Total cost for diy total LED upgrade?
Ribenapigeon
PostPosted: 14:51 - 08 Oct 2015    Post subject: Total cost for diy total LED upgrade? Reply with quote
How much to completely upgrade a bike to LED's ? How much hassle is it and what are the best quality parts to use?
Cheers.
MCN
PostPosted: 15:49 - 08 Oct 2015    Post subject: Reply with quote
Entirely dependent on how cheap/classy you are.
Not that much hassle apart from the headlamps. Most incandescent lamps have simple replacement LEDs.
But a sound idea.
RhynoCZ
PostPosted: 16:08 - 08 Oct 2015    Post subject: Reply with quote
It's cheap, BUT I'd still keep traditional bulbs for the head lights. If you're gonna use LED bulbs for the tail light, make sure they are 350lm+. The replacement for the 5W bulbs in the clocks is cheap as well. Thumbs Up
PostPosted: 16:10 - 08 Oct 2015    Post subject: Reply with quote
In my experience. The "cluster" type of LED bulb do not last any longer than standard filament types.
They are prone to corrosion and sensitive to vibration.
They are also horribly directional (so a tail light one is only properly visile from directly behind).
I had LED stop and tails fitted to my VFR and after 6 months shit-canned them in favour of standard, good quality (named brand) filament bulbs again.
So avoid this type:
https://www.rimmerbros.co.uk/ItemImages/Large/GLB380LED-RED.jpg
Surface mount ones ought to be better but I'd want them potted/ sealed and I'd want them with angled/side mounted LEDs as well as pointing straight back.
Also be aware dash LEDs can be pretty sensitive to very low current leakage. My main beam warming glows dimly in wet conditions if the headlight is on. I presume due to moisture in the switch/relay.
Why do you want LEDs on your XJ6? I'd have thought it would provide ample power for all it's electrical requirements along with a few extras?
Matt B
PostPosted: 16:11 - 08 Oct 2015    Post subject: Reply with quote
Exactly what I was just about to ask. Why?
Ribenapigeon
PostPosted: 16:20 - 08 Oct 2015    Post subject: Reply with quote
I was under the impression LED's are brighter for less drain on the electrical system, more reliable and longer lasting. If that's not the case I'll stick with standard, though id like brighter headlights.
RhynoCZ
PostPosted: 16:24 - 08 Oct 2015    Post subject: Reply with quote
More bright, less drain, yes. More reliable, it depends. I have got LED bulbs in my tail light, 2000 miles done, worked great so far. The reason I went for LEDs was to reduce the drain during braking. Traditional bulbs made my headlight go dim. My mate used small LEDs in interior of his car and the car did many many thousands of miles. If you count all the 5W bulbs that are there, knowing the LED alternative needs about 1.5W, you get yourself a considerable amount of power saved. Wink
https://obd.tui21.com/img/tui21201333215056734.jpg
PostPosted: 16:40 - 08 Oct 2015    Post subject: Reply with quote
They draw less current certainly. But that's not going to make your headlight brighter unless you up the wattage well beyond that it's got fitted already (at which point you may need to consider uprating the wiring leading to it and it would be illegal at a level that would be overloading your charging system anyway) or fit additional lights.
LEDs are not necessarily brighter. Depends on the LED.
Where I have used them before was to free up current to fit auxilliary lighting (I had some VERY silly headlights on my MZ street moto).
I personally think LEDs as a headlamp have a ways to go yet.
I fitted some good quality, brand name headlight bulbs to my VFR and they made an enormous difference. Bosch +90s as I recall.
A GOOD reason to fit a (sufficiently bright and visible) LED lamp on your bike would be for the brake light. AN LED will come on 0.2 seconds sooner than a tungsten filament. At motorway speeds, you've travelled 6.3 metres in that time.
MCN
PostPosted: 16:41 - 08 Oct 2015    Post subject: Reply with quote
If you pay cheap you get cheap is a rule of thumb.
Look for warranty on the lamps.
I replaced the trailer lights on my bike trailer with LED units. less than half the thickness so are better protected and the bulb warning in the car is happier. Ever time I connected the plug to the car I got a failed bulb warning. No hassle now.
