Reg Plates Legality / Exhaust Heat Issue
Jayy
Mr. Ponzi
PostPosted: 18:14 - 13 Oct 2015    Post subject: Reg Plates Legality / Exhaust Heat Issue Reply with quote
https://i.imgur.com/eRRcOhM.jpg
Right, I just fitted a tail tidy kit (indicator unit not fitted in this photo) and the plate mounts really close the the big exhaust loop directly behind it.
This is a very American thing the way the plate mounts down there as I ordered this kit from America (Indicator unit & plate mount). My understanding is, they mostly use metal reg plates over there?
My only concern is when I got back and touched the plate, it was stupidly hot, to the point that I could wiggle the plate and it felt like jelly.
What is the actual law on plates (other than legal size), i.e. Do I have to have that yellow reflective surface on the back? Can I get a metal plate made up?
finniee
PostPosted: 18:21 - 13 Oct 2015    Post subject: Reply with quote
Hopefully this helps https://www.pepipoo.com/forums/lofiversion/index.php/t90123.html
It's for cars but I believe it is the same for motorcycles and pressed plates are not legal in the UK.
Honda CBF125
sickpup
Old Timer
PostPosted: 19:02 - 13 Oct 2015    Post subject: Reply with quote
That link says they are as long as they meet the relevant legislation.
SQL
PostPosted: 19:03 - 13 Oct 2015    Post subject: Reply with quote
back the plate with metal?
Jayy
Mr. Ponzi
PostPosted: 19:11 - 13 Oct 2015    Post subject: Reply with quote
Interesting read, seems that you can use metal plates as long as they meet them standards.
A guy a few posts down mentions there's specific rules for where to mount a plate as well, I wonder if mine is legal or not?
Going to all this effort only to have a 7x5 plate, which isn't legal anyway Laughing But in saying that, I have been riding around for years with 7x5 plates and never been pulled up about it.
Jayy
Mr. Ponzi
PostPosted: 19:12 - 13 Oct 2015    Post subject: Reply with quote
Wouldn't that just do the same thing as now by turning the backed metal in to a grill?
Just been and checked it now it has cooled right down and the plate has slightly warped already and a small bubble at the bottom. I can see this being completely fucked after several more outings.
SQL
PostPosted: 19:15 - 13 Oct 2015    Post subject: Reply with quote
back it with some kind of heat proof material, I have had a similar issue on a pitbike, backed it with a bit of ally sheet and it was fine.
Jayy
Mr. Ponzi
PostPosted: 19:33 - 13 Oct 2015    Post subject: Reply with quote
I found these: https://www.ebay.co.uk/itm/8-x-7-Motorbike-Motorcycle-Bike-Aluminium-Metal-PRESSED-Number-Plate-GIFTS-/291553566898?
He said he can do 7 x 5 with no black border
finniee
PostPosted: 19:37 - 13 Oct 2015    Post subject: Reply with quote
All seems legal but from what I understand of what i read it needs to be made from a reflective yellow, I don't know if metal pressed plates are going to be reflective as the plastic ones.
Honda CBF125
PostPosted: 21:29 - 13 Oct 2015    Post subject: Reply with quote
There's all sorts of stupidly detailed regulations about what reg. plates can be made of.
Including how much spring and deflection they have when supported on one end with a weight on the other.
Long story short. Metal can't possibly comply. It either premanantly bends too easily or is too stiff.
Nothing saying what you put behind your plate though. I'd suggest a piece of silicone matting.
PostPosted: 21:47 - 13 Oct 2015    Post subject: Reply with quote
So anyway I was sitting behind a Maibatsu CockThruster pickup today sporting a tiny plate completely devoid of BS AU 145d mark or maker's info, with a bold hexagon background and miniscule mostly hollow letters spelling out "L6 FKR" or similar and in conclusion you're massively over-thinking this.
J.M.
PostPosted: 22:07 - 13 Oct 2015    Post subject: Reply with quote
Have to agree with Rogerborg. So long as your plate looks legal, who is really going to question it?
