CG125 Loose main bearing in crankcase.. Normal?
smallfrowne
PostPosted: 20:10 - 18 Oct 2015    Post subject: CG125 Loose main bearing in crankcase.. Normal? Reply with quote
Just dropped the oil out of the cg, opened up the filter and was greeted with a random bit of epoxy type stuff. It was hard, brittle and non-metallic.
https://i.imgur.com/zyRTgR1l.jpg
This coloured me curious and prompted further investigation.
It seems it was slathered on to the right hand side of the main bearing, with the indentations in the epoxy matching someone's attempt at using a nail punch to stop the bearing spinning in the crankcase. (right hand side, clutch side). It's obviously come loose and the bearing does spin in the case. For the past few rides I thought I was picking up a little bit more vibration than usual too, but I wasn't sure if I was going mad. But then 'extra' vibes may still be in my head as there isn't any play in the shaft given a good hard wiggle.
https://i.imgur.com/PORR9Agl.jpg
Never had the bottom end stripped down before, so my question is: Should the bearing be free to rotate in the crankcase like this? I can push it round with my finger. I'm going for no, and tempted to split the cases and slather some loctite in there (sparingly of course)... would that even hold it short/long term?
InB4 "get a new engine theyz only liek 50 squid safe urself sum hassle. Pass your test get busa" Very Happy
Cheers Cool
PostPosted: 20:20 - 18 Oct 2015    Post subject: Reply with quote
If you mean the outer race turning, no of course not.
Dimpling is a standard way of trying to recover a bearing housing when the bearing has siezed and worn away the casing. Add in bearing fit from Loctite and thats what you have there.
I know because this is a standard Marine engineers bodge when you don't have a new bearing case to fit and you have to get the macinery working till you hit port.
The only proper repair is a new case/housing. You could get it built up with weld and machined but I would suspect that would be more expensive than a new part.
So in b4 new engine - Yes another engine will probably be your cheapest route.
kramdra
PostPosted: 20:40 - 18 Oct 2015    Post subject: Reply with quote
CG would not be worth the effort of a swap or strip. Sell it as repairs while its still running and get something decent.. NSR125 perhaps Very Happy
MCN
PostPosted: 20:52 - 18 Oct 2015    Post subject: Reply with quote
You could clean it with brake cleaner and clash it together using Loctite High Strength Retaining Compound and a new bearing.
Or maybe sleeve the case.
smallfrowne
PostPosted: 22:46 - 18 Oct 2015    Post subject: Reply with quote
Thanks for the replies. Looks like there is already a steel liner. Hmmmmm
https://i.imgur.com/5v26Q5Il.jpg
I think I'll give it a good fettle with brake cleaner and paraffin next.
kramdra
PostPosted: 22:48 - 18 Oct 2015    Post subject: Reply with quote
If you are going to strip it anyway, get someone to mig a bead of aluminium around the bearing/punch marks. The bearing will need to be replaced, but it should not require any machining.
PostPosted: 22:53 - 18 Oct 2015    Post subject: Reply with quote
Bearing retainer is the way to go. Loctite 603 is high strength and oil tolerant. If it's more than 4 thou/0.1mm loose then Loctite 660.
smegballs
PostPosted: 05:18 - 19 Oct 2015    Post subject: Reply with quote
Pete. wrote:
If it's more than 4 thou/0.1mm loose then weld it up with a fishfinger electrode.
FTFY Thumbs Up
MCN
PostPosted: 09:25 - 19 Oct 2015    Post subject: Reply with quote
Pardon the pedant if you know this already. Paraffin then Brake Cleaner. It must be as dry as a witches tit (absolutely oil/grease free) to help the retaining compound set up and key into everything.
Use a medium wet or dry on the case to remove the polished surface. A rougher surface offers almost double the area for the glue to hold onto. The other stuff possibly fell off as it was not keyed into the case. (although it was probably only stuff squeezed out during assembly)
When the 603 is set you'll normally need a press or a lot of hammer-hammer-hammer to get the part out after. Embarassed
smallfrowne
PostPosted: 09:55 - 19 Oct 2015    Post subject: Reply with quote
Ok, having gone to bed and re-read the haynes manual, it notes
"The crankshaft assembly can be lifted out of position. The use of steel inserts in each crankcase half means that the main bearings are a light sliding fit, and offer little resistance during removal. They will remain in position on the crankshaft."
... so all seems well and as designed by the big H? Haynes mentions nothing of added loctite or making an effort to secure the bearings in the cases.
But! Another issue is now clear.