OEM LED units are normally a better job than 'cheap' after market upgrades. I replaced my tail light with LED years ago but the light as Stinkers says is very directional.
There was some rule that tail lights but show visible light through a 180º arc. Not sure the PoPo or an MOT guy would notice though.
RhynoCZ
PostPosted: 17:26 - 08 Oct 2015    Post subject: Reply with quote
The problem I had was the draw when I applied the brakes. The headlights went dim only about 10-15%, yet it was annoying at night.
Matt B
PostPosted: 08:56 - 09 Oct 2015    Post subject: Reply with quote
What about some uprated bulbs like Osram Night Breakers?
sickpup
Old Timer
PostPosted: 09:57 - 09 Oct 2015    Post subject: Reply with quote
Changing everything for LEDs could cause the reg/rec to fail prematurely.
Ribenapigeon
PostPosted: 10:04 - 09 Oct 2015    Post subject: Reply with quote
How come? I thought it would mean less stress on the reg/rec.
sickpup
Old Timer
PostPosted: 10:10 - 09 Oct 2015    Post subject: Reply with quote
Charging system is designed to produce a certain output at a certain engine speed. Use less power and the generator still produces the same output that has to be disposed of as heat, heat from the reg/rec.
PostPosted: 11:19 - 09 Oct 2015    Post subject: Reply with quote
As sickpup says.
I run with the headlight on in daytime on my VFR, not so much to be seen as to take load off the reg/rec.
A switch-mode reg/rec wouldn't be as prone to the same issues but looking on ebay, an XJ6n has an SH type which does dissipate excess current as heat.
@ RhynoCZ. Assuming you were on a modern japanese bike with a 3-phase alternator, it sounds like you had some other issue there. Either with alternator output or your wiring. The brake light shouldn't be dippng the headlamp. Manufacturers have a tendancy to push the limits to the bare minimum with wiring thicknesses which, after a few years and a build-up of corrosion on terminals and (especially) switches, can lead to significant resistance in the circuit.
Amazing the difference bunging a couple of relays in to control the lighting circuit can make on older bikes with DC lighting (both Japanese and others. Works REALLY well on old MZs).
Quick job. You run a relatively heavy twin-core wire up to the back of the headlights direct from the battery and main frame earth. Hook them into a single-throw, normally off, fused relay (ideally with a diode, you sometimes get an earth feedback-loop causing them to "latch" otherwise) and use the dipped headlamp to switch it. Have the output from this feeding into a changeover relay and use the high-beam output to switch it. The outputs from the changeover relay go to the bulb.
This isn't helping the OP who I suspect should simply check the aim of his headlamp and consider upgrading his bulb.
Ribenapigeon
PostPosted: 13:35 - 09 Oct 2015    Post subject: Reply with quote
Yeah, I'm just going to upgrade the bulb, seems the best option.
smegballs
PostPosted: 17:08 - 09 Oct 2015    Post subject: Reply with quote
stinkwheel wrote:
beware old thin wires
This.
I have a voltmeter on my dash that draws off the pilot light feed.
On sidelights it reads 14.1V
With headlights on it reads 13.6V
Headlights and brake light is down to 13.2V
Yet a multimeter across the battery shows a nice 14.4V under all conditions*.
Due to the non-linerarity of headlight voltage to brightness, use of relays to get that missing 0.8V to the bulb could well make the world of difference.
Back on topic, I switched my lights to led, in order to get the headroom to go from a 35W headlight to a 55W one.
*R/R is hardwired to the battery terminals with doubled up 10G for pos and neg, so about as good as connection as you will get.
ADSrox0r
PostPosted: 19:05 - 09 Oct 2015    Post subject: Reply with quote
I've been on a bit of a journey with bulb 'upgrades' of late and I can tell you, LED technology just isn't quite there yet. If you want as good as it gets, buy a set of Cyclops 3800 lumen fan cooled jobbies if they'll fit. Even then they're still not as good for night projection as decent halogens such as Nightbreakers.
In the end, I chucked HIDs in with the new H7'R' type bulbs that cut a lot of the glare out of reflector lens fittings.
The last post was made 11 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 103.28 Kb
