Battery completely dead after about 4 weeks?
EazyDuz
PostPosted: 18:08 - 12 Oct 2015    Post subject: Battery completely dead after about 4 weeks? Reply with quote
I just happened to walk in the garage and could hear a feint clicking noise coming from the alarm.
Pressed the alarm button on the fob and nothing. Turned the ignition and nothing, not even the dash light lit up.
Put it on charge and will see what happens.
Question is why is it dead? I have nothing connected the the batt apart from a USB socket with a single blue LED inside it, a 12v socket with nothing plugged into it and a charge lead with nothing plugged in.
I do have a simple alarm wired to the batt, this one:
https://www.ebay.co.uk/itm/EASY-FIT-Motorcycle-Motorbike-bike-Scooter-Trike-Quad-Alarm-2-wire-connection-/191021841479?hash=item2c79c9fc47
However it wasn't armed.
Is it likely the alarm slowly drained the battery? And also is the battery fucked beyond repair? I've put it on charge now.
doggone
PostPosted: 18:21 - 12 Oct 2015    Post subject: Reply with quote
The alarm might well have drained it in four weeks without use.
It's not good for batteries to be drained completely, but if they do go right down for a short period it might not be a disaster.
It will probably still work but life expectacy will have reduced almost for sure.
Ariel Badger
PostPosted: 18:44 - 12 Oct 2015    Post subject: Reply with quote
Alarm has drained it.
sickpup
Old Timer
PostPosted: 23:54 - 12 Oct 2015    Post subject: Reply with quote
I agree. The NCS cheap alarms can kill a YTX9-BS in under 2 weeks armed or disarmed and a YTX12-BS in 3 weeks.
davebike
PostPosted: 08:19 - 13 Oct 2015    Post subject: Reply with quote
Most even god alarms will kill a battery in a mater of weeks
If you lay up a bike with an Alarm you need to charge it weekly or disconnect the battery and risk bricking the alarm
Dave
NC750Xdct + others at work !
[email protected]
doggone
PostPosted: 08:36 - 13 Oct 2015    Post subject: Reply with quote
Or fit a trickle charger you can easily connect, and leave on if not using it more than a few days.
sickpup
Old Timer
PostPosted: 09:03 - 13 Oct 2015    Post subject: Reply with quote
I disagree. A Data-tool S3 will not kill a YTX9-BS battery in 4 weeks yet an NCS Cyclone will kill a larger YTX12-BS in 3.
Bikeless
PostPosted: 09:29 - 13 Oct 2015    Post subject: Reply with quote
Find out what the current draw of the alarm is and compare it to your battery amperage, odds on alarm has drained it, fit a trickle charger. When i had a sola alarm on one of my bikes, i would just attach the optimate every couple of weeks till it was full.
talkToTheHat
PostPosted: 10:12 - 13 Oct 2015    Post subject: Reply with quote
Find out current draw of USB socket, that will be 5v so there's some kind of voltage reduction gubbins going on. If it's busy converting excess voltage to heat at say 1w, you'll soon have a flat battery. Wire in an accessory relay. I have one that kills my USB and my heated grips when I turn the bike off.
Bandit. does. everything.
MCN
PostPosted: 13:22 - 13 Oct 2015    Post subject: Reply with quote
AVO-meter between pos battery post and pos lead. Everything switched off and see how many amps are been eaten by something.
Disconnect the something you think is eating amps.
See if amps are still being eaten.
Buying and connecting a battery conditioner when the bike is laid up is recommended.
PostPosted: 14:06 - 13 Oct 2015    Post subject: Reply with quote
Must admit, the NCS alarms are very hungry, even on my Triples nice battery its draining it well Laughing
The last post was made 10 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 68.2 Kb
