Am I meant to oil/grease the wheels?
Tomahawk
PostPosted: 14:56 - 18 Oct 2015    Post subject: Am I meant to oil/grease the wheels? Reply with quote
When I push my ZX6, the front wheel seems make some "friction" sounds.. is that normal? Am I meant to be oiling or greasing the wheels?
PostPosted: 15:12 - 18 Oct 2015    Post subject: Reply with quote
It's most likely the brake pads touching the discs and quite normal.
If you're unsure ask someone who is capable of holding a bike steady and check for play in the wheel bearings.
Grease is used on the spindle mainly to aid insertion and extraction, other than that you don't oil or grease the wheels. Smile
Tomahawk
PostPosted: 15:14 - 18 Oct 2015    Post subject: Reply with quote
Thanks.
How do I check for play in wheel bearings?
kramdra
PostPosted: 15:16 - 18 Oct 2015    Post subject: Reply with quote
Brake pads are always touching the disc, which can make noise, and is normal. The disc should not get warm if its not being used - ride a couple miles using only rear brake to test, if it cold, front brake is normal.
Worth checking the bearings occasionally - with front wheel off the ground check there is no play. When you next have wheel out, remove the outer seal from each bearing to check they have adequate grease and no rust. Do not let any dirt get in.
Tomahawk
PostPosted: 15:24 - 18 Oct 2015    Post subject: Reply with quote
Sorry, stupid question coming: Should I be taking the wheels off? I've never had occasion to do this, when would I take off the wheels?
Itchy
PostPosted: 15:39 - 18 Oct 2015    Post subject: Reply with quote
When you change tyres.. You can change brake pads with the wheels on.
You can do it without taking the wheels off. Just stick a hammer inverted under the swing arm and onto the side stand and try rock the wheels.
kramdra
PostPosted: 15:50 - 18 Oct 2015    Post subject: Reply with quote
As above wheel only comes out for tires, bearings, fork or chain service.
If there is *any* noise from bearings you should get the wheel out to inspect them, but its almost certainly from brake.
Tomahawk
PostPosted: 20:40 - 19 Oct 2015    Post subject: Reply with quote
OK, thanks guys, much appreciated.
The last post was made 11 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 57.08 Kb
