1975 Kh100 starting problems
bratwurst
PostPosted: 14:22 - 08 Oct 2015    Post subject: 1975 Kh100 starting problems Reply with quote
i have a 75' Kawasaki KH100 that i cannot get started for the life of me. everything is checking out as far as mechanical goes. Carb float is not sticking, bowl was clean and not gunked up. fuel lines are ok. petcock is functional i am aware that these can be a problem on kawa's. the only thing is electrical.
on the controls, there is a on and off switch for the engine. i think the guy who had it before me tried to short cut the ignition system by only making the handlebar controls work. Only thing is when i test for spark it gives me an OKish spark on the ON and OFF position.
It will not start with choke on/bump start. ive tried different gas mixtures and nothing. the only way it will start is if gas is put directly into the engine cylinder and only for a few seconds.
Is there a problem with the electrical thats preventing the bike from running? points/timing? Crying or Very sad
this is my first two stroke road bike. i've had a few other hondas before never had problems like this. any help is great
low budget warrior
Oldie
PostPosted: 18:27 - 08 Oct 2015    Post subject: Reply with quote
Always best to start off with new plugs. Cheap first step.
stevo as b4
PostPosted: 18:37 - 08 Oct 2015    Post subject: Reply with quote
Have you checked what sort of compression pressure your seeing?
the other possibilities if the carb really is clean and fuel flow is ok, as well as the spark looking good are:
1, Crank shaft oil seals may have perished if it's been stored. You won't get any primary compression in that case to draw up fuel/air into the cylinder.
2, The Disc valve could not be sealing or it could be mistimed on the crank possibly?
3, The spark that looks ok, could be weak and breaking down under compression pressure?
Have you had the carb off for an ultrasonic clean and or blow out of all the jets etc? It'd be worth re-checking all the simple things first, before you strip the motor, but a loss of primary compression or an air leak is only really easy to find with a leak down test, which is something you could probably rig up with an air line, some adapter's and gauge etc?
temeluchus
PostPosted: 19:02 - 08 Oct 2015    Post subject: Reply with quote
My KH100 would refuse to start and need the points adjusting regularly.
bratwurst
PostPosted: 15:30 - 09 Oct 2015    Post subject: Reply with quote
i threw a new plug in it, it looks like there were some abrasions on the plug electrode. like the piston was hitting it. fuel mixture on it too.
anther thing when i kick it over it seems to makes a squeaking sound sometimes. not sure why this is.
Rebuilt the carb again sprayed some cleaner through jets. when i tested to see if the carb was blowing out gas air mixture. it sucked in and then blew out on reset of the piston? im totally lost i think its valves maybe.
Evil or Very Mad
low budget warrior
bratwurst
PostPosted: 17:49 - 09 Oct 2015    Post subject: Reply with quote
[quote="Vincent"]Got a photo of that spark plug? Has the bike been standing? They're not bad little bikes these, if you find it needs engine work, and the rest of the bike is in good nick, I'd get it done. Once sorted, it'll keep going for years. If you're finding it hard to get a spark, you'll need to check the output on the high voltage ignition coil behind the points. There's two there, one for the ignition and one for the lights, IIRC, they both tend to degrade with age.
the plug it seemed there was some graphite colored grainy residue on the electrode it was not wet with fuel/oil. Can't get a picture to work right now
low budget warrior
bratwurst
PostPosted: 18:42 - 09 Oct 2015    Post subject: Reply with quote
low budget warrior
bratwurst
PostPosted: 00:07 - 12 Oct 2015    Post subject: Reply with quote
Ok update. Got it running! But not ideally it seemed to increase revs with the choke off and no throttle. Not fast like an air leak but slower like Predetonation or something? Not sure fuel mix too rich? Any help is great
low budget warrior
bratwurst
PostPosted: 22:59 - 12 Oct 2015    Post subject: Reply with quote
Vincent wrote:
Are you getting plenty of smoke coming out of the exhaust?
yes actually alot of smoke from the exhaust.
started it today and the revs increased rapidly like an air leak or something
low budget warrior
The last post was made 11 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.16 - MySQL Queries: 13 - Page Size: 78.94 Kb
