CBR 929 electrical fault
leonsg
PostPosted: 14:01 - 18 Oct 2015    Post subject: CBR 929 electrical fault Reply with quote
Hi guys
I have a 2001 CBR 929 that refuses to start. Fuel pump primes, starter turns over and the HISS and key system is working. The engine has compression. What could be causing this?
Thanks in advance
Copycat73
PostPosted: 14:44 - 18 Oct 2015    Post subject: Reply with quote
is this of any use Question
https://www.cbrxx.com/honda-cbr-xx-resource-center/10115-checking-for-fi-faults.html
caveat emptor
kramdra
PostPosted: 15:42 - 18 Oct 2015    Post subject: Reply with quote
Check connection on bank angle sensor, which on CBR6 is located above the headlight. You can temporarily bypass it to test by unplugging connector. There should be 3 wires,
Yellow is switched 12v supply
Red is the angle sensor signal
Green is ground.
Bike will run when red and green are connected, engine will stop when red and yellow are connected. Use a bit of wire to bridge the red and green wires. However it should be enough to clean up corrosion on the pins and replug it.
leonsg
PostPosted: 15:49 - 18 Oct 2015    Post subject: Reply with quote
Thanks copycat, actually very useful but unfortunately my error code light doesn't work so I'm not sure which error code its giving out. And okay thanks kramdra shall give that a try
The last post was made 10 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 38.87 Kb
