Bike doesn't stay on after sitting for nearly 2 months. TYG
Kal-El This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
bladeblaster
PostPosted: 12:01 - 07 Oct 2015    Post subject: Reply with quote
is it the same fuel thats been sat in the carbs for 2 months?
Drain the old and put in fresh fuel would be the first port of call.
Minty
PostPosted: 12:08 - 07 Oct 2015    Post subject: Reply with quote
My bike often goes 4-5 months without starting. Have never had a problem with fuel going off.
My fingers smell of your mum.
Minty
PostPosted: 12:09 - 07 Oct 2015    Post subject: Reply with quote
You did turn the fuel tap back on - assuming you may have turned it off before laying it up?
PostPosted: 12:26 - 07 Oct 2015    Post subject: Re: Help. Reply with quote
1) Workshop.
2)
Kal-El wrote:
my bandit
Your Bandit what? 600? 650? 1200?
3) Is it running on all cylinders? Does it sound like any cylinders are giving up before the rest of them?
bladeblaster
PostPosted: 13:12 - 07 Oct 2015    Post subject: Reply with quote
neither have I, but okums razor, and all that.
it could be many things, but if you know you have good fuel to start with, that's the biggest common factor covered.
pompousporcup...
PostPosted: 14:41 - 07 Oct 2015    Post subject: Reply with quote
selling you say. drop me a pm if you do
Kal-El
PostPosted: 15:29 - 07 Oct 2015    Post subject: Reply with quote
It's a bandit 600.
Ok, just tried again.
It turns on, stays on as long as the revs are up. Had the choke on for a few minutes. But the second it goes off it doesn't start again. But if I was to try again tomorrow, it will start up and same thing will happen again.
Looking to get it sorted and sold before I'm off to the US for me holidays!
It says I need a signature, so yeah, here's one.
pompousporcup...
PostPosted: 15:58 - 07 Oct 2015    Post subject: Reply with quote
so it will not start again after it stalls, or do you mean it will not run without the choke..
my guess is not enough fuel getting through due to clogged something or other
DrSnoosnoo
PostPosted: 16:26 - 07 Oct 2015    Post subject: Reply with quote
Possibly not the best, or most technical, suggestion.
If it's been stood, stuff may "glaze" over. If you start 'er up with the choke, for a minute or so, then keep the revs up and turn off the choke, will it keep running?
If it does keep running, I'd be minded to try and ride it down a quiet road, revving the nuts off it, trying to pile fuel through the carbs and decoking anything somewhere.
Now, that is hardly technical but that's what I'd try.
CaNsA
PostPosted: 16:27 - 07 Oct 2015    Post subject: Re: Help. Reply with quote
Kal-El wrote:
Help.
The most hated thread title ever.
bladeblaster
PostPosted: 16:46 - 07 Oct 2015    Post subject: Reply with quote
does it stink of petrol? Could be flooding the carbs due to a sticking float?
hellkat
PostPosted: 16:59 - 07 Oct 2015    Post subject: Re: Help. Reply with quote
CaNsA wrote:
Kal-El wrote:
Help.
Police Police
Police Police
And also, even worse if it were in the correct forum (WORKSHOP)
Shocked
(not least of all because it makes me start singing old Beatles songs)
OP Praying please Praying change title of your thread and then put in an order (in triplicate) for the mods to move thread to the relevant forum.
Thanking you Laughing
Val
PostPosted: 22:22 - 07 Oct 2015    Post subject: Re: Help. Reply with quote
And now I can't get rid of this song either Laughing
Seriously guys make next title more detailed like:
Help...I need somebody...help
MCN
PostPosted: 22:34 - 07 Oct 2015    Post subject: Reply with quote
Is there an in-line fuel filter on the bike?
If it was sitting any shit in the tank could have gelled in the matrix.
Fit a new filter and try.
If it starts and then runs down it's a sign that it's starved of fuel.
Once it stops fuel can trickle through any blockage to re-fill the float chamber again.
My money if on blocked fuel system.
I don't know of fuel getting 'old' but I do know fuel filters plug is there is no regular flow through them.
You can try to by-pass any fuel filter and direct feed fuel via a bit of hose from a fuel can. If it's only a gravity feed then it should prove disprove a fuel blockage. Without having to gut the fuel system.
mentalboy
PostPosted: 23:08 - 07 Oct 2015    Post subject: Reply with quote
^^^What 'e said
Kal-El
PostPosted: 16:47 - 11 Oct 2015    Post subject: Reply with quote
It will stay on choke for a while but will slowly decrease in revs and turn off. Then it doesn't turn on until tomorrow or after a significant amount of time has passed.
You may as well be talking chinese to me as I'm quite the noob when it comes to mechanics.
I guess I could try changing the air filter. See if that works.
I called up a local mechanic and he said it could be the carbs that need cleaning. (He said £200 minimum to fix it :/)
Do you think it could be the a2 restriction that caused the issue?
Can someone in London or around the kent area come and fix it for me lol, will give you £50 for your troubles.
I've spent more on the bike than I bought it for. Before next summer comes, i'm getting a ducati 696 or any newer bike that I know won't break down. My R125 would sit for ages and the only issue would be a dead battery.
SQL
PostPosted: 16:53 - 11 Oct 2015    Post subject: Reply with quote
you look close where you based?
Kal-El
PostPosted: 16:54 - 11 Oct 2015    Post subject: Reply with quote
Blackheath/Greenwich
SQL
PostPosted: 16:55 - 11 Oct 2015    Post subject: Reply with quote
Once you have it started have you tried taking it for a run? are you starting it in neutral?
Kal-El
PostPosted: 16:58 - 11 Oct 2015    Post subject: Reply with quote
Tried taking it for a run, did work briefly before cutting off. Yeah I'm starting in neutral. I'm not that silly not to Razz
SQL
PostPosted: 17:03 - 11 Oct 2015    Post subject: Reply with quote
Start bike with full choke, let it idle at 3k for about 30sec then move to half choke, go for a ride after 5-10mins turn choke off, (Near your house obviously) see how long until it cuts out.
Open fuel cap check for vacuum noises, check the airbox drain plug. if none of that works check the airfilter and the colour of the sparkplugs. post pics here
Bezzer
PostPosted: 17:07 - 11 Oct 2015    Post subject: Reply with quote
. Might be the tap playing up because of a loose vacuum line or the tap diaphragm. Bandit taps aren't that good, turn it to PRIme and see if it runs longer, duff tap can just allow fuel to dribble through overnight and fill the carb bowls so it can run for a short while each day. I've had a similar problem in the past and it was the vacuum pipe half hanging off the tap, just had to run it home on Prime as it'a bit of a bitch to get at without lifting the tank on a Bandit.
Kris
PostPosted: 21:19 - 11 Oct 2015    Post subject: Reply with quote
Fucked battery.
Next!
www.prisonplanet.com
Suntan Sid
PostPosted: 22:29 - 11 Oct 2015    Post subject: Reply with quote
No one else has mentioned it, try starting and running it with the petrol cap open, it would rule out a blocked breather, if nothing else.
The last post was made 10 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 131.16 Kb
