| Easyrider88 |
 Easyrider88 L Plate Warrior
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:40 - 18 Oct 2015 Post subject: Re: Gilera Couger 03 Problems. |
| Easyrider88 wrote: | £600, bargin! |
Errrr. OK.
It's possible that one of its many owners has up-geared it and you're just going past the power peak in 4th and 5th. Count the number of teeth on the sprockets and compare against what it's meant to be. Even if it's correct, it may just not have enough torque for 5th to be more than an economy gear.
Is the speedo working? Is it in any way accurate (check it against a GPS or speed-nag sign)? If so, I'd leave it alone rather than spending one penny more than you have to. If it's way off it may be because of the gearing. How's it driven? From the engine or from the wheel?
What's sticking? Is it the lever, or actuator arm on the clutch housing, or the cable? Detatch the cable at both ends and find out. If it's the lever or actuator arm, sure, just lube them. WD-40 might dissolve any crud that's in there, but it's not a lubricant. Use some form of oil, graphite or silicone lube.
If the cable is sticky then you can try lubing it (Google for how) but I'd be suspicious that it's being pinched or has frayed internally. Definitely check for that, having it snap while you're out and about is not much fun. ____________________ Biking is 1/20th as dangerous as horse riding.
| Robby |
 Robby Dirty Old Man
 Posted: 13:51 - 18 Oct 2015 Post subject: |
The first thing to do with a cheap bike is get it in the garage and give it a good going over and service. You will find more problems that the 3 things you already know of.
1. Lack of power. There are a multitude of possible causes on any bike. There are more on a 125, because you don't know what a previous owner brokes/changed trying to make it go faster. As Roger said, someone could have messed with the sprocket sizes. It could also be a choked (dirty) air filter, some unusual carb settings, a worn out spark plug, or you just aren't riding it hard enough. It's a 125, it has no power, it needs to be revved hard to make progress.
2. Speedo. If you are thinking of just fitting a cheap universal speedo, there is a good chance it won't work. Assuming a convential front wheel driven speedo, you can have variances based on the wheel size and speedo drive. If you have to change it, look for a speedo that is adjustable or can be switched between a variety of wheel sizes. Or just fix what you have.
3. Sticky clutch. The easy bits to check at the lever pivot, the cable, and the actuating arm down on the engine. The cable is the most likely problem, particularly if the cable is routed close to the exhaust. The heat from the exhaust dries out the lube in the cable, and in extreme circumstances melts the plastic part of the cable. If you remove/replace the cable, make sure you thread the new one through the same run - if you don't, you'll find that it pulls the clutch in when you turn the bars to full lock.
I know you want to ride it, but you should really get a Haynes manual and work through a full service first. Also worth thinking through the "tuning" that the previous owners may have tried, and set it back to standard. Fiddling with the mixture screw is an old favourite. |
| Easyrider88 |
The last post was made 10 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 42.37 Kb