Now I have the crank out and can play with the two main bearings I can see some slop in both, although they are still smooth running. Time to replace the buggers then, but seems like hard work to get them off the crank, and the left hand one has the camshaft drive gear/pinion. Any tips on this job? Haynes says to mark the gear relative to the shaft to aid reassembly - but is it so simple? Am I just to man up, line the marks up to within 4 thou and then whack it back on again or am I missing something? Surely an error here could knock the timing off and kill the high performance of the machine.
https://i.imgur.com/3zpvSZS.png
Also, just seen the extra reply from MCN. The stuff that was glued on looked like it was stuck on from the outside, using the punch marks as a key. No sign of it on the inside of the case anywho. This bike has seen some bodges, I'm not surprised.
PostPosted: 11:56 - 19 Oct 2015    Post subject: Reply with quote
If that primary drive pinion is bigger than the bearing race ID it'll pull off the end of the crank, it's probably a light press fit and driven by a keyway.
Take care when pulling on that gear. Probably it would be best to pull on the bearing and let that get the gear moving then get some shims behind it. The bearing might not pull over the key though.
smallfrowne
PostPosted: 13:04 - 19 Oct 2015    Post subject: Reply with quote
Cheers Pete, yeah it must pull off, not that I have a puller (yet). The slightly worrying thing is that there is no keyway (I can see) and it's driving the cam. There is a punch mark to align with the cam gear when it goes back together. The primary drive is on the other side and slides onto splines.
https://i.imgur.com/XcO0a1U.jpg
The woodruff key in the exploded diagram (10) is for the alternator rotor. Why no key for the cam timing? Why big H, why?
https://i.imgur.com/Mzca5yt.jpg
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
MCN
PostPosted: 14:04 - 19 Oct 2015    Post subject: Reply with quote
Many 'interference fit' parts can be removed by simple heat.
Use a soft-ish flame on the inner 'hub' of the primary gear to warm it up. Heat fitting is usually around 120-140º (not often much more). So no chance of affecting any post machining heat treatment of the gear. Just keep the flame off any points/teeth tips as that can create localised hot spots.
A cold bandage made from a rag filled with crushed ice will help chill the end of the cranks as you apply heat.
Support the crank so the gear will fall down.
You can use a MAPP gas type of torch to do this.
Welder Gloves also help. Embarassed
The principle is to warm the smaller part which will reach a temperature that allows expansion before the bigger part catches up.
Fitting is the reverse. But turn the shaft up the other way Very Happy .
Mark the gear and shaft with something hard as a belt and braces in case there is no key. (But there should be a key or at least a pin and slot.)
smallfrowne
PostPosted: 15:07 - 19 Oct 2015    Post subject: Reply with quote
Sounds like half a plan then Very Happy
I have a decent propane torch, can get some ice ready (could stretch to a mojito to go with) and I have some gloves...
Looks like I'll need a puller for the bearings though, unless I can fanny the heat method to work on them too.. but any bearing puller recommendations for when I fail to master it? I've seen a 3 leg puller on the bearing king site (who are actually local to me and are a lovely bunch [/end non-affiliated passing comment]) but it's £130 ex. vat Shocked . Probably the crème of all pullers like but even so.
I'm going to try make some wedges out of steel strips with a ground edge to get it going as per the haynes.
The only issue with this whole procedure is that I'll struggle to get the pinion exactly back in place even with marks, what with it being an interference fit surely it'll be hard to adjust once it's on. I can see me wanting to heat it up and rag it round with some pipe pliars to get it to move and damaging the teeth. I hope the diagrams are wrong and there's a key and I'm worrying/whining about nowt.
Ah well, I'll dive in tonight and we'll see.
PostPosted: 16:21 - 19 Oct 2015    Post subject: Reply with quote
There is a special tool for pulling that gear.
I'm an enormous fan of special tools. Every one I've ever bought has made a difficult job easy.
I would assume if it's pulls the gear, it could also be used as an arbour to re-fit it.
Often the genuine Honda one is cheapest so if you have the workshop manual and it says the part number, plug it into David Silvers website. For example, I bought a honda flywheel puller a few years back. It was £10.50 and I proceeded to remove the flywheel off my H100 by hand pressure.
PostPosted: 16:26 - 19 Oct 2015    Post subject: Reply with quote
I wouldn't put a torch anywhere near that pinion. You risk drawing the temper on the teeth trying to heat up the hub. Just pull the beggar off.
PostPosted: 16:27 - 19 Oct 2015    Post subject: Reply with quote
Oh, and cheap but... Cheap.
https://www.ebay.co.uk/itm/12-pcs-Bearing-Splitter-Gear-Puller-Fly-Wheel-Separator-Set-With-Box-Tool-Kit-UK-/191693394149?hash=item2ca1d110e5:g:rO0AAOSwKIpV-o1X
PostPosted: 16:42 - 19 Oct 2015    Post subject: Reply with quote
Can't really go wrong for less than a round of beer. just make sure there's plenty of oil on the threads and grease the end. Perhaps put a small washer on the dimple to save marring the crank end.
The last post was made 11 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 106.6 Kb
