DTR 125 1997-1998 helllllp pleaseee
Dansaunders10...
PostPosted: 20:36 - 07 Oct 2015    Post subject: DTR 125 1997-1998 helllllp pleaseee Reply with quote
Right I've just got the bike and it wasn't sparking fixed that with a new coil but now when I turn the ignition on I don't get the power valve noise when it cleans and tests its self just silent also bike it still stripped down ie no carb or tank but all connected up and everything works as it should after hours of tapeing up wires beautiful bike though pics will follow if any ones interested also I'm pretty new to forms so if I make a mistake pick me up on it thanks people.Dan brighton
Dan
redeem ouzzer
PostPosted: 20:38 - 07 Oct 2015    Post subject: Reply with quote
Did the servo work before the sparking issue?
Dansaunders10...
PostPosted: 14:11 - 09 Oct 2015    Post subject: Reply with quote
[quote="mpd72"]Disconnect the cables or pulley at the top and see if it turns on the key. Could be a sized PV or cables on back to front.[/quoti will check that my friend thanks for the reply I've been pulling my hair out all day with this bike I thought I had a spark but it was the light bulb at the front making a bit light when kicked in a dark garage so no spark Sad just spent 4 houres on bike and no spark I've got new coil think it's earthed right as new one only has one spade for the orange wire from cdi other one had 2 but yeah no spark checked pick up all looks good coil in fly wheel looks good just running out of idears only had it a week and haven't started it yet Sad poor bikes in parts any help you can give me or if you want to make a few vids for YouTube of the bike I've got a Haynes manual bit not very good with electrics just don't want to throw money at a mechanic Sad .dan
Dan
Old Git Racing
PostPosted: 17:17 - 09 Oct 2015    Post subject: Reply with quote
Check the battery first, powervalves don't cycle if it's flat.
OGR
Ariel Badger
PostPosted: 18:30 - 09 Oct 2015    Post subject: Re: DTR 125 1997-1998 helllllp pleaseee Reply with quote
Dansaunders1000 wrote:
Right I've just got the bike and it wasn't sparking fixed that with a new coil but now when I turn the ignition on I don't get the power valve noise when it cleans and tests its self just silent also bike it still stripped down ie no carb or tank but all connected up and everything works as it should after hours of taping up wires beautiful bike though pics will follow if any ones interested also I'm pretty new to forms so if I make a mistake pick me up on it thanks people.Dan brighton
Well I will pick you up on a few points because you asked. Use more punctuation, Brighton has a capital B and there should be a space between your full stop and Dan, by "forms" i take it you mean "forums". On a positive note though I do like your use of the apostrophe.
redeem ouzzer This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
The last post was made 10 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 52.03 Kb
