Suzuki Bandit GS600F Rev counter and instrument lights
kristoff01
PostPosted: 01:20 - 03 May 2006    Post subject: Suzuki Bandit GS600F Rev counter and instrument lights Reply with quote
Hi all, just bought a 97, 600 bandit which has been in storage for the last 5 years, in the process of putting it back on the road.
I'm having a problem with the rev counter not working nor the neutral light or oil pressure light. I've checked the fuses and bulbs all is ok. These items are on the same circuit as the indicators and they are working fine. Any ideas before I start disecting the wiring loom?
Thanks
Kris.
BanditsHigh
Worse than a woman
PostPosted: 08:20 - 03 May 2006    Post subject: Reply with quote
Sounds like a dodgy connection to me ... I'd take the connectors apart, squirt them with WD40 and put them back together ... should sort the problem.
All the best ... Barry
There is a gap of 9 years, 165 days between these two posts...
profjono
PostPosted: 10:36 - 13 Oct 2015    Post subject: Reply with quote
I have the same problem and tried this but it made no difference. Any other suggestions?
mudcow007
PostPosted: 11:08 - 13 Oct 2015    Post subject: Reply with quote
got a multimeter?
profjono
PostPosted: 11:16 - 13 Oct 2015    Post subject: Reply with quote
Unfortunately not.
If I did have one, what should I do?
PostPosted: 17:12 - 13 Oct 2015    Post subject: Reply with quote
There's a large earth junction in the loom up at the headlight that can only be found by un-taping the wiring loom. This sometimes rots and the wires break loose, especially if the bike is or has been fitted with different headlights. Normally it's protected by being inside the headlight bowl but fitting smaller lights leaves it exposed to the elements and damp gets in.
profjono
PostPosted: 19:01 - 13 Oct 2015    Post subject: Reply with quote
Thanks Pete,
I will check that in a few days.
Paul
The last post was made 10 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 49.8 Kb