2004 R1 & 2018 XSR900
Undinist
PostPosted: 22:43 - 13 Oct 2015    Post subject: Reply with quote
Here's a road legal metal one for bikes https://r.ebay.com/7CN7RP
Current bike: K1100RS. Previous: CD200, GSX250, GT550, VFR750, K100LT, K1100LT, R1100GS, R1150GS, ZZR1100, Hayabusa, RSV Mille, MV F4 750S, R1, ZX-10, KTM Adventure 950S
PostPosted: 23:28 - 13 Oct 2015    Post subject: Reply with quote
Unfortunately. Like many things on ebay. It's not what it proports to be. That is not a legal plate.
It would be legal if already fitted to a motorcycle manufactured before a certain date which I can't be bothered to look up (but go pre-'65 and you can effectively tip-ex it onto the back mudguard).
It's not legal as-is for either fitment to a modern bike OR as a replacement numberplate. Has to be retroreflective. Effectively has to be perspex/polycarbonate (because they're the only things that conform to the material specifications) and must have the makers name and postcode displayed across the bottom fo the plate.
What they have there is a "show plate". Something most makers of such things have enough common sense to advertise them as.
There will be other issues
Matt B
PostPosted: 08:47 - 14 Oct 2015    Post subject: Reply with quote
Put the metal one on if you want. Move on with life.
When it comes to MOT time do what needs to be done - full size plate, stick on reflector etc. Get home, swap it all back Thumbs Up I practice the number plate shuffle every year.
The Disapproving Brit
PostPosted: 09:40 - 14 Oct 2015    Post subject: Reply with quote
Exactly. You won't get a legal one in 7x5, because a 7x5 plate is inherently not legal already. If you want a metal one, get a metal one. You'll only be committing the same offence you're already committing anyway.
I think the unspoken rule is that as long as the ANPR cameras can read it without any problems, nobody gives a shit.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
grr666
PostPosted: 10:07 - 14 Oct 2015    Post subject: Reply with quote
Indeed. My 'illegal' plate on my bike has BSAU145d markings on it anyway, Laughing despite being wrong sized and
having a green coloured border around the slightly smaller than standard lettering. Embarassed Again, despite
my best efforts I have still to be pulled for it. I have the dealer plate for its first MOT next year if I still have the bike then.
Matt B
PostPosted: 10:42 - 14 Oct 2015    Post subject: Reply with quote
Well technically because it's all about the letter sizing, spacing and borders, not the actual plate size, it depends on how many letters you have. 7x5 would be legal for something short like registration B6.
Andy_Pagin
PostPosted: 11:05 - 14 Oct 2015    Post subject: Reply with quote
From Jan 1st 1973 it has to be for all intents and purposes the same as a modern plate, except for the type-face regulations which apply from 1st September 2001.
I suspect the DVLA and the British Standards people would take a dim view to anyone slapping BS AU 145d on a piece of ally with what most definitely is NOT the 'standard character font'.
That said, I doubt plod would stop you for it, unless ANPR was upset about it. Keep a copy of the Ebay page to hand though, afterall if you do get shafted you may as well take them down with you.
Here's the joe public friendly leaflet (as supplied to me by plod)
https://www.dropbox.com/s/z4jjtgf66aarnf5/number_plates_dg_067666.pdf?dl=0
and here's the Sir Humphrey Appleby friendly low down
https://www.legislation.gov.uk/uksi/2001/561/pdfs/uksi_20010561_en.pdf
PostPosted: 12:17 - 14 Oct 2015    Post subject: Reply with quote
I suspect that if you wandered o'er the land on a thousand year quest that you would never find anyone in those organisations who could bestir themselves to give a single solitary fuck about it.
DVSA and MOT testers, just perhaps, but only to the extent of not issuing an MOT pass.
Jayy
Mr. Ponzi
PostPosted: 13:46 - 14 Oct 2015    Post subject: Reply with quote
I don't think they care around here, had 7x5 and 9x3 in the last 5 years and never once got pulled up about them, even after a few run ins with the law over traffic offences.
Like already mentioned, as long as ANPR can ping you and it isn't ridiculously illegal (bad fonts, 3d, etc) I don't think they really care.
Been out again today and the plate has warped again with the heat. This metal one will be here next week so it will hold up until then (waste of £20 for the plastic one).
PostPosted: 13:59 - 14 Oct 2015    Post subject: Reply with quote
Why not do a vinyl sticker then stick that onto a bit of sheet metal. Job done.
The last post was made 11 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 118.48 Kb
