GN125 Engine Rebuild (REALLY NEED ADVICE!)
Need a new engine?
yes
0%
 0%  [ 0 ]
no
100%
 100%  [ 1 ]
Total Votes : 1
CasperAndRed
PostPosted: 12:16 - 14 Oct 2015    Post subject: GN125 Engine Rebuild (REALLY NEED ADVICE!) Reply with quote
Hey guys new member here and pretty damn new to bikes (that said I don't think ill ever be happy again without at least one..).
Basically about 2 and a half months ago I passed my CBT had a GN125 waiting in my back yard and two weeks later tried to take it to Ireland. Got about half way to the ferry and it went bang.
Turns out the spark plug exploded into the engine and now its full of shrapnel.
So I've already tried replacing spark plug and running it to see if the metal would blow through the exhaust, it wouldn't turn over, so now I have the engine out of the bike and am planning on rebuilding it.
I have no workshop, and need to buy tools etc for the job but does anyone fancy helping me out by telling me what I need? I don't want to go and blow next months pay on a bunch of useless tools that will break or be wrong for the job.
Any help would be great guys cause I cant ride until I either fix this bike or buy a new one and turn this into a project.
P.S. I doubt anyone on here will be heartless and say scrap the bike and buy a new one (heard it from all my friends before that don't ride) but im not willing to give up on my baby after getting it to ayr before my trip and then going back through to pick it up.
Just so you can all laugh at the newb biker here, it took me 16 hours to get from Edinburgh to Belfast and I arrived at like 3 in the morning and had to get picked up by my girlfriends mum at the ferry. Brick Wall
If you want to live, don't touch my girlfriend, my dreads or my bike.
RhynoCZ
PostPosted: 13:50 - 14 Oct 2015    Post subject: Reply with quote
Hello and welcome,
If the source of the metal bits is the faulty spark plug, then I'd take off the head and clean the engine properly, before attempting starting it again. Once the head is down you can see if the valves, piston and other bits are still alright. I'd be also draining the oil, to see if the metal bits got also somewhere else. Thumbs Up
CasperAndRed
PostPosted: 13:53 - 14 Oct 2015    Post subject: Reply with quote
(noob question here)
Normal socket set and some spanners enough to do this? don't want to start if it get half way through and find something im not prepared for.
RhynoCZ
PostPosted: 13:56 - 14 Oct 2015    Post subject: Reply with quote
Yes, the tools you already own should be enough for this job.
EDIT: The head and oil is what I would do. Some would just change the spark plug and ride it, since the only way the metal bits can possibly go, is the exhaust. I'd check at least the piston for dents. Thumbs Up
CasperAndRed
PostPosted: 14:00 - 14 Oct 2015    Post subject: Reply with quote
Cheers mate, like I say I tried to run the bike but it wasn't turning over, not sure if something got jammed, my carbs exhaust manifold and air intake(?) (that's my best description of what was in the pic) are littered with the metal
RhynoCZ
PostPosted: 14:08 - 14 Oct 2015    Post subject: Reply with quote
Drain the oil, check for metal bits in it. Then, it's the head off time. Check for any damage in the head and combustion chamber. This could also be a cracked cylinder sleeve. No need to worry, if the engine is past a reasonable repair, then there are tons of engines that will fit your frame. Wink
CasperAndRed
PostPosted: 14:11 - 14 Oct 2015    Post subject: Reply with quote
As for cleaning the metal out wipe down just do? should I use fluid for cleaning the carb?
Thanks btw for taking the time to reply
RhynoCZ
PostPosted: 14:25 - 14 Oct 2015    Post subject: Reply with quote
The carb won't need cleaning, but you could use a chain cleaner for instance. Anything that does not harm rubber and is not greasy should be alright.
The engine: if you use an cleaner (engine specific or once again something that doesn't eat rubber - DO NOT USE WD40), then I'd use clean engine oil to lube the moving parts and cylinder sleeve after you're done.
To take it apart and then back together, find the service manual to your bike. It's here on the BCF + there are tons of videos on youtube, where people work on the GN engines.
CasperAndRed
PostPosted: 15:39 - 14 Oct 2015    Post subject: Reply with quote
how do you remove the tach cable housing? mines on solid?
RhynoCZ
PostPosted: 15:52 - 14 Oct 2015    Post subject: Reply with quote
I'd just disconnect the cable and leave it on. By the way, loosen up no. 16 while it's till in the bike. It'll be easier than trying to loose it up in your bare hands.
https://www.motolights.cz/pd/picown2/417980.png
CasperAndRed
PostPosted: 16:51 - 14 Oct 2015    Post subject: Reply with quote
got it off, turned out the tacho was completely seized to the housing...so half is in the housing half is in the engine.
too late for no.16 had the engine out before doing this post haha
Found you why there was so much metal, the piston is completely blown, looks like this is going to be a worse job than I thought.
Thanks for all the help Smile
RhynoCZ
PostPosted: 17:16 - 14 Oct 2015    Post subject: Reply with quote
I'd keep taking it apart and inspect the engine. If the piston is the only thing, that needs to be change, look for another piston. If there's more damage, just buy a new engine of ebay. The GN engine was put into many, many motorcycles and still is used in chinese bikes.
Your engine should be the same, or very similar to Suzuki GZ 125, the stuff Sinnis makes and others. Google around. Thumbs Up
Robby
Dirty Old Man
PostPosted: 18:50 - 14 Oct 2015    Post subject: Reply with quote
Spark plugs do not typically explode. To turn a piston into little bits of metal you normally need to introduce something hard for the piston to bash into. This process will generally also wreck the cylinder head.
Those little bits of piston can then drop down into the (still spinning) engine to damage other things - such as by getting caught between gear in the gearbox. The saving grace is that the oil pickup on most engines has a strainer, to prevent these little bits of metal from destroying your oil pump and crank.
Either way, fixing it is an involved process which involves stripping the engine and examining all of the bits. If you don't know what you're doing, you can't do this.
A replacement engine is the easy way forward, but also try to work out what caused this one to fail in case you take out the next engine in the same way. It could be a dodgy plug, but I'm not sure where you would be able to buy such a thing these days. It could be a part of the carb that had somehow come loose and been sucked into the engine. If you aren't running an air filter, then you should be.
Carvel
PostPosted: 19:10 - 14 Oct 2015    Post subject: Reply with quote
The likely scenario is that it's dropped a valve.
As mentioned a replacement engine is the sensible answer. It will have scrapped most of motor.
Ariel Badger
PostPosted: 21:02 - 14 Oct 2015    Post subject: Reply with quote
One of two things has happened, the piston has hit a solid object such as a valve or it has overheated from a weak fuel mix and has melted. Either way a new engine will not cost a lot more than a rebuild.
The last post was made 10 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 15 - Page Size: 90.21 Kb
