Pressing out a yoke stem - DIY
A100man
PostPosted: 20:49 - 13 Oct 2015    Post subject: Pressing out a yoke stem - DIY Reply with quote
Hi All
Anyone done this ? Thinking of try to rig something up using a bottle jack and steel frame - other suggestions appreciated.
J
sickpup
Old Timer
PostPosted: 22:11 - 13 Oct 2015    Post subject: Reply with quote
Buy a press. Thumbs Up
SQL
PostPosted: 22:55 - 13 Oct 2015    Post subject: Reply with quote
Good luck getting a 20 ton bottle jack
A100man
PostPosted: 23:01 - 13 Oct 2015    Post subject: Reply with quote
Now why didn't I think of that ? Neutral
bladeblaster
PostPosted: 08:37 - 14 Oct 2015    Post subject: Reply with quote
don't think a bottle jack will be man enough, those things are a real big interference fit, take some serous weight to press them out.
Why do you want to press it out anyway?
Fizzer Thou
PostPosted: 09:39 - 14 Oct 2015    Post subject: Reply with quote
I wanted to have the bottom yoke of my dirt bike reanodised to a different colour so I needed to press out the centre stem.They are only an interference fit so I just went to a local car garage and borrowed their press.Took five minutes.
Always have a 'Plan B'
DrDonnyBrago
PostPosted: 09:53 - 14 Oct 2015    Post subject: Reply with quote
https://www.screwfix.com/p/hilka-pro-craft-20-tonne-bottle-jack/81887
Fizzer Thou
PostPosted: 09:59 - 14 Oct 2015    Post subject: Reply with quote
Agreed.Plenty around Thumbs Up
https://www.machinemart.co.uk/shop/product/details/20-tonne-bottle-jack
A100man
PostPosted: 22:44 - 14 Oct 2015    Post subject: Reply with quote
To simplify a front-end swap.
My best jack is only about 10 t so might end up seeking pro help in that case.
Thanks for replies.
J
PostPosted: 23:57 - 14 Oct 2015    Post subject: Reply with quote
My "20t press" came with a standard 20t bottle jack - useful for lifting the truck without worry.
Fizzer Thou
PostPosted: 16:44 - 16 Oct 2015    Post subject: Reply with quote
Vincent wrote:
Has anyone managed to remove a stem, or heard of it being done with a fly-press?
Yes.As I stated above,I pressed out the stem from the bottom yoke of my KTM.
Of course,on some bikes they are welded together Wink
PostPosted: 22:13 - 16 Oct 2015    Post subject: Reply with quote
Don't bother with a fly press. It's a production tool used for punching holes or other features in thin sheet steel. The number of the press usually indicates the tonnage, and even a No4 press is a big lump of iron. They are expensive to buy, cumbersome, use a lot of room and require a very heavy bench to support them. Oh and to pass a long item though the press requires a big hole in the bench and space underneath.
On the other hand a 6 ton hydraulic press is quite cheap, light, has a fairly small footprint and is much more versatile. Of course if you have some fabrication skills and a supply of scrap you could make a 10-20ton press for little money.
The last post was made 10 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 81.89 Kb
