTheHat
PostPosted: 03:26 - 09 Oct 2015    Post subject: Reply with quote
I have a cheapy 6AA heated vest somewhere. Fleecy high collar means I can't get my textile jacket done up over it. Didn't like. Was always too hot and fiddling with it was difficult. Unless there are controls as easy as heated grips then I would call such a disaster waiting to happen.
Thermal longjohns and thermal vest, long sleeve T-shirt or thick cotton shirt. HG touring jacket, similar style of trousers from ixs. Altberg boots. The only thing that ever gets too cold is my hands and I think this year will be the year I finally do tucano urbano muffs. A tall screen helps too.
Bandit. does. everything.
spnorm
PostPosted: 06:49 - 12 Oct 2015    Post subject: Reply with quote
I was converted to the idea of a heated vest after riding my old R1200RT with heated seats. They really made a difference once the temperature dropped into single figures.
As my new GS LC didn't have heated seats, I bought SWMBO a Keiss heated vest and she loved it, so I didn't miss the opportunity to pick one up for £40 from my local BMW dealers in their sale last spring.
Both our vests heat the back and the chest. Hers also has a heated collar.
They make a massive difference and we stayed warm in Scotland a couple of weeks ago despite the temperature dropping down to 4.5C in the Cairngorms Thumbs Up If you keep your body core warm, it keeps your extremities warmer too. There's no need for loads of bulky layers.
The last post was made 11 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 100.53 Kb
