annual oil change
czakal
PostPosted: 14:38 - 15 Oct 2015    Post subject: annual oil change Reply with quote
Hello,
My YBR250 owner's manual is a bit ambiguous about oil change schedules, as oil changes are listed in the things to be done every year but also states it's to be done every 10k km. I think many other bike manual say to change the oil every certain number of miles, or every year whichever comes first. Should I also follow that rule?
Seb
someotherguy
PostPosted: 15:10 - 15 Oct 2015    Post subject: Reply with quote
Yes - do whichever comes first, be it mileage or time elapsed between changes.
I do mine every 4,000 miles.
PostPosted: 16:28 - 15 Oct 2015    Post subject: Reply with quote
Yup, whichever comes first. I mean, unless you're doing very low mileages and don't really care about moisture in the oil.
I change twice as often as recommended, either mileage based or 6 months, using cheap oil.
pompousporcup...
PostPosted: 16:34 - 15 Oct 2015    Post subject: Reply with quote
IMO change is as at least yearly.. whats 20/25 quid for peace of mind, regardless of mileage done since last change?
czakal
PostPosted: 16:43 - 15 Oct 2015    Post subject: Reply with quote
Thanks for the tips, just didn't want to do unnecessary work. I will do it next month when it's due.
smegballs
PostPosted: 18:58 - 15 Oct 2015    Post subject: Reply with quote
I go on the basis that oil is cheaper than engine parts...
Add to that I'll be doing short journeys in cold weather over winter and I'm a firm member of the cheap-oil changed-often camp.
Just did my GN half hour and the whole process is a 10 min job.
PostPosted: 19:59 - 15 Oct 2015    Post subject: Reply with quote
My newly acquired motors will be 1500 mile changes. My Triumph will similar. My sv gets topped up because it likes to slurp some. The ped.... as and when.
kramdra
PostPosted: 20:53 - 15 Oct 2015    Post subject: Reply with quote
10k is a long time for a little, budget 250, based on the 125 engines.
PostPosted: 21:27 - 15 Oct 2015    Post subject: Reply with quote
10K km =~ 6200 miles.
But yes, I'd still call that too much. I do the Nazi Tractor every 3000.
MCN
PostPosted: 01:07 - 16 Oct 2015    Post subject: Reply with quote
Why are you changing the oil? Superstition?
Cheaper oils might not stay in grade as long as more expensive specialized/modern oils so more frequent change may be required.
I do at OEM recommended and never lost an engine yet.
Doing it more frequently may just be wasting oil.
My car says 20,000 miles for the engine. Full Synthetic (and a big sump). It gets changed at 20,000 no worries kittens all happy.
Go by what the OEM recommends and and sleep easy.
It's when you try to extend that recommendation things can get funny.
PostPosted: 09:02 - 16 Oct 2015    Post subject: Reply with quote
MCN wrote:
OEM recommended
Suzuki announced that the new V-Strom 1000 would have 3500 mile oil change intervals.
Outrage, rabble rabble, letters to the editor.
Just before release (which doesn't imply before manufacturing had begun in earnest), they increased it to 7500 miles because of "extensive engine development".
I find their story uncompelling, and suspect that decision to have been taken by marketing rather than engineering.
Northern Monkey
PostPosted: 11:09 - 16 Oct 2015    Post subject: Reply with quote
My BMW car has 20k intervals, the owners before me were lax on changing the oil, and a couple of times it did 30k before changes.
it got to 150k miles before an expensive electronics issue lead to scrapping.
Kittens may have been killed, but seemed to work ok until electodeath
czakal
PostPosted: 13:09 - 16 Oct 2015    Post subject: Reply with quote
I had been trying to follow manufacturer instructions... but they just happened to be a bit ambiguous (labelling oil change both annual maintenance and every 10k km without explanatory notes) and Yamaha UK didn't answer my question when I asked them. So I thought I'd double check.
In any case no danger at all that I may be changing less than needed: my mileage is pretty low as a part time worker/commuter.
Seb
PostPosted: 14:12 - 16 Oct 2015    Post subject: Reply with quote
My Trophy goes to the dealers once a year for it's service irrespective of the mileage.
If I include the 500 mile service and the time they recalled and fitted a new cylinder head it has had 5 oil changes in 4000 miles Embarassed
Rather overkill Laughing
smegballs
PostPosted: 15:47 - 16 Oct 2015    Post subject: Reply with quote
Don't know how it correlates to Jap engines, but lots of the ex-commercial vehicles like utes and vans in straya were apparently being serviced every 5k (km's).
You'd often see "serviced every 5k, receipts present" on gumtree. These would typically be big-displacement engines of US origin. Lots of them did seem to have crazy high milage and still be in good order though so didn't seem to be killing them...
PostPosted: 16:33 - 16 Oct 2015    Post subject: Reply with quote
Septics are mad keen on doing 3,000 mile changes, leading to lakes of barely used oil.
czakal
PostPosted: 16:43 - 16 Oct 2015    Post subject: Reply with quote
Indeed, it was one of the reasons why I decided to double check before doing my oil change. But you're right that 10k km seems like a lot for a small bike (I think for my previous Kymco Pulsar 125 it was like half that). But I'm unlikely to make that mileage in a year at current rate so the annual change will work quite well. Just got a few bottles of Castrol Power1 at a clearance at local Asda in fact...
Seb
The last post was made 10 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 92.11 Kb
