| MrHash |
 MrHash Derestricted Danger
 Posted: 09:07 - 09 Oct 2015 Post subject: Waterproof shell jackets |
Hello, I'm a relatively new rider getting my gear sorted out. I like the idea of layering for flexibility, utility, and comfort, as opposed to a one-jacket-does-all kind of approach. With that in mind, I'm planning on using a merino base layer, possibly mid-layer fleece if needed, an armoured shirt such as the forcefield pro or knox urbane, and an outer shell.
I'm finding it a bit tricky to find a suitable outer shell which offers both gore tex like breathability with road abrasion resistance. The technology does exist as it is used in many textile jackets. There are very good (expensive) tough shells out there such as the Arc'teryx Alpha/Beta but it seems a bit harder to find a good breathable lightweight leather or textile shell.
What would you recommend? Should i look for a lightweight armoured jacket and just remove the armour? Or just use non-road specific outers?
thanks  |
| Matt B |
 Matt B World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:57 - 09 Oct 2015 Post subject: |
Urgh, layers and layers and layers at the beginning and end of a ride.
There's a reason that jackets with abrasion + impact + water + thermal layers are popular. ____________________ Biking is 1/20th as dangerous as horse riding.
| chris-red |
| MrHash |
| grr666 |
 grr666 Super Spammer
 Posted: 10:31 - 09 Oct 2015 Post subject: |
My Richa textile 3 season jacket was 30 quid second hand from ebay.
I wear that more than anything else I have, and there's a LOT of choice in my wardrobe. Armour x5, hi spec
abrasion tested nylon, thermal zip in inner and separate zip in waterproof sections. It can be worn in
any combination of the 3 pieces. The jacket also has mesh panels and useful reflecty details, zipping pockets
inside and out which I also like. I even took the armour out of it and took it on holiday to New Zealand last year.
It was a perfect jacket for somewhere like that with rapidly changing weather and it meant I never needed
to pack several coats either (think touring). While there, I wore it while mountain biking, on aerial ziplines all harnessed up,
for many miles of hiking and even on a tarmac luge one time too and suffered no discomfort or restriction of
movement. It kept me warm, cool and dry whenever it needed to.
Best 30 quid I've spent on gear, good kit needn't cost a packet. If you put in just a little legwork, deals are there to be had. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.
| Matt B |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:38 - 09 Oct 2015 Post subject: |
| MrHash wrote: | I don't see the problem with layers. |
Time at the start and end of your rides.
Maybe not a problem if you're riding for pleasure and leisure, but it's a pain on a daily commute.
| MrHash wrote: | It's convenient |
Throwing on one jacket is far more convenient.
Yes.
| MrHash wrote: | comfortable |
Eh.
| MrHash wrote: | especially when I am in hotter climates. |
You're asking this in October. You can take the thermal layer out of any decent jacket, and open vents.
Thing is, I do sort of agree with you and have a vast wardrobe of bits and pieces that I mix and match because fashionista.
But for a first purchase, in October, I would suggest my default go-to jacket: heavy cordura, with armour, a water "proof" layer and a removable thermal layer.
There's no right or wrong answer, of course, it's a very personal choice. You don't have to persuade us any more than we can persuade you.  ____________________ Biking is 1/20th as dangerous as horse riding.
| stinkwheel |
 Posted: 10:53 - 09 Oct 2015 Post subject: |
Normal leather jacket. Warm stuff under it if it's cold. Throw a pacamac over the top if it's raining. (although a cag in a bag is better, no zip).
Not so dumb as it sounds.
Forgo the waterproofs altogether unless it's raining enough to make you wet rather than damp.
I've recently been wearing merino base with fleece or wool insulating layer then a leather jacket over the top and carrying a waterproof layer (but mostly not wearing it unless it sets in for some "proper" rain I cant see stopping). I've arrived dry where others in the group have arrived damp in their waterproof textiles or all-in-one romper suits. I presume the combination of wicking and airflow in my gear has allowed the damp to disperse as quick as it arrived.
My base layers are merino T-shirts which I can keep on all day. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MrHash |
 Posted: 10:56 - 09 Oct 2015 Post subject: |
Just to be clear, of course I would need a heavy duty abrasion resistant top layer. I think i'll only be commuting occasionally, not every day so my use case is more casual.
It looks like the more complete jackets are their own layering systems anyway so maybe it makes sense to find a suitable all-in-one and layer it as required.. I guess i just like the idea of total control of all the layers of what i'm wearing  |
| MrHash |
| MrHash |
 Posted: 13:44 - 09 Oct 2015 Post subject: |
Ok so after some research, it occurs to me the best solution may be to use a summer leather jacket and remove the armour if i need. Also A*'s Rideout collection has some technical shells, so there are several options. Thanks all for the advice!  |
The last post was made 11 years, 37 days ago. Instead of replying here, would creating a new thread be more useful? |
