Brain is mush - electric circuit help needed
map
Mr Calendar
PostPosted: 15:53 - 09 Feb 2005    Post subject: Brain is mush - electric circuit help needed Reply with quote
Can't get my brain in gear today.
Going round in circles figuring out a circuit diagram.
Need a circuit to switch on when ignition circuit is off (as bike alarm).
Circuit will draw direct from battery when bike off, disconnected when bike on.
I know a relay will be in there somewhere but more used to using them to switch on with ignition.
Can anyone offer any help?
Git
PostPosted: 16:27 - 09 Feb 2005    Post subject: Reply with quote
It can be done easily as long as you have a 5 terminal relay.
Terminals 85 and 86 are used to energize the coil.
Terminals 87 and 30 is the switch, these two only become a circuit when power is applied to the coil and the contact is made.
Terminal 87a is made when the relay is off and broke when the relay is on, if you put the live feed from battery on 30, 87a will be live when switched off.
hope that helped a bit.
Fortuna
PostPosted: 16:41 - 09 Feb 2005    Post subject: Reply with quote
Edit: Too late, what he said. ^^
map
Mr Calendar
PostPosted: 16:52 - 09 Feb 2005    Post subject: Reply with quote
Git wrote:
It can be done easily as long as you have a 5 terminal relay...
Doh! Doh!
Here's me playing around with a pair of 4-ways!
Like I said, brain not in gear. Thanks for the info Thumbs Up
Villers
PostPosted: 19:30 - 09 Feb 2005    Post subject: Reply with quote
Its just a case of using the 'Normally open' contacts and the 'normally closed' contacts of the relay!
The last post was made 21 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 44.39 Kb
