Blackbird not reving past 4000 revs..???
troyboy37
PostPosted: 17:13 - 12 Oct 2015    Post subject: Blackbird not reving past 4000 revs..??? Reply with quote
Hi Guys, heres my problem..!!
have a 97 carb bird, the last time I rode her was mid sept, with a little surging as per usual but no problems...
I took her out on Sunday and she stuggled to get a wriggle on... not reving very well.. and struggling to get past 75mph..
Today, I took the tank and air filter housing off..
Checked the plugs (these were fitted in May) the first 3 were normal, but no. 4 was slighly oily..
I balanced the carbs today, with a make do tank and carbs were balanced..
However.....
When I rev'd the bike she only went to 4000 revs then died ... i kept reving her but she wouldnt go past 4000 revs..
When I held the throttle open she went to 4000 revs then dies back to 2000 revs, then went back up to 4000 revs, and back down to 2000.. and so on...
Any ideas guys as I dont know what to do next..???
Yam FundaAce
temeluchus
PostPosted: 19:55 - 12 Oct 2015    Post subject: Reply with quote
Did you drain the float bowls?
Hose to the vacuum tap ok?
Scythe
PostPosted: 20:07 - 12 Oct 2015    Post subject: Reply with quote
My SV did this after a winter lay up, turns out the HT lead had broken down. Check your sparks.
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
Ariel Badger
PostPosted: 22:37 - 12 Oct 2015    Post subject: Reply with quote
You can rule out a lot of problems as it is a four cylinder motor and a simple thing like a single ht lead or a blocked jet would not give such a huge drop in performance. It has to be a common problem to all four pots, is fuel getting to the carbs in a sufficient flow? The ignition will be controlled by a computer of some kind, is it borked, can it be remapped?
How good is your fuel, have you put diesel in it (my mate did)? Is the tank vent clear?
troyboy37
PostPosted: 09:47 - 13 Oct 2015    Post subject: Reply with quote
No diesel in it.. all the hoses under the tank were connected correctly, What I forgot to say was, that on the morning of the ride I had a flat battery and jump started it with my wifes car (Kia Picanto)..
I wonder if this any issues...??
Yam FundaAce
sickpup
Old Timer
PostPosted: 10:14 - 13 Oct 2015    Post subject: Reply with quote
Yes a dead battery can cause odd faults, charge fully and see if it still happens.
troyboy37
PostPosted: 11:21 - 13 Oct 2015    Post subject: Reply with quote
it started this morning OK, Gunna charge it and then see if anything improves..
Yam FundaAce
troyboy37
PostPosted: 19:59 - 13 Oct 2015    Post subject: Reply with quote
So far checked the filter and petcock.. all good..
Battery charged, and all put back together..
Took her for a test ride all seemed good initially.. but then under load when I hit the higher revs it started to sound like it was running on 3 and struggled to keep in the higher revs.
I'm thinking coils or plugs..?? Question Rolling Eyes
Yam FundaAce
temeluchus
PostPosted: 23:29 - 13 Oct 2015    Post subject: Reply with quote
Looks like the HT leads are removable. Pop them off the coils and take the caps off to inspect for rot.
Fizzer Thou
PostPosted: 09:44 - 14 Oct 2015    Post subject: Reply with quote
If I leave the Exup for any longer than a week without using it then I am pretty sure that condensation forms in the float chamber.It takes some time for it to dissipate once the engine has been run for a while,but I do get similar running problems.
Super unleaded is supposed to lessen the possibility of condensation as some super fuels have less biofuel than ordinary unleaded.
Always have a 'Plan B'
The last post was made 10 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 64.38 Kb
